Booting with default debian image
(11-07-2019, 09:36 AM)tophneal Wrote: If you have a USB c cable you can use rkflashtool to flash to your emmc. Refer to the wiki for the internal button that puts the PBP in mask tomorrow mode.
I don't think i would attempt that till the documentation is a little more nailed down. I don't have multiple units to experiment with.
It should be the same process as with any other rockchip. There's a button inside the PBP for entering mask rom mode, plugin USBC cable to your PBP and computer, flash IMG with the rkflashtool.
Sent from my iPhone using Tapatalk
(11-07-2019, 04:10 AM)danielt Wrote:
(11-07-2019, 02:51 AM)mfritsche Wrote: Next stupid question:
I see that extlinux.conf defines a boot menu. Is the menu only available via serial console?
Yes.
Hopefully this can change as the platform matures (u-boot can draw to framebuffers and listen to USB keyboards but it requires drivers and these don't exist just yet) but at present you need a serial port to interact with the boot menu.
A simple approach is to put your boot partition on an SD card since if you need to change kernel you can eject the card, boot from a eMMC and edit extlinux.conf .
So, my understanding is:
1. SoC looks for u-boot, loads u-boot
2. u-boot looks for boot loader (extlinux used for standard image), loads extlinux
3. extlinux looks for extlinux.conf, loads and starts kernel
So actually, it's extlinux that doesn't have a framebuffer/ keyboard to display the menu/ get user input right now?
Shameless self-plug: I made a guide that „works for me™“ how to compile a kernel (mrfixit's 4.4.196) on the Pinebook Pro itself, and safely booting it from SD card:
https://dynamic.reauktion.de/flugphase/2...mpilation/
(created from .bash_history).
DO NOT TRY IF YOU DON'T KNOW HOW TO RECOVER FROM A BRICKED DEVICE!
(11-08-2019, 05:52 AM)mfritsche Wrote: Shameless self-plug: I made a guide that „works for me™“ how to compile a kernel (mrfixit's 4.4.196) on the Pinebook Pro itself, and safely booting it from SD card:
I will review and test your process tomorrow. The current kernel is missing an option I desire so this is a way to kill two birds with one stone.
Will report back on the results.
Unfortunately, the PinebookPro seems to get too hot. First, WiFi dies and then a lot of other fun stuff happens :/ So compiling right on the PinebookPro (at least with -j 6) is not advised.
  Debian on Pinebook Pro u974615 8 436 03-22-2024, 03:57 PM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,107 02-22-2024, 04:02 PM
  Nethunter default password failed lamlarryyyy 0 266 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 3,826 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,012 09-07-2023, 09:38 PM
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 899 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 3,819 07-15-2023, 02:58 PM
Last Post: u974615
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,650 04-01-2023, 02:58 PM
Last Post: TRS-80
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,199 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,238 12-09-2022, 05:04 AM
Last Post: ndp
