Help troubleshooting kernel panic
Hi! I'm new to the SBC world, so please excuse my noobness.
I've tried multiple images on my new Rock64 and all of them, at some point, crash. The problem is that I can't see the error messages because a lot of information is output too fast. Is there a location where that information is logged? I tried checking kern.log and other logs in /var/log but coludn't find anything.
(12-14-2019, 02:56 PM)gabrielfin Wrote: Hi! I'm new to the SBC world, so please excuse my noobness.
If anywhere it'd be in /var/log/syslog, that said using a Serial Console would be your best bet for capturing debugging info...
The messages don't seem to be logged to syslog, nor anywhere else...
Although once the following error did indeed show up in a log: https://pastebin.com/73tuTGUv
This is another error: https://www.dropbox.com/s/8wvrhc99k84j1j...b.mp4?dl=1 (I shot at 60 FPS but still the text goes too fast...)
I tried with different images and all show similar errors. Also tried flashing the images with both dd and Etcher. The images I tried were:
Armbian_19.11.3_Rock64_bionic_current_5.3.11_desktop.img
bionic-minimal-rock64-0.9.14-1159-arm64.img (ayufan)
buster-minimal-rock64-0.9.14-1159-arm64.img (ayufan)
rock64-debian-mrfixit-190531.img
bionic-lxde-rock64-0.9.14-1159-armhf.img (ayufan)
Most of the times, the crash happens while booting, but once in a while I manage to boot up correctly. But eventually I get a crash.
I tried with a different micro SD card, but the same happens. I also verified the SD card with f3write.
Any idea what's going on?
For anyone interested, the problem was a bad board. They're already sending me a replacement.
  Linux 5.15 Kernel - openSuse mark1250 0 1,288 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,776 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,641 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,294 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,066 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,091 04-18-2020, 11:34 PM
Last Post: CameronNemo
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,017 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,121 11-16-2019, 12:17 PM
Last Post: dkebler
  Does anybody run the mainline kernel? CameronNemo 3 4,659 09-09-2019, 07:56 PM
  ROCK64 Kernel compilation problem cao 0 2,474 01-21-2019, 01:21 AM
Last Post: cao
