But can it run minecraft?
Is there any guidance on this issue, I kind of want to demo it on a video since I got mc to run on my pi. Can the PBP do the same with the correct magical commands?
Have you tried setting up the MC Pi edition yet? This seems to be an available option people with Chromebooks have been using, too: https://mcpelauncher.readthedocs.io/en/l...arted.html
Pi Edition, if you can get it, should just work.
For normal (Java Edition) Minecraft, there's a lot of work to do for it, but it should be possible. From what I remember it's mostly to do with replacing the LWJGL version for x86 that comes with MC, with one compiled for ARM.
Lol the pi addition is like being forced to have an abortion, but it seems minetest works Smile
@Atton this thread on reddit might be of some help if you're feeling adventurous.
https://www.reddit.com/r/chromeos/commen...n/dhb6t7k/
Did some testing on this with various versions of linux. In one cases thanks to software rendering it can work with the following guide. https://www.raspberrypi.org/forums/viewt...8&t=243946
I honestly don't have a clue how to get opengl working on the system so the fps sucks.
  Minecraft Java on the Pinebok Pro BenniTec 1 1,428 07-07-2022, 08:48 PM
Last Post: branon
