Raspbian on the Pine 64 ?
Hi everyone,
I would like to know if this is plan to launch Raspian on the Pine, because many tutorials made for the Raspberry ( unfortunally there is no tutorial to makes projects on the Pine64 yet Undecided ) works on Raspbian ?
Thanks for your time
Have a nice day
Cookeys
(04-29-2016, 03:27 PM)cookeys Wrote: Hi everyone,
Have a nice day
Cookeys
Raspbian is just Debian for the Raspberry.
If you take a Debian image for the Pine64, you can use the same commands to install/update packages (sudo apt-get ...)
JAVE
(04-29-2016, 03:33 PM)I am a software person rather than a hardware one. Does that mean that Raspbian software will run on the Pine64? What about hardware oriented libraries like PWM, I2C and so on?Thnx Wrote:
Have a nice day
Cookeys
JAVE
as above, raspbian is just debian compiled to work on the raspberry pi hardware, the debian releases for pine are pretty much identical and you can use your tutorials from raspbian without any real issues.
Information Howto: OctoPrint Working on Pine 64 chaos_actual125 22 50,717 07-11-2021, 04:13 AM
Last Post: zer0sig
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,930 07-28-2020, 01:49 PM
Last Post: kuleszdl
  32bit Apps on Pine djinn5150 2 4,502 08-09-2016, 11:03 AM
Last Post: xalius
  Can ping between Pine 64 on a switch, but unable to ssh MikeJewski 4 6,151 07-28-2016, 08:40 PM
Last Post: MikeJewski
