~/.profile not being sourced upon login
Bug
Has anyone else had issues relating to ~/.profile not being sourced upon login.
I've made a couple of customisations that add a couple of directories to the system $PATH upon login. However, these don't seem to materialise when I login. Namely:
# set PATH so it includes the snap bin if it exists
if [ -d "/snap/bin" ]; then
PATH="$PATH:/snap/bin"
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/.local/bin" ] ; then
   PATH="$HOME/.local/bin:$PATH"
fi
Both directories appear in the system $PATH if I run:
source ~/.profile
Ben
@"Feakster", try this file instead;
.bash_profile
Arwen Evenstar
Princess of Rivendale
I've always referenced this flowchart to follow bash's initialization insanity:
https://i.stack.imgur.com/17NoJ.png
Pick your login type and follow the colored arrow to see which files bash loads under different circumstances.
See here for more: https://blog.flowblok.id.au/2013-02/shel...ripts.html
(11-09-2019, 02:10 PM)Arwen Wrote: @"Feakster", try this file instead;
.bash_profile
I thought it was the case that .bash_profile was sourced if it existed, otherwise .profile was sourced?
Just tried this and rebooted. The contents of the .bash_profile file were also not being sourced.
Ben
(11-09-2019, 09:40 PM)Arglebargle Wrote: I've always referenced this flowchart to follow bash's initialization insanity:
Thank you. I put the code in .bashrc & it works now.
Ben
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 657 07-13-2023, 05:21 PM
Last Post: owaspfap
  Chromium Not allowing google login sititahwsi22 1 2,771 11-07-2020, 03:35 PM
Last Post: regivanx
  can't login on pine pro 64 LRFritz 0 1,571 09-25-2020, 02:13 PM
Last Post: LRFritz
  Manjaro ARM Sway Profile appelgriebsch 20 20,447 08-03-2020, 10:28 AM
Last Post: appelgriebsch
  Manjaro bootup freezes on logo before Login LMalilil 26 31,579 07-23-2020, 07:58 PM
Last Post: vdicarlo
