different keyboard layouts (like AZERTY)
The current Pinebook pro comes with the option between ISO and ANSI layout, what is great. But it is only QWERTY.
I understand that makes sense. Other layouts are the exception. And this is not a store. To keep costs low, producing other low volume keyboard layout versions is probably not possible.
Nevertheless if you are accustomed to a non-Qwerty layout it can be annoying to be forced to use it. Using stickers is an option but not ideally. It never looks great.
Idea;
Let's take French Azerty.  Take all the keys with the correct printing on them for French Azerty.  And then remove the keys that are identical of the included QWERTY layout.
Sell that bag of extra printed keys as an ad-on to the order.  So ordering a Pinebook pro AZERTY FR is only the default computer + a bag of extra keyboard keys.
And then the buyer can do some puzzling to rearrange the keys. The bag can also contain a tool for removing the keys of the keyboard.
I suspect (hope) a bag of extra lose printed keyboard keys would not be very expensive. This way multiple keyboard layouts could be offert.
We may have something in the works to make it possible for users that rely on different keyboard layout. Stay tuned.
In thee mean time, ISO variants are the same keys with different labels. If you're okay with the key labels being wrong (like me, I type programmer's dvorak on standard ANSI labels), then you can order an ISO. If you're okay with relabeling with stickers, then order an ISO and some key label stickers. Otherwise, you may want to wait for an update from Luke.
  Did pine64 change the keyboard? Hsingai 1 3,831 08-10-2020, 06:52 PM
Lightbulb A low-tech hack to help the crappy keyboard combs 11 17,794 03-04-2020, 12:36 PM
Last Post: bancha
  Pinebook 11" Keyboard Corkonian 2 4,949 11-02-2019, 07:41 AM
Last Post: Corkonian
  keyboard x0r 0 2,292 07-11-2019, 11:57 AM
Last Post: x0r
  keyboard broken? Erik 0 1,906 05-20-2019, 02:52 AM
Last Post: Erik
  Scandinavian or alternate PineBook Keyboard? GreenThing 8 11,340 04-18-2019, 02:23 AM
Last Post: freppa
Information Pinebook 14" keyboard misses keypresses UPDATE MarkHaysHarris777 22 39,027 02-13-2019, 02:34 PM
Last Post: schallee
  Swapout Pinebook keyboard? maddmike 0 1,888 12-17-2018, 02:22 PM
Last Post: maddmike
  broken keyboard -> transplant all organs into an thinkpad? stereo 1 2,821 05-19-2018, 03:25 PM
Last Post: stereo
  Pinebook Keyboard and Stand MarkHaysHarris777 2 3,592 05-15-2018, 09:18 AM
Last Post: MattTC
