PIneBook Pro - Boot from SD
I have a new PineBook Pro, and simply want to boot from an SD image.   I've carefully followed the instructions to create a Bionic LXDE Community Build using Etcher on my Mac.  From what I have been able to understand, all I need to do is insert the formatted card into the PineBook and power on in order to boot to the SD, but it won't.  Instead, the PineBook always boots to the default OS that was delivered with the device.
I am totally stuck.  I've looked through the forums and tried various images with the same result.
I've reviewed the common issues posted by 'Ghost' and none apply to my environment.
Is there some kind of boot sequence key combination that I need to press to boot using the image on the SD card?
Any guidance is appreciated.  Thank you!
Have you fully updated the default OS, yet?
(11-10-2019, 06:23 PM)tophneal Wrote: Have you fully updated the default OS, yet?
Nope. I’ll look into it and try. Thank you!
To be more explicit -- there's an update button in the tray next to the clock on the default debian desktop. Click/run that, it calls a separate script that'll pull down updates not included in packages.
Thanks for the tips.  I updated via the command line because I don't have an 'update' icon in my tray.  (sudo apt update; sudo apt upgrade).  Still not booting from MicroSD.  The SD card is mounting with  "boot" and "linux-root" drives, so I know the card is seen and recognized.  It just doesn't seem to be selected as the boot source.  I am out of ideas on how to resolve this.
Again, thank you for your replies!
(11-12-2019, 09:07 AM)mcdomx Wrote: Thanks for the tips.  I updated via the command line because I don't have an 'update' icon in my tray.  (sudo apt update; sudo apt upgrade).  Still not booting from MicroSD.  The SD card is mounting with  "boot" and "linux-root" drives, so I know the card is seen and recognized.  It just doesn't seem to be selected as the boot source.  I am out of ideas on how to resolve this.
You might need to manually update your uboot. I'll see if I can dig up on of the links/posts already up.
Per Wizzard:
Quote:If we need also to boot other operating systems, we need to apply uboot fix. So download all the files from here https://github.com/mrfixit2001/updates_r...filesystem and run the mrfixit_update.sh script while running from eMMC.
I had this boot issue last weekend as well. PBP was always booting from the eMMC.
This changed with running the fixit script from /usr/bin/. Please try this at first.
Next problem was that I didn't know, how to write a new image to eMMC. From the
Pinebook I know hat there were special sd card images which do this when booting from sd card.
Finally I booted from sd card and wrote the new image via dd to eMMC. This works fine for me.
Regards, Ansgar
Thank you all for your input! Using the MrFix it script worked! I am up-and-running! For anyone stumbling on this post with the same issue, the solution is to update the image you're received. I did this by cloning the git repo:
https://github.com/mrfixit2001/updates_repo/tree/v1.1
and running the "mrfixit_update.sh" script.
After that, everything worked as I expected and I was able to boot from the sdcard.
(11-13-2019, 04:44 AM)mcdomx Wrote: Thank you all for your input!  Using the MrFix it script worked!  I am up-and-running!  For anyone stumbling on this post with the same issue, the solution is to update the image you're received.  I did this by cloning the git repo:
which image did you pick? any of these: https://wiki.pine64.org/index.php/Pinebo..._Downloads
or would I expect the images for the original pinebook to work on the pro as well from here:
https://wiki.pine64.org/index.php/Pinebo...re_Release
The images for the original Pinebook will not work for the Pinebook Pro. You may have luck with some images for the RockPro64, though, since it shares the same "guts" as the PBP.
  Pinebook Pro Initial Impressions kunger 443 586,440 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,274 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 384 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 290 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 279 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 213 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 654 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 719 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 782 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 283 01-16-2024, 09:17 AM
Last Post: jbradley419
