I've built my own android rom for the pinebook (the /e/ rom pinned) and I'm trying to create a sd2emmc image. I haven't been able to do it so far, I've tried to replace the pinebook.img inside kde neon, so it flashed android instead of kde neon, then it doesn't boot, looking for a partition that doesn't exist so it seems it is a problem of mount of partitions
fdisk: can't open '/dev/block/mmcblk0': No such file or directory
I'm guessing partitions are not in the right place
Any ideas ?
thanks
Any ideas ?
thanks
