Install OS directly to eMMC?
You should, of course, shrink the partition first if you have grown it to fill your SD card, otherwise you will almost certainly end up with corruption.
If it's possible to increase the pixel density of the screen I think it would be ideal since I think most phone apps probably would do better with 150% the current PPI density. Also, digitizer accuracy and responsiveness are pretty important and maybe having a faster form of memory than SD-Card.
Of course it depends on what kind of device you are trying to build and what cost-range too. I think there's interest in a more expensive higher quality device provided value is exchanged for the benefits.
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,330 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 2,916 04-09-2023, 06:08 PM
Last Post: zetabeta
  Install OS Permanently ismkdc 1 1,373 03-20-2023, 01:13 PM
Last Post: fxc
Question PinephonePro can't Flashing to the eMMC ricardo 0 728 08-21-2022, 05:51 AM
Last Post: ricardo
  install packages pamac anbox neithan76 0 710 07-18-2022, 07:13 AM
Last Post: neithan76
  How to replace the home folder on eMMC ragreenburg 2 1,737 03-31-2022, 02:19 PM
Last Post: ragreenburg
  Wipe out eMMC before flashing new OS? zkajdan 15 9,906 11-13-2021, 03:10 AM
Last Post: zetabeta
  Streamlined jmms install amindfv 1 1,674 10-29-2021, 07:04 AM
Last Post: TRS-80
  Anbox: install Google Services sonic 0 1,944 02-07-2021, 04:45 AM
Last Post: sonic
  Emmc drive gone? Flashing with Jump Drive muemmel 2 3,413 11-12-2020, 05:40 PM
Last Post: hiimtye
