Pinebook Pro - Store Parts
#21
The only hard part is the trackpad. No screws. You will have to use pushing force for some time to get it off the plastic. Be patient.
#22
I replaced my ISO keyboard today. Not difficult; go slow and follow the PPT slides. I just put the screws and parts in an ordered stack; made it easy to reassemble. A couple of notes:
  • On first boot, the keyboard didn't work. Some keys would register a random character. Make sure you have a USB keyboard handy. It worked fine. I did a keyboard/trackpad patch. I followed the Manjaro procedure. On reboot, the keyboard works fine.
  • The screen was very dim, almost unreadable. FN+F2 worked to increase the display.
I wish threre were a backlit keyboard available.
#23
(06-17-2020, 06:58 PM)dgkPBP Wrote: I replaced my ISO keyboard today. Not difficult; go slow and follow the PPT slides. I just put the screws and parts in an ordered stack; made it easy to reassemble. A couple of notes:
Could you post a link to the guide you followed? Thanks!
#24
(06-16-2020, 06:09 AM)dgkPBP Wrote:
(06-11-2020, 08:52 AM)dgkPBP Wrote:
(06-10-2020, 10:29 AM)TDC_PBP Wrote:
(06-09-2020, 02:35 PM)dgkPBP Wrote: I ordered an ANSI keyboard for my Pinebook Pro/ISO about two weeks ago. It arrived today!
I naively assumed it would come with some type of instructions on how to do the replacement. No such luck.
Does anyone have procedures on how to do the replacement?
Thanks.
I would like to know that too! I have ordered a replacement as well, and unless somebody else posts a howto, I am planning on taking a video of me taking it apart, then playing it back in reverse and hoping for the best  Smile .
I'm looking forward to it! If I get some time and some nerve, I may give it a try.
I sent a note to support asking for documentation. They sent a PDF with pictures on how to do the replacement. I've attached the document.
I posted it as an attachement in this thread.
  Pinebook Pro Initial Impressions kunger 443 586,515 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,274 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 385 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 292 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 280 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 214 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 655 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 721 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,566 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,195 12-15-2023, 02:11 PM
