Defective screen?
After about 30 minutes of uptime my screen will start to glitch out and eventually remain "double imaged" and persist even through reboots until the laptop has been turned off for a while. Has anyone else experienced this? I have a support ticket in, but have not gotten a reply other than my issue is being forwarded to an engineer. Hope this can get sorted out soon because I waited so long for this thing.
[Image: 5-A26-C7-E6-E907-48-BC-854-B-39-E73796102-B.jpg?dl=1]
This is what it looks like when the issue just starts happening. Then, as described above, the screen will just stay "double-imaged".
[Image: giphy.gif]
I had this exact same issue
After a short time of being on, the image would double like this, and after an hour or more, it eventually degrades into nothing but grey vertical bars. Since then, my screen has gone completely black and will not turn on at all.
When you know what happened, and how to fix, (even if it's simply a RMA), let us know.
I can update the Troubleshooting section for the Pinebook Wiki with the information, so that others have clues.
Arwen Evenstar
Princess of Rivendale
(11-09-2019, 02:06 PM)Arwen Wrote: When you know what happened, and how to fix, (even if it's simply a RMA), let us know.
Mines does that but it only happens if I'm loading up Debian Itll boot just like that. At this time I'm using Manjaro.
"That, according as it is written, He that glorieth, let him glory in the master."
1 Corinthians 1:31
  Malfunction: horizontal white streak on the screen regivanx 0 929 06-23-2022, 12:59 AM
Last Post: regivanx
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 1,685 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  I broke my screen :( espenbo 3 2,901 01-03-2022, 03:46 PM
Last Post: altacus
  Broken Screen vxzero 0 1,325 08-26-2021, 09:02 PM
Last Post: vxzero
  Screen offset nobodyinperson 7 8,884 01-26-2021, 04:55 PM
  Pinebook Pro screen failure? BBreeziN 1 2,886 01-08-2021, 03:21 PM
Last Post: member
  Horrible screen flicker/strobe on battery power mattjb 19 24,330 09-14-2020, 03:19 AM
Last Post: m.bakhterev
Thumbs Up 180 degree screen tilt mod - works for me! mil 2 4,201 08-21-2020, 05:28 AM
Last Post: polrus
  PBP not booting screen blank after SD card boot Jakobp 10 13,459 08-18-2020, 08:56 PM
Last Post: trinapicot
  PBP lines across screen, halts whilst running (prev. will not power on) ajcollins 5 6,713 07-05-2020, 02:30 AM
Last Post: ajcollins
