Trackpad firmware update
(07-26-2020, 06:10 PM)MtnSk8 Wrote:
(07-26-2020, 08:29 AM)rfm83 Wrote: This update doesn't apply to the units produced and shipped in May of 2020, correct?
I keep checking back for an answer to this question. I hope someone in the know will answer it at some point. Smile
I just tried updating it on my PBP from the May 2020 batch. Right now I have a bricked keyboard (ANSI) and trackpad. Not sure if this is an isolated issue or if I should not have tried on this version of PBP.
I’ll be trying to fix it later tonight. Anyone know how I can flash the old firmware back?
There was a long thread on this back when they first suggested doing the firmware update.
  I imagine there are some good ideas posted there that should still be helpful today.
  Just sometimes it can be frustrating trying to look up older threads.
Okay, I was able to fix it by running the updater in tty and doing a full shutdown (not reboot) after steps 1 and 2. Trackpad seems to work a bit better than it used to.
(07-29-2020, 06:54 PM)guiltydoggy Wrote: Okay, I was able to fix it by running the updater in tty and doing a full shutdown (not reboot) after steps 1 and 2. Trackpad seems to work a bit better than it used to.
Thanks for posting your results!  I was wondering if you now have additional touchpad functions like `2 finger tap for right click` or `sensitivity settings in kde systemsettings.`
+1, Just flashed this custom firmware, and the trackpad is much more usable. I'm a happy camper.
No, those settings are greyed out
IIRC the trackpad isn't improved, just the keyboard -- however the perception/experience is often connected.
@xmixahlx
On the other hand, I think Jack's replacement firmware has a small modification or 2 for the trackpad. It's not in the trackpad software it's self. Just that the keyboard controller has the connection to the trackpad. So, some communication modifications on the keyboard controller's software, (for the trackpad), has improved the trackpad slightly.
Got my ANSI keyboard replacement for my ISO Pinebook Pro. So I may move to Jack's keyboard firmware on both my ISO and ANSI.
Arwen Evenstar
Princess of Rivendale
Am I the only one who can't change the sensitivity parameters in the touchpad settings?
I've been using the firmware update from jackhumbert, and it vastly improves my touchpad experience, but it doesn't seem to persist a reboot. Has anyone else experienced this?
I'm using debian from the pinebook pro installer.  Its not like the firmware somehow is getting reverted, because if I modify the updater to purely enter boot mode and then do a reset (skipping the actual firmware flashing), the touchpad is suddenly usable and great again.  As far as I can tell, nothing is different when Xorg detects the device the second time -- the logs indicate the same parameters with respect to acceleration, the only thing that changes is the ID (event11 instead of event7 in my case), probably because its rediscovered.
I'm tempted to just trigger this on my xsession.
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,190 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,036 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,051 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,937 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,295 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,414 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,081 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,914 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,371 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,565 10-19-2021, 01:57 AM
Last Post: j4n3z
