LSI SAS3082E-R
Did not boot.  Might try to flash to IT mode.  Serial output:
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 250
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
FwPartOffset=2000 , 0
StorageInit ok = 43990
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xd35dc
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  3.9 GiB
Sysmem: init
Relocation Offset is: f5bfa000
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
               DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled
               DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
                LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
             SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled
                  dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
              vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)
       vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
          vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
        vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, disabled | suspend     -61uV, enabling
              vcc5v0-sys@     vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
   vcc12v-pcie-regulator@    vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV
             vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)
MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   serial
Err:   serial
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Bootdev(atags): mmc 1
PartType: DOS
get part misc fail -1
boot mode: None
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
 aplll 816000 KHz
 apllb 24000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
 aclk_perihp 133333 KHz
 hclk_perihp 66666 KHz
 pclk_perihp 33333 KHz
 aclk_perilp0 266666 KHz
 hclk_perilp0 88888 KHz
 pclk_perilp0 44444 KHz
 hclk_perilp1 100000 KHz
 pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
load_android_image: Can't find part: boot
Android boot failed, error -1.
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
404 bytes read in 3 ms (130.9 KiB/s)
1: ROCKPRO
Retrieving file: /Image
reading /Image
25612296 bytes read in 2715 ms (9 MiB/s)
append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current
Retrieving file: /rk3399-rockpro64.dtb
reading /rk3399-rockpro64.dtb
96363 bytes read in 13 ms (7.1 MiB/s)
## Flattened Device Tree blob at 08300000
  Booting using the fdt blob at 0x8300000
  Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 3840.443 ms
Starting kernel ...
[UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice System Slice.
        Mounting POSIX Message Queue File System...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on Journal Socket.
        Starting Load Kernel Modules...
        Starting Create list of required st…ce nodes for the current kernel...
        Starting Restore / save the current clock...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Paths.
        Mounting Debug File System...
        Starting Remount Root and Kernel File Systems...
[  OK  ] Reached target Swap.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on Syslog Socket.
        Starting Journal Service...
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Remount Root and Kernel File Systems.
        Starting Load/Save Random Seed...
        Starting udev Coldplug all Devices...
        Starting Create Static Device Nodes in /dev...
        Mounting FUSE Control File System...
        Mounting Configuration File System...
        Starting Apply Kernel Variables...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
        Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
        Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Journal Service.
        Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
        Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Reached target System Time Synchronized.
        Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
        Starting LSB: IPv4 DHCP client with IPv4LL support...
        Starting Login Service...
        Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started Boot and Home Patition Mount Service.
        Starting System Logging Service...
        Starting Save/Restore Sound Card State...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
        Starting LSB: Starts and stops Wicd...
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Timers.
[  OK  ] Started System Logging Service.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started Raise network interfaces.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Network.
        Starting Permit User Sessions...
[  OK  ] Reached target Network is Online.
        Starting LSB: Start NTP daemon...
        Starting OpenBSD Secure Shell server...
[  OK  ] Reached target Sound Card.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Login Service.
        Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started LSB: IPv4 DHCP client with IPv4LL support.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started LSB: Start NTP daemon.
[  OK  ] Started OpenBSD Secure Shell server.
[    3.237032] Internal error: : 96000210 [#1] SMP
[    3.237439] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[    3.238239] CPU: 0 PID: 49 Comm: kworker/u12:1 Not tainted 4.4.180 #1
[    3.238803] Hardware name: Pine64 RockPro64 (DT)
[    3.239219] Workqueue: deferwq deferred_probe_work_func
[    3.239681] task: ffffffc0f2bb9b00 task.stack: ffffffc0f24f8000
[    3.240205] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    3.240656] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    3.241107] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    3.241751] sp : ffffffc0f24fb7e0
[    3.242043] x29: ffffffc0f24fb7e0 x28: 0000000000000000
[    3.242516] x27: 0000000000000001 x26: 0000000000000000
[    3.242987] x25: 0000000000000000 x24: ffffffc0f14ad000
[    3.243459] x23: 0000000000000000 x22: 0000000000000004
[    3.243933] x21: ffffffc0f0ae4a28 x20: ffffffc0f24fb86c
[    3.244405] x19: ffffff8014100000 x18: 0000000000000005
[    3.244877] x17: 0000000000000000 x16: ffffff80081ede5c
[    3.245348] x15: 0000000000000000 x14: 000000000000000a
[    3.245820] x13: ffffff80898f48e7 x12: 0000000000000030
[    3.246291] x11: 0000000000000006 x10: ffffff80098f48ef
[    3.246763] x9 : 0000000005f5e0ff x8 : 616373203a31303a
[    3.247235] x7 : 3030303020737562 x6 : ffffff80098f4914
[    3.247706] x5 : ffffff80084a10bc x4 : 0000000000000000
[    3.248178] x3 : 000000000000000b x2 : 0000000000000800
[    3.248650] x1 : ffffff8012c00008 x0 : ffffff8014000000
[    3.249122]
[    3.249122] PC: 0xffffff80084a11a0:
[    3.249557] 11a0  54fffd01 39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[    3.250313] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[    3.251066] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[    3.251819] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[    3.252572] 1220  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[    3.253323] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[    3.254075] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[    3.254828] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[    3.255582]
[    3.255582] LR: 0xffffff80084a1190:
[    3.256017] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[    3.256770] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[    3.257523] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[    3.258273] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[    3.259026] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[    3.259777] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[    3.260528] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[    3.261281] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[    3.262032]
[    3.262032] SP: 0xffffffc0f24fb760:
[    3.262467] b760  00000004 00000000 00000000 00000000 f14ad000 ffffffc0 00000000 00000000
[    3.263220] b780  00000000 00000000 00000001 00000000 00000000 00000000 f24fb7e0 ffffffc0
[    3.263970] b7a0  084a1210 ffffff80 f24fb7e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[    3.264721] b7c0  00100000 00000000 f24fb86c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[    3.265474] b7e0  f24fb820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 f14ad000 ffffffc0
[    3.266227] b800  00000000 00000000 00000140 00000000 f24fb8ec ffffffc0 00000000 00000000
[    3.266979] b820  f24fb870 ffffffc0 0848210c ffffff80 f24fb8ec ffffffc0 f14ad000 ffffffc0
[    3.267732] b840  f14ad000 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[    3.268484]
[    3.268484] X0: 0xffffff8013ffff80:
[    3.268918] ff80  ******** ******** ******** ******** ******** ******** ******** ********
[    3.269676] ffa0  ******** ******** ******** ******** ******** ******** ******** ********
[    3.270429] ffc0  ******** ******** ******** ******** ******** ******** ******** ********
[    3.271182] ffe0  ******** ******** ******** ******** ******** ******** ******** ********
[    3.271935] 0000
[    3.272093] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[    3.965088] vendor storage:20160801 ret = -1
[    4.809094] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    4.809627] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    5.810091] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    5.810619] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[    6.811088] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    6.811615] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    7.812088] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    7.812612] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[    8.813093] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    8.813625] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    9.814094] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    9.814627] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   10.272919] BUG: spinlock lockup suspected on CPU#0, kworker/u12:1/49
[   10.273494]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:1/49, .owner_cpu: 0
[   10.274263] CPU: 0 PID: 49 Comm: kworker/u12:1 Not tainted 4.4.180 #1
[   10.274826] Hardware name: Pine64 RockPro64 (DT)
[   10.275237] Workqueue: deferwq deferred_probe_work_func
[   10.275698] Call trace:
[   10.275922] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[   10.276398] [<ffffff80080883e8>] show_stack+0x24/0x30
[   10.276845] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[   10.277292] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[   10.277729] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[   10.278230] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[   10.278764] [<ffffff8008088428>] die+0x34/0x1b4
[   10.279165] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[   10.279656] [<ffffff8008093324>] do_sea+0x80/0x94
[   10.280071] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[   10.280529] Exception stack(0xffffffc0f24fb240 to 0xffffffc0f24fb370)
[   10.281095] b240: ffffffc0f2bb9b00 0000008000000000 ffffffc0f24fb410 ffffff8008422884
[   10.281780] b260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[   10.282465] b280: ffffff80098f5148 0000000000000000 ffffffc0f24fb2b0 ffffff80080eda14
[   10.283149] b2a0: 0000000000000005 0000000000000000 ffffffc0f24fb350 ffffff80080edb74
[   10.283834] b2c0: ffffffc0f24fb3d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[   10.284519] b2e0: ffffffc0f24fb49c ffffff8014000000 0000000000000004 00000040ee841000
[   10.285204] b300: 0000000000000002 ffffffc0f24fb4a0 ffffffc0f24fb49c 00000000ffffffff
[   10.285888] b320: ffffff800991020f 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   10.286573] b340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   10.287256] b360: ffffff80081ede5c 0000000000000000
[   10.287684] [<ffffff80080825cc>] el1_da+0x24/0x84
[   10.288099] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[   10.288626] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[   10.289093] [<ffffff80080884ac>] die+0xb8/0x1b4
[   10.289493] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[   10.289981] [<ffffff8008093324>] do_sea+0x80/0x94
[   10.290395] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[   10.290853] Exception stack(0xffffffc0f24fb610 to 0xffffffc0f24fb740)
[   10.291417] b600:                                   ffffff8014100000 0000008000000000
[   10.292101] b620: ffffffc0f24fb7e0 ffffff80084a1220 ffffffc0f14ad120 000000000000006e
[   10.292786] b640: ffffffc0f24fb7f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[   10.293471] b660: ffffffc0f24fb752 0000000000000000 ffffffc0f24fb680 ffffff8009692000
[   10.294156] b680: 0000000000000140 00000000093c1b86 ffffffc0f24fb860 ffffffc0f24fb860
[   10.294840] b6a0: ffffffc0f24fb830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[   10.295525] b6c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[   10.296210] b6e0: ffffff80098f4914 3030303020737562 616373203a31303a 0000000005f5e0ff
[   10.296894] b700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[   10.297579] b720: 000000000000000a 0000000000000000 ffffff80081ede5c 0000000000000000
[   10.298263] [<ffffff80080825cc>] el1_da+0x24/0x84
[   10.298679] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[   10.299237] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[   10.299802] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[   10.300337] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[   10.300804] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[   10.301317] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[   10.301813] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[   10.302333] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[   10.302860] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[   10.303357] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[   10.303936] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[   10.304465] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[   10.304970] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[   10.305497] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[   10.306032] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[   10.306521] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[   10.307010] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[   10.307529] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[   10.308018] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[   10.308570] [<ffffff80080b2350>] process_one_work+0x224/0x368
[   10.309075] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[   10.309557] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[   10.309980] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[   10.815087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   10.815609] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   11.820087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   11.820611] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   12.821087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   12.821610] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   13.822086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   13.822609] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   15.809088] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   15.809611] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   16.810088] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   16.810611] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   17.811086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   17.811608] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   18.812087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   18.812609] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   19.813085] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   19.813609] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   20.814087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   20.814610] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   21.815086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   21.815607] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   22.816086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   22.816607] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   23.817086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   23.817608] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   24.157077] Watchdog detected hard LOCKUP on cpu 0
[   24.157490] ------------[ cut here ]------------
[   24.157912] WARNING: at kernel/watchdog.c:352
[   24.158292] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[   24.159076]
[   24.159211] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.180 #1
[   24.159734] Hardware name: Pine64 RockPro64 (DT)
[   24.160137] task: ffffffc0f328c380 task.stack: ffffffc0f32a8000
[   24.160662] PC is at watchdog_timer_fn+0x190/0x2e8
[   24.161081] LR is at watchdog_timer_fn+0x190/0x2e8
[   24.161500] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[   24.162143] sp : ffffffc0f7f3fdf0
[   24.162433] x29: ffffffc0f7f3fdf0 x28: 0000000000000000
[   24.162903] x27: ffffff80096d7720 x26: ffffff8009698260
[   24.163373] x25: ffffffc0f7f42278 x24: ffffffc0f32abda0
[   24.163842] x23: 0000000000000000 x22: 0000000000000000
[   24.164311] x21: ffffff80096d6000 x20: ffffff80096982d8
[   24.164780] x19: ffffff8009698000 x18: 0000000000000005
[   24.165249] x17: 0000000000000000 x16: ffffff80081ede5c
[   24.165718] x15: 0000000000000000 x14: 000000000000000a
[   24.166186] x13: ffffff80898f48e7 x12: 0000000000000030
[   24.166655] x11: 0000000000000006 x10: ffffff80098f48ef
[   24.167125] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[   24.167593] x7 : 6574636574656420 x6 : ffffff80098f491d
[   24.168062] x5 : 00000000fffffffe x4 : 0000000000000002
[   24.168531] x3 : 00000040ee8aa000 x2 : 00000040ee8aa000
[   24.169000] x1 : 0000000000000005 x0 : 0000000000000026
[   24.169470]
[   24.169470] PC: 0xffffff800812c6b8:
[   24.169903] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.170648] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.171396] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.172145] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.172888] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.173633] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.174380] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.175126] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.175872]
[   24.175872] LR: 0xffffff800812c6b8:
[   24.176305] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.177053] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.177799] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.178546] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.179292] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.180038] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.180785] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.181533] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.182280]
[   24.182280] SP: 0xffffffc0f7f3fd70:
[   24.182712] fd70  00000000 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.183462] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.184207] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.184953] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.185698] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.186447] fe10  9a444064 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000003 00000000
[   24.187193] fe30  098a07b8 ffffff80 9a444064 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.187935] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.188681]
[   24.188681] X6: 0xffffff80098f489d:
[   24.189114] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.189859] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.190605] 48dc  00000000 00000001 00000000 30303020 32303330 30363030 34205d35 20636438
[   24.191354] 48fc  312e3432 38363838 58205d31 30203a36 66666678 38666666 38393030 39383466
[   24.192101] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[   24.192851] 493c  30303030 72656e0a 7570635f 0a30203a 30303030 6c6c750a 625b2029 30207375
[   24.193596] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[   24.194345] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[   24.195092] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[   24.195841]
[   24.195841] X10: 0xffffff80098f486f:
[   24.196282] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197030] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197777] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.198524] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   24.199269] 48ec  312e3432 36323932 34205d39 20636538 312e3432 34383539 58205d31 203a3031
[   24.200016] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[   24.200762] 492c  74617473 36203a65 30303030 0a356331 30303030 72656e0a 7570635f 0a30203a
[   24.201509] 494c  30303030 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   24.202254] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   24.203002]
[   24.203002] X13: 0xffffff80898f4867:
[   24.203442] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204187] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204933] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.205676] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206417] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207160] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207900] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   24.208642] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   24.209382] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   24.210125]
[   24.210125] X16: 0xffffff80081edddc:
[   24.210565] dddc  34fff777 91020260 97fffc1f 17ffffb8 f9403720 b4fffa40 aa1903e0 94073e42
[   24.211313] ddfc  17ffffcf 52800017 17fffff4 12800034 17ffffaf 12800014 17ffffb3 128002b4
[   24.212062] de1c  17ffffb1 12800114 17ffffb3 12800114 17fffe82 71000aff 54fff420 71000eff
[   24.212808] de3c  54fff640 12800214 710006ff 54ffef40 17fffea8 b5fff3f6 f94057a0 17fffe6d
[   24.213555] de5c  a9b57bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0103fa
[   24.214301] de7c  aa0203f8 aa0003f4 aa0303f3 aa1e03e0 d503201f 51000701 321f67e0 6b00003f
[   24.215048] de9c  54001708 d5384101 937c7f00 f9400422 aa1a03e1 ab000021 fa423022 9a9f87e3
[   24.215797] debc  b4001643 2a1403e0 97ff6a02 f90037a0 f27ef415 540015e0 f94016a1 f0006e60
[   24.216544]
[   24.216544] X19: 0xffffff8009697f80:
[   24.216985] 7f80  ******** ******** ******** ******** ******** ******** ******** ********
[   24.217729] 7fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218472] 7fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219215] 7fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219958] 8000  ******** ******** ******** ******** ******** ******** ******** ********
[   24.220702] 8020  ******** ******** ******** ******** ******** ******** ******** ********
[   24.221447] 8040  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222190] 8060  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222936]
[   24.222936] X20: 0xffffff8009698258:
[   24.223376] 8258  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224120] 8278  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224862] 8298  ******** ******** ******** ******** ******** ******** ******** ********
[   24.225607] 82b8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226348] 82d8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227088] 82f8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227831] 8318  ******** ******** ******** ******** ******** ******** ******** ********
[   24.228575] 8338  ******** ******** ******** ******** ******** ******** ******** ********
[   24.229320]
[   24.229320] X21: 0xffffff80096d5f80:
[   24.229761] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.230505] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231250] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231996] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232745] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.233491] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234236] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234981] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.235728]
[   24.235728] X24: 0xffffffc0f32abd20:
[   24.236168] bd20  00000000 00000004 00000004 00000000 00000000 00000000 0000007e 00000000
[   24.236915] bd40  000000f6 00000000 000000f6 00000000 000000f6 00000000 000007cb 00000000
[   24.237660] bd60  000003e1 00000000 00000001 00000001 09894e00 ffffff80 0000001e 00000000
[   24.238405] bd80  f7f49dd7 ffffffc0 00000000 00000000 098952c0 ffffff80 ee8aa000 00000040
[   24.239151] bda0  f7f46180 ffffffc0 ee8aa000 00000040 f7f46180 ffffffc0 f32abeb0 ffffffc0
[   24.239896] bdc0  ffffffff 00ffffff 289b0eda 00000000 0000b602 00000000 00000000 00000000
[   24.240644] bde0  f32abf50 ffffffc0 00000000 00000000 000009a0 00000000 00000474 00000000
[   24.241390] be00  0000011d 00000000 00000001 00000003 00000004 00000000 00000000 00000000
[   24.242137]
[   24.242137] X25: 0xffffffc0f7f421f8:
[   24.242578] 21f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7f42210 ffffffc0
[   24.243323] 2218  f7f42210 ffffffc0 f7f42220 ffffffc0 f7f42220 ffffffc0 0812b194 ffffff80
[   24.244068] 2238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[   24.244813] 2258  00000001 00000000 00000006 00000000 00000005 00000000 f3326c00 ffffffc0
[   24.245558] 2278  f7f42278 ffffffc0 00000000 00000000 00000000 00000000 9a443dc0 00000005
[   24.246304] 2298  9a443dc0 00000005 0812c5a8 ffffff80 f7f41c80 ffffffc0 00000000 0000001f
[   24.247049] 22b8  0812c57c ffffff80 63746177 676f6468 0000352f 00000000 00000000 00000000
[   24.247796] 22d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   24.248544]
[   24.248544] X26: 0xffffff80096981e0:
[   24.248985] 81e0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249728] 8200  ******** ******** ******** ******** ******** ******** ******** ********
[   24.250469] 8220  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251214] 8240  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251954] 8260  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252697] 8280  ******** ******** ******** ******** ******** ******** ******** ********
[   24.253443] 82a0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254186] 82c0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254931]
[   24.254931] X27: 0xffffff80096d76a0:
[   24.255372] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[   24.256118] 76c0  00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[   24.256862] 76e0  00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[   24.257611] 7700  00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[   24.258358] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[   24.259104] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[   24.259849] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[   24.260596] 7780  0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[   24.261343]
[   24.261343] X29: 0xffffffc0f7f3fd70:
[   24.261783] fd70  00000000 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.262532] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.263279] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.264024] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.264770] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.265517] fe10  9a444064 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000003 00000000
[   24.266262] fe30  098a07b8 ffffff80 9a444064 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.267010] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.267756]
[   24.267890] ---[ end trace e4addd7b1b7d3dfd ]---
[   24.268293] Call trace:
[   24.268510] Exception stack(0xffffffc0f7f3fc10 to 0xffffffc0f7f3fd40)
[   24.269072] fc00:                                   ffffff8009698000 0000008000000000
[   24.269754] fc20: ffffffc0f7f3fdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[   24.270435] fc40: 0000000000000026 0000000000000000 ffffffc0f7f3fcf0 ffffff80080edb74
[   24.271117] fc60: ffffffc0f7f3fd70 ffffff800937898b ffffff80096d6000 0000000000000000
[   24.271797] fc80: 0000000000000000 ffffffc0f32abda0 ffffffc0f7f42278 ffffff8009698260
[   24.272479] fca0: ffffff80096d7720 0000000000000000 0000000000000001 ffffff8009692000
[   24.273160] fcc0: 0000000000000026 0000000000000005 00000040ee8aa000 00000040ee8aa000
[   24.273842] fce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[   24.274523] fd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   24.275205] fd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   24.275888] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[   24.276398] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[   24.276929] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[   24.277433] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[   24.277973] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[   24.278519] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[   24.279021] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[   24.279531] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   24.280009] Exception stack(0xffffffc0f32abda0 to 0xffffffc0f32abed0)
[   24.280571] bda0: ffffffc0f7f46180 00000040ee8aa000 ffffffc0f7f46180 ffffffc0f32abeb0
[   24.281253] bdc0: 00ffffffffffffff 00000000289b0eda 000000000000b602 0000000000000000
[   24.281935] bde0: ffffffc0f32abf50 0000000000000000 00000000000009a0 0000000000000474
[   24.282615] be00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   24.283297] be20: ffffff80081ede5c 0000000000000000 0000000000000000 000000059a443e1d
[   24.283979] be40: 0000000000000000 ffffffc0f1eeb600 0000000000000000 ffffff80098a0ce0
[   24.284660] be60: 0000000000000000 000000059a350fe2 ffffff800983def0 0000000001193244
[   24.285342] be80: 0000000000000000 ffffffc0f32abed0 ffffff8008c43ccc ffffffc0f32abed0
[   24.286023] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f32abed0 ffffff8008c43ccc
[   24.286704] bec0: ffffffffffffffff 0000000000000000
[   24.287131] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   24.287560] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   24.288084] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   24.288548] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   24.289003] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   24.289512] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   24.290058] [<0000000001193188>] 0x1193188
[   24.818093] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   24.818624] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   26.809088] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   26.809609] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   27.810086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   27.810609] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[   28.811087] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   28.811610] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[   29.812086] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[   29.812608] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
This is an IBM br10i SAS card.  I flashed it to IT mode, still no joy.  This is the 4th card I've tried to use, the only success I've had is on a single SAS 4 port card.  Anyone know what's going on?  Thanks
Flashing success:
   LSI Corporation SAS FLASH Utility.
   SASFlash Version 1.24.00.00 (2009.11.13)
   Copyright (c) 2006-2007 LSI Corporation. All rights reserved.
       Advanced Mode Set
       Adapter Selected is a LSI SAS 1068E(B3):
       Executing Operation: Flash Firmware Image
               Checksum Passed: 00000000
               Verifying NVDATA Compatibility. . .
               NVDATA Versions Compatible
               Product ID and Vendor ID do not match.
               Would you like to flash anyway [y/n]? y
               Valid BootLoader Image verified.
               Flashing IT Firmware over IR Firmware!
               Beginning Firmware Download
               Firmware Download: SUCCESSFUL!
               Verifying the image flashed correctly. . .
               Firmware Flash: SUCCESSFUL!
               Resetting Adapter:
               Adapter Successfully reset.
       Executing Operation: Flash BIOS Image
               Validating BIOS Image. . .
               BIOS Header Signature Valid.
               BIOS Image compatible with the SAS Controller.
               Attempting to Flash BIOS Image. . .
               BIOS Flash: SUCCESSFUL!
Finished Processing Commands Successfully.
       Exiting SASFlash.
Serial boot messages:
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
OUT
CPUId = 0x0
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
StorageInit ok = 44107
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
INFO:    SPSR = 0x3c9
PreSerial: 2
DRAM:  3.9 GiB
Sysmem: init
I2c speed: 400000Hz
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
PartType: DOS
boot mode: None
 aplll 816000 KHz
 apllb 24000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
Scanning mmc 1:1...
1: ROCKPRO
reading /Image
25612296 bytes read in 2716 ms (9 MiB/s)
96363 bytes read in 14 ms (6.6 MiB/s)
Total: 3851.25 ms
Starting kernel ...
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Started Save/Restore Sound Card State.
[    2.644852] Internal error: : 96000210 [#1] SMP
[    2.645259] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[    2.646056] CPU: 1 PID: 49 Comm: kworker/u12:1 Not tainted 4.4.180 #1
[    2.646619] Hardware name: Pine64 RockPro64 (DT)
[    2.647036] Workqueue: deferwq deferred_probe_work_func
[    2.647498] task: ffffffc0f2bbb600 task.stack: ffffffc0f2518000
[    2.648022] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    2.648472] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    2.648923] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    2.649567] sp : ffffffc0f251b7e0
[    2.649860] x29: ffffffc0f251b7e0 x28: 0000000000000000
[    2.650331] x27: 0000000000000001 x26: 0000000000000000
[    2.650803] x25: 0000000000000000 x24: ffffffc0f0976800
[    2.651276] x23: 0000000000000000 x22: 0000000000000004
[    2.651748] x21: ffffffc0f0b85c28 x20: ffffffc0f251b86c
[    2.652219] x19: ffffff8014100000 x18: 0000000000000005
[    2.652691] x17: 0000000000000000 x16: ffffff80081ede5c
[    2.653163] x15: 0000000000000000 x14: 000000000000000a
[    2.653635] x13: ffffff80898f48e7 x12: 0000000000000030
[    2.654106] x11: 0000000000000006 x10: ffffff80098f48ef
[    2.654578] x9 : 0000000005f5e0ff x8 : 756220676e696e6e
[    2.655051] x7 : 616373203a31303a x6 : ffffff80098f4914
[    2.655523] x5 : ffffff80084a10bc x4 : 0000000000000000
[    2.655994] x3 : 000000000000000b x2 : 0000000000000800
[    2.656466] x1 : ffffff8012c00008 x0 : ffffff8014000000
[    2.656940]
[    2.656940] PC: 0xffffff80084a11a0:
[    2.657375] 11a0  54fffd01 39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[    2.658127] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[    2.658878] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[    2.659630] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[    2.660383] 1220  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[    2.661133] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[    2.661884] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[    2.662637] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[    2.663389]
[    2.663389] LR: 0xffffff80084a1190:
[    2.663823] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[    2.664576] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[    2.665329] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[    2.666082] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[    2.666835] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[    2.667586] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[    2.668336] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[    2.669087] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[    2.669841]
[    2.669841] SP: 0xffffffc0f251b760:
[    2.670276] b760  00000004 00000000 00000000 00000000 f0976800 ffffffc0 00000000 00000000
[    2.671027] b780  00000000 00000000 00000001 00000000 00000000 00000000 f251b7e0 ffffffc0
[    2.671777] b7a0  084a1210 ffffff80 f251b7e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[    2.672528] b7c0  00100000 00000000 f251b86c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[    2.673280] b7e0  f251b820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 f0976800 ffffffc0
[    2.674031] b800  00000000 00000000 00000140 00000000 f251b8ec ffffffc0 00000000 00000000
[    2.674782] b820  f251b870 ffffffc0 0848210c ffffff80 f251b8ec ffffffc0 f0976800 ffffffc0
[    2.675535] b840  f0976800 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[    2.676289]
[    2.676289] X0: 0xffffff8013ffff80:
[    2.676724] ff80  ******** ******** ******** ******** ******** ******** ******** ********
[    2.677481] ffa0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.678231] ffc0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.678984] ffe0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.679738] 0000
[    2.679897] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[    3.502125] failed to power up DHD generic adapter, 1 retry left
[    3.518206] wifi_platform_set_power = 0
[    3.518551] ======== PULL WL_REG_ON(-1) LOW! ========
[    3.518994] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    3.519441] [WLAN_RFKILL]: wifi shut off power.
[    3.519842] wifi_platform_bus_enumerate device present 0
[    3.520328] ======== Card detection to remove SDIO card! ========
[    3.520862] sdio: host isn't  initialization successfully.
[    3.521411] wifi_platform_set_power = 1
[    3.521749] ======== PULL WL_REG_ON(-1) HIGH! ========
[    3.522225] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    3.522638] [WLAN_RFKILL]: wifi turn on power. -1
[    3.823119] wifi_platform_bus_enumerate device present 1
[    3.823588] ======== Card detection to detect SDIO card! ========
[    3.824135] sdio: host isn't  initialization successfully.
[    3.966103] vendor storage:20160801 ret = -1
[    5.824107] failed to power up DHD generic adapter, 0 retry left
[    5.840370] wifi_platform_set_power = 0
[    5.840708] ======== PULL WL_REG_ON(-1) LOW! ========
[    5.841164] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    5.841576] [WLAN_RFKILL]: wifi shut off power.
[    5.841972] wifi_platform_bus_enumerate device present 0
[    5.842440] ======== Card detection to remove SDIO card! ========
[    5.842971] sdio: host isn't  initialization successfully.
[    5.843452] failed to power up DHD generic adapter, max retry reached**
[    5.844107] unregister wifi platform drivers
[    5.844482] wifi_platform_bus_enumerate device present 0
[    5.844944] ======== Card detection to remove SDIO card! ========
[    5.845486] sdio: host isn't  initialization successfully.
[    5.845966] ======== dhd_wlan_deinit_plat_data ========
[    5.846432] dhd_module_init: Failed to load the driver, try cnt 0
[    5.846983] dhd_module_init: Failed to load driver max retry reached**
[    5.847559] dhd_module_init: Exit err=-19
[    6.406178] random: nonblocking pool is initialized
[    9.680722] BUG: spinlock lockup suspected on CPU#1, kworker/u12:1/49
[    9.681297]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:1/49, .owner_cpu: 1
[    9.682065] CPU: 1 PID: 49 Comm: kworker/u12:1 Not tainted 4.4.180 #1
[    9.682628] Hardware name: Pine64 RockPro64 (DT)
[    9.683039] Workqueue: deferwq deferred_probe_work_func
[    9.683501] Call trace:
[    9.683725] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[    9.684200] [<ffffff80080883e8>] show_stack+0x24/0x30
[    9.684647] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[    9.685093] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[    9.685530] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[    9.686030] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[    9.686565] [<ffffff8008088428>] die+0x34/0x1b4
[    9.686964] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.687453] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.687867] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.688326] Exception stack(0xffffffc0f251b240 to 0xffffffc0f251b370)
[    9.688891] b240: ffffffc0f2bbb600 0000008000000000 ffffffc0f251b410 ffffff8008422884
[    9.689576] b260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[    9.690261] b280: ffffff80098f5148 0000000000000000 ffffffc0f251b2b0 ffffff80080eda14
[    9.690945] b2a0: 0000000000000005 0000000000000000 ffffffc0f251b350 ffffff80080edb74
[    9.691630] b2c0: ffffffc0f251b3d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[    9.692314] b2e0: ffffffc0f251b49c ffffff8014000000 0000000000000004 00000040ee856000
[    9.692999] b300: 0000000000000002 ffffffc0f251b4a0 ffffffc0f251b49c 00000000ffffffff
[    9.693683] b320: ffffff800990ff77 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[    9.694366] b340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[    9.695050] b360: ffffff80081ede5c 0000000000000000
[    9.695479] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.695894] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[    9.696422] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[    9.696888] [<ffffff80080884ac>] die+0xb8/0x1b4
[    9.697287] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.697775] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.698188] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.698646] Exception stack(0xffffffc0f251b610 to 0xffffffc0f251b740)
[    9.699210] b600:                                   ffffff8014100000 0000008000000000
[    9.699894] b620: ffffffc0f251b7e0 ffffff80084a1220 ffffffc0f0976920 000000000000006e
[    9.700577] b640: ffffffc0f251b7f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[    9.701262] b660: ffffffc0f251b752 0000000000000000 ffffffc0f251b680 ffffff8009692000
[    9.701947] b680: 0000000000000140 00000000093c1b86 ffffffc0f251b860 ffffffc0f251b860
[    9.702632] b6a0: ffffffc0f251b830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[    9.703316] b6c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[    9.704001] b6e0: ffffff80098f4914 616373203a31303a 756220676e696e6e 0000000005f5e0ff
[    9.704685] b700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[    9.705369] b720: 000000000000000a 0000000000000000 ffffff80081ede5c 0000000000000000
[    9.706053] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.706470] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[    9.707028] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[    9.707593] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[    9.708127] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[    9.708594] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[    9.709105] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[    9.709602] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[    9.710121] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[    9.710648] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[    9.711145] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[    9.711723] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[    9.712252] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[    9.712757] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[    9.713284] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[    9.713819] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[    9.714308] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[    9.714797] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[    9.715316] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[    9.715805] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[    9.716356] [<ffffff80080b2350>] process_one_work+0x224/0x368
[    9.716861] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[    9.717345] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[    9.717767] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[   24.154098] Watchdog detected hard LOCKUP on cpu 1
[   24.154513] ------------[ cut here ]------------
[   24.154936] WARNING: at kernel/watchdog.c:352
[   24.155318] Modules linked in: midgard_kbase phy_rockchip_pcie dw_hdmi_i2s_audio rockchip_saradc
[   24.156107]
[   24.156243] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.180 #1
[   24.156768] Hardware name: Pine64 RockPro64 (DT)
[   24.157173] task: ffffff80096de2d0 task.stack: ffffff80096d0000
[   24.157696] PC is at watchdog_timer_fn+0x190/0x2e8
[   24.158118] LR is at watchdog_timer_fn+0x190/0x2e8
[   24.158539] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[   24.159184] sp : ffffffc0f7ed6df0
[   24.159476] x29: ffffffc0f7ed6df0 x28: 0000000000000001
[   24.159948] x27: ffffff80096d7720 x26: ffffff8009698260
[   24.160420] x25: ffffffc0f7ed9278 x24: ffffff80096d3d70
[   24.160893] x23: 0000000000000000 x22: 0000000000000012
[   24.161365] x21: ffffff80096d6000 x20: ffffff80096982d8
[   24.161837] x19: ffffff8009698000 x18: 0000000000000005
[   24.162308] x17: 0000000000000000 x16: ffffff80081ede5c
[   24.162780] x15: 0000000000000000 x14: 000000000000000a
[   24.163252] x13: ffffff80898f48e7 x12: 0000000000000030
[   24.163723] x11: 0000000000000006 x10: ffffff80098f48ef
[   24.164195] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[   24.164666] x7 : 6574636574656420 x6 : ffffff80098f491d
[   24.165138] x5 : 00000000fffffffe x4 : 0000000000000002
[   24.165610] x3 : 00000040ee841000 x2 : 00000040ee841000
[   24.166081] x1 : 0000000000000000 x0 : 0000000000000026
[   24.166554]
[   24.166554] PC: 0xffffff800812c6b8:
[   24.166988] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.167742] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.168495] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.169248] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.169998] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.170751] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.171503] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.172255] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.173007]
[   24.173007] LR: 0xffffff800812c6b8:
[   24.173442] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.174193] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.174943] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.175696] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.176449] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.177200] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.177953] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.178706] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.179458]
[   24.179458] SP: 0xffffffc0f7ed6d70:
[   24.179893] 6d70  00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0
[   24.180645] 6d90  09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6df0 ffffffc0
[   24.181397] 6db0  0812c738 ffffff80 f7ed6df0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.182149] 6dd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.182899] 6df0  f7ed6e60 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0
[   24.183650] 6e10  9a167c3f 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000
[   24.184403] 6e30  098a07b8 ffffff80 9a167c3f 00000005 0812c5a8 ffffff80 096de2d0 ffffff80
[   24.185155] 6e50  f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6ed0 ffffffc0 081036e8 ffffff80
[   24.185908]
[   24.185908] X6: 0xffffff80098f489d:
[   24.186343] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.187094] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.187847] 48dc  00000000 00000001 00000000 30303020 32303330 34383730 34205d37 20636438
[   24.188598] 48fc  312e3432 30393538 58205d38 30203a36 66666678 38666666 38393030 39383466
[   24.189351] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[   24.190104] 493c  30303030 72656e0a 7570635f 0a31203a 30303030 6c6c750a 625b2029 30207375
[   24.190857] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[   24.191607] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[   24.192360] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[   24.193113]
[   24.193113] X10: 0xffffff80098f486f:
[   24.193556] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.194308] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.195058] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.195807] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   24.196559] 48ec  312e3432 35353632 34205d39 20636538 312e3432 31313339 58205d33 203a3031
[   24.197310] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[   24.198063] 492c  74617473 36203a65 30303030 0a356331 30303030 72656e0a 7570635f 0a31203a
[   24.198813] 494c  30303030 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   24.199563] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   24.200316]
[   24.200316] X13: 0xffffff80898f4867:
[   24.200759] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   24.201514] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   24.202266] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.203018] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.203770] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204523] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   24.205275] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206028] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206781] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207536]
[   24.207536] X16: 0xffffff80081edddc:
[   24.207978] dddc  34fff777 91020260 97fffc1f 17ffffb8 f9403720 b4fffa40 aa1903e0 94073e42
[   24.208731] ddfc  17ffffcf 52800017 17fffff4 12800034 17ffffaf 12800014 17ffffb3 128002b4
[   24.209484] de1c  17ffffb1 12800114 17ffffb3 12800114 17fffe82 71000aff 54fff420 71000eff
[   24.210236] de3c  54fff640 12800214 710006ff 54ffef40 17fffea8 b5fff3f6 f94057a0 17fffe6d
[   24.210986] de5c  a9b57bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0103fa
[   24.211738] de7c  aa0203f8 aa0003f4 aa0303f3 aa1e03e0 d503201f 51000701 321f67e0 6b00003f
[   24.212490] de9c  54001708 d5384101 937c7f00 f9400422 aa1a03e1 ab000021 fa423022 9a9f87e3
[   24.213240] debc  b4001643 2a1403e0 97ff6a02 f90037a0 f27ef415 540015e0 f94016a1 f0006e60
[   24.213994]
[   24.213994] X19: 0xffffff8009697f80:
[   24.214436] 7f80  ******** ******** ******** ******** ******** ******** ******** ********
[   24.215191] 7fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.215947] 7fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.216701] 7fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.217455] 8000  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218208] 8020  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218960] 8040  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219713] 8060  ******** ******** ******** ******** ******** ******** ******** ********
[   24.220469]
[   24.220469] X20: 0xffffff8009698258:
[   24.220911] 8258  ******** ******** ******** ******** ******** ******** ******** ********
[   24.221665] 8278  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222416] 8298  ******** ******** ******** ******** ******** ******** ******** ********
[   24.223169] 82b8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.223920] 82d8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224675] 82f8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.225429] 8318  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226183] 8338  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226938]
[   24.226938] X21: 0xffffff80096d5f80:
[   24.227380] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.228132] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.228882] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.229631] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.230383] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231132] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231882] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232634] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.233385]
[   24.233385] X24: 0xffffff80096d3cf0:
[   24.233828] 3cf0  00000000 00000000 00000000 00000000 00000000 00000000 000003c6 00000000
[   24.234581] 3d10  0000041f 00000000 0000041f 00000000 0000041f 00000000 0000045e 00000000
[   24.235332] 3d30  0000020f 00000000 00000001 00000003 00000004 00000000 00000000 00000000
[   24.236084] 3d50  096d3e60 ffffff80 080d9950 ffffff80 f7edd180 ffffffc0 096de2d0 ffffff80
[   24.236836] 3d70  f7edd180 ffffffc0 ee841000 00000040 f7edd180 ffffffc0 096d3e80 ffffff80
[   24.237588] 3d90  ffffffff 00ffffff 289eba50 00000000 0000ba24 00000000 00000000 00000000
[   24.238341] 3db0  096d3f20 ffffff80 00000000 00000000 000009a0 00000000 00000107 00000000
[   24.239092] 3dd0  0000011d 00000000 00000001 00000000 00000001 00000000 00000000 00000000
[   24.239844]
[   24.239844] X25: 0xffffffc0f7ed91f8:
[   24.240287] 91f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7ed9210 ffffffc0
[   24.241039] 9218  f7ed9210 ffffffc0 f7ed9220 ffffffc0 f7ed9220 ffffffc0 0812b194 ffffff80
[   24.241792] 9238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[   24.242542] 9258  00000001 00000000 00000006 00000000 00000005 00000000 f3288000 ffffffc0
[   24.243294] 9278  f7ed9278 ffffffc0 00000000 00000000 00000000 00000000 9a167700 00000005
[   24.244044] 9298  9a167700 00000005 0812c5a8 ffffff80 f7ed8c80 ffffffc0 00000000 0000000a
[   24.244795] 92b8  0812c57c ffffff80 63746177 676f6468 0000302f 00000000 00000000 00000000
[   24.245548] 92d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   24.246299]
[   24.246299] X26: 0xffffff80096981e0:
[   24.246741] 81e0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.247493] 8200  ******** ******** ******** ******** ******** ******** ******** ********
[   24.248247] 8220  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249000] 8240  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249753] 8260  ******** ******** ******** ******** ******** ******** ******** ********
[   24.250505] 8280  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251258] 82a0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252012] 82c0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252766]
[   24.252766] X27: 0xffffff80096d76a0:
[   24.253209] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[   24.253961] 76c0  00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[   24.254711] 76e0  00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[   24.255461] 7700  00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[   24.256213] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[   24.256966] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[   24.257717] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[   24.258470] 7780  0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[   24.259225]
[   24.259225] X29: 0xffffffc0f7ed6d70:
[   24.259667] 6d70  00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0
[   24.260419] 6d90  09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6df0 ffffffc0
[   24.261172] 6db0  0812c738 ffffff80 f7ed6df0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.261924] 6dd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.262674] 6df0  f7ed6e60 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0
[   24.263426] 6e10  9a167c3f 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000
[   24.264177] 6e30  098a07b8 ffffff80 9a167c3f 00000005 0812c5a8 ffffff80 096de2d0 ffffff80
[   24.264930] 6e50  f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6ed0 ffffffc0 081036e8 ffffff80
[   24.265681]
[   24.265816] ---[ end trace 3d3b6a56b1496ce2 ]---
[   24.266220] Call trace:
[   24.266439] Exception stack(0xffffffc0f7ed6c10 to 0xffffffc0f7ed6d40)
[   24.267003] 6c00:                                   ffffff8009698000 0000008000000000
[   24.267688] 6c20: ffffffc0f7ed6df0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[   24.268371] 6c40: 0000000000000026 0000000000000000 ffffffc0f7ed6cf0 ffffff80080edb74
[   24.269055] 6c60: ffffffc0f7ed6d70 ffffff800937898b ffffff80096d6000 0000000000000012
[   24.269740] 6c80: 0000000000000000 ffffff80096d3d70 ffffffc0f7ed9278 ffffff8009698260
[   24.270425] 6ca0: ffffff80096d7720 0000000000000001 0000000000000001 ffffff8009692000
[   24.271109] 6cc0: 0000000000000026 0000000000000000 00000040ee841000 00000040ee841000
[   24.271794] 6ce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[   24.272478] 6d00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   24.273162] 6d20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   24.273848] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[   24.274363] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[   24.274897] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[   24.275405] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[   24.275950] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[   24.276499] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[   24.277004] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[   24.277516] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   24.277996] Exception stack(0xffffff80096d3d70 to 0xffffff80096d3ea0)
[   24.278560] 3d60:                                   ffffffc0f7edd180 00000040ee841000
[   24.279245] 3d80: ffffffc0f7edd180 ffffff80096d3e80 00ffffffffffffff 00000000289eba50
[   24.279930] 3da0: 000000000000ba24 0000000000000000 ffffff80096d3f20 0000000000000000
[   24.280614] 3dc0: 00000000000009a0 0000000000000107 000000000000011d 0000000000000001
[   24.281298] 3de0: 0000000000000001 0000000000000000 ffffff80081ede5c 0000000000000000
[   24.281982] 3e00: 0000000000000000 000000059a1678d4 0000000000000000 ffffffc0f1d67400
[   24.282666] 3e20: 0000000000000000 ffffff80098a0ce0 0000000000000000 000000059a07472e
[   24.283351] 3e40: ffffff800983def0 000000000119323c 00000000017a001c ffffff80096d3ea0
[   24.284035] 3e60: ffffff8008c43ccc ffffff80096d3ea0 ffffff8008c43d00 0000000060000145
[   24.284720] 3e80: ffffff80096d3ea0 ffffff8008c43ccc ffffffffffffffff 0000000000000000
[   24.285404] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   24.285837] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   24.286364] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   24.286831] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   24.287289] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   24.287801] [<ffffff8008f8cdd0>] rest_init+0x74/0x7c
[   24.288238] [<ffffff80095a0bcc>] start_kernel+0x3d8/0x3fc
[   24.288712] [<ffffff80095a01c4>] __primary_switched+0x30/0x6c
In the log you presented, the following two failed at the initial stage of device detection.
This is almost equivalent to the absence of the card itself, and the kernel does nothing after that.
That is why the kernel did not crash.
https://forum.pine64.org/showthread.php?tid=8091
"EVGA geforce GT 730 P / N 01G-P3-2730-KR dmesg"
[3.347302] rockchip-pcie f8000000.pcie: PCIe link training gen1 timed out.
"Asus Hyper M.2 X4 dmesg"
[3.290551] rockchip-pcie f8000000.pcie: PCIe link training gen1 timed out.
Next is about the crash log you presented.
Other than you, there are quite a few reports of crashes in equivalent places.
It may be the same cause.
I do n’t know if a workaround exists,
It is recommended that you increase the loglevel and compare with other reports.
(* The log that you presented does not show what was executed before the crash because the loglevel is low)
https://forum.pine64.org/showthread.php?tid=8161
[3.240205] PC is at rockchip_pcie_rd_conf + 0x164 / 0x1b4
[3.240656] LR is at rockchip_pcie_rd_conf + 0x154 / 0x1b4
Thanks for the reply.  I changed loglevel to 6 and got a new capture.  Not really sure where to go from here, what should I look into to work on this?  I think the synchronous external abort errors are the problem, but I don't know how to troubleshoot further.
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 249
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
FwPartOffset=2000 , 0
StorageInit ok = 44119
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xd35dc
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  3.9 GiB
Sysmem: init
Relocation Offset is: f5bfa000
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
               DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled
               DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
                LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
             SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled
                  dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
              vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)
       vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
          vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
        vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, disabled | suspend     -61uV, enabling
              vcc5v0-sys@     vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
   vcc12v-pcie-regulator@    vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV
             vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)
MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   serial
Err:   serial
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Bootdev(atags): mmc 1
PartType: DOS
get part misc fail -1
boot mode: None
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
 aplll 816000 KHz
 apllb 24000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
 aclk_perihp 133333 KHz
 hclk_perihp 66666 KHz
 pclk_perihp 33333 KHz
 aclk_perilp0 266666 KHz
 hclk_perilp0 88888 KHz
 pclk_perilp0 44444 KHz
 hclk_perilp1 100000 KHz
 pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
load_android_image: Can't find part: boot
Android boot failed, error -1.
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
415 bytes read in 5 ms (81.1 KiB/s)
1: ROCKPRO
Retrieving file: /Image
reading /Image
25612296 bytes read in 2715 ms (9 MiB/s)
append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current loglevel=6
Retrieving file: /rk3399-rockpro64.dtb
reading /rk3399-rockpro64.dtb
## Flattened Device Tree blob at 08300000
  Booting using the fdt blob at 0x8300000
  Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 3855.951 ms
Starting kernel ...
[    0.000000] Linux version 4.4.180 (adam@adam-vb) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08) ) #1 SMP Fri May 31 17:07:08 EDT 2019
[    0.000000] Kernel command line: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current loglevel=6 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff80095a0000 - 0xffffff80096d0000   (  1216 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008fa0000   ( 15488 KB)
[    0.000000]     .rodata : 0xffffff8008fa0000 - 0xffffff80095a0000   (  6144 KB)
[    0.000000]       .data : 0xffffff80096d0000 - 0xffffff80098ed008   (  2165 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.561441] vcc1v8_sdio: regulator get failed, ret=-517
[    0.562255] vcc1v8_wifi: regulator get failed, ret=-517
[    0.563788] vcc1v8_pcie: regulator get failed, ret=-517
[    0.567385] SCSI subsystem initialized
[    0.613045] FS-Cache: Loaded
[    0.622128] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.630946] Initialise system trusted keyring
[    0.640281] NFS: Registering the id_resolver key type
[    0.640770] Key type id_resolver registered
[    0.641169] Key type id_legacy registered
[    0.648596] Key type asymmetric registered
[    0.648997] Asymmetric key parser 'x509' registered
[    0.651188] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[    0.659057] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    0.660920] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    0.662507] rk-vcodec ff660000.rkvdec: could not find power_model node
[    0.678062] Unable to detect cache hierarchy for CPU 0
[    0.686608] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    0.762386] Rockchip WiFi SYS interface (V1.00) ...
[    0.764740] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    0.769651] rockchip-dwc3 usb1: fail to get drvdata hcd
[    0.854095] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.854708] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.876095] fusb302 4-0022: Can't get property of role, set role to default DRP
[    0.893635] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    0.909152] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    0.966849] Bridge firewalling registered
[    0.968723] Key type dns_resolver registered
[    0.969742] Registered cp15_barrier emulation handler
[    0.970393] Registered setend emulation handler
[    0.971502] Loading compiled-in X.509 certificates
[    0.973582] phy phy-ff770000.syscon:usb2-phy@e450.5: Failed to get VBUS supply regulator
[    0.982074] rockchip-drm display-subsystem: failed to parse loader memory
[    1.033346] xhci-hcd xhci-hcd.7.auto: Host not halted after 16000 microseconds.
[    1.033986] xhci-hcd xhci-hcd.7.auto: Host controller not halted, aborting reset.
[    1.233980] es8316 1-0011: ASoC: Failed to create Left Hp mixer debugfs file
[    1.234648] es8316 1-0011: ASoC: Failed to create Right Hp mixer debugfs file
[    1.235291] es8316 1-0011: ASoC: Failed to create HPCP L debugfs file
[    1.235859] es8316 1-0011: ASoC: Failed to create HPCP R debugfs file
[    1.236441] es8316 1-0011: ASoC: Failed to create HPVOL L debugfs file
[    1.237022] es8316 1-0011: ASoC: Failed to create HPVOL R debugfs file
[    1.239778] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0
[    1.240417] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
[    1.241043] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22
[    1.241788] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
[    1.242576] asoc-simple-card: probe of spdif-sound failed with error -22
[    1.245744] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r)
[    1.246403] ======== dhd_wlan_init_plat_data ========
[    1.246854] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1
[    1.247377] dhd_wlan_init_gpio: oob_irq=70, oob_irq_flags=0x414
[    1.247892] dhd_wifi_platform_load: Enter
[    1.248272] Power-up adapter 'DHD generic adapter'
[    1.257835] wifi_platform_set_power = 1
[    1.258193] ======== PULL WL_REG_ON(-1) HIGH! ========
[    1.364978] mmcblk0: error -5 transferring data, sector 530000, nr 144, cmd response 0x900, card status 0xb00
[    1.365888] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    1.381049] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[    1.559174] wifi_platform_bus_enumerate device present 1
[    1.559651] ======== Card detection to detect SDIO card! ========
[    1.560284] sdio: host isn't  initialization successfully.
[    1.574774] mmc0: tried to reset card
[    1.718534] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    1.726303] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[    1.728821] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[    1.755350] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.756698] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.761148] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[    1.762126] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[    1.803783] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.804752] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.805807] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.807036] random: systemd: uninitialized urandom read (16 bytes read, 61 bits of entropy available)
[    1.902435] systemd[1]: Configuration file /lib/systemd/system/partition-bootup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    1.913114] systemd[1]: Starting of Arbitrary Executable File Formats File System Automount Point not supported.
[UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Created slice System Slice.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on Journal Socket.
        Starting Remount Root and Kernel File Systems...
        Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
        Mounting POSIX Message Queue File System...
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote File Systems.
        Starting Restore / save the current clock...
[  OK  ] Created slice system-serial\x2dgetty.slice.
        Starting Load Kernel Modules...
[  OK  ] Listening on Syslog Socket.
        Starting Journal Service...
        Mounting Debug File System...
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted Debug File System.
        Mounting Configuration File System...
        Starting Apply Kernel Variables...
        Mounting FUSE Control File System...
        Starting Create Static Device Nodes in /dev...
        Starting udev Coldplug all Devices...
        Starting Load/Save Random Seed...
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Static Device Nodes in /dev.
        Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
        Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Journal Service.
        Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
        Starting Create Volatile Files and Directories...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Reached target System Time Synchronized.
        Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target Sound Card.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
[    2.354308] ff100000.saradc supply vref not found, using dummy regulator
[    2.407705] rockchip-pcie f8000000.pcie: missing optional "memory-region" property
[    2.408388] rockchip-pcie f8000000.pcie: missing optional "rockchip,dma_trx_enabled" property
[    2.409140] rockchip-pcie f8000000.pcie: missing optional "rockchip,deferred" property
        Starting LSB: IPv4 DHCP client with IPv4LL support...
        Starting Login Service...
        Starting System Logging Service...
[  OK  ] Started Boot and Home Patition Mount Service.
        Starting LSB: Starts and stops Wicd...
        Starting Save/Restore Sound Card State...
[  OK  ] Started Regular background program processing daemon.
        Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started System Logging Service.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Network.
        Starting OpenBSD Secure Shell server...
        Starting Permit User Sessions...
[  OK  ] Reached target Network is Online.
        Starting LSB: Start NTP daemon...
        Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started LSB: IPv4 DHCP client with IPv4LL support.
[  OK  ] Started LSB: Start NTP daemon.
[    2.788438] FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[  OK  ] Started OpenBSD Secure Shell server.
[    2.935464] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014100000
[    2.936278] Internal error: : 96000210 [#1] SMP
[    2.936679] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[    2.937479] CPU: 0 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[    2.938050] Hardware name: Pine64 RockPro64 (DT)
[    2.938469] Workqueue: deferwq deferred_probe_work_func
[    2.938931] task: ffffffc0f1c23600 task.stack: ffffffc0f1564000
[    2.939460] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    2.939911] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    2.940363] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    2.941007] sp : ffffffc0f15677e0
[    2.941300] x29: ffffffc0f15677e0 x28: 0000000000000000
[    2.941773] x27: 0000000000000001 x26: 0000000000000000
[    2.942245] x25: 0000000000000000 x24: ffffffc0ef61d000
[    2.942717] x23: 0000000000000000 x22: 0000000000000004
[    2.943190] x21: ffffffc0f14f9028 x20: ffffffc0f156786c
[    2.943661] x19: ffffff8014100000 x18: 0000000000000005
[    2.944133] x17: 0000000000000000 x16: 0000000000000000
[    2.944605] x15: 0000000000000000 x14: 000000000000000a
[    2.945080] x13: ffffff80898f48e7 x12: 0000000000000030
[    2.945565] x11: 0000000000000006 x10: ffffff80098f48ef
[    2.946037] x9 : 0000000005f5e0ff x8 : 6e696e6e61637320
[    2.946509] x7 : 3a31303a30303030 x6 : ffffff80098f4914
[    2.946982] x5 : ffffff80084a10bc x4 : 0000000000000000
[    2.947454] x3 : 000000000000000b x2 : 0000000000000800
[    2.947925] x1 : ffffff8012c00008 x0 : ffffff8014000000
[    2.948399]
[    2.948399] PC: 0xffffff80084a11a0:
[    2.948836] 11a0  54fffd01[    2.949003] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency
[    2.949639]  39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[    2.950296] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[    2.951049] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[    2.951802] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[    2.952555] 1220  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[    2.953307] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[    2.954057] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[    2.954808] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[    2.955564]
[    2.955564] LR: 0xffffff80084a1190:
[    2.955999] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[    2.956750] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[    2.957503] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[    2.958253] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[    2.959004] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[    2.959754] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[    2.960508] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[    2.961260] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[    2.962012]
[    2.962012] SP: 0xffffffc0f1567760:
[    2.962447] 7760  00000004 00000000 00000000 00000000 ef61d000 ffffffc0 00000000 00000000
[    2.963198] 7780  00000000 00000000 00000001 00000000 00000000 00000000 f15677e0 ffffffc0
[    2.963949] 77a0  084a1210 ffffff80 f15677e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[    2.964703] 77c0  00100000 00000000 f156786c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[    2.965455] 77e0  f1567820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 ef61d000 ffffffc0
[    2.966206] 7800  00000000 00000000 00000140 00000000 f15678ec ffffffc0 00000000 00000000
[    2.966957] 7820  f1567870 ffffffc0 0848210c ffffff80 f15678ec ffffffc0 ef61d000 ffffffc0
[    2.967710] 7840  ef61d000 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[    2.968462]
[    2.968462] X0: 0xffffff8013ffff80:
[    2.968897] ff80  ******** ******** ******** ******** ******** ******** ******** ********
[    2.969652] ffa0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.970406] ffc0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.971157] ffe0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.971912] 0000
[    2.972071] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[    3.976000] vendor storage:20160801 ret = -1
[    4.491076] random: nonblocking pool is initialized
[    9.972895] BUG: spinlock lockup suspected on CPU#0, kworker/u12:3/159
[    9.973475]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:3/159, .owner_cpu: 0
[    9.974251] CPU: 0 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[    9.974820] Hardware name: Pine64 RockPro64 (DT)
[    9.975233] Workqueue: deferwq deferred_probe_work_func
[    9.975693] Call trace:
[    9.975918] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[    9.976394] [<ffffff80080883e8>] show_stack+0x24/0x30
[    9.976840] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[    9.977287] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[    9.977724] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[    9.978225] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[    9.978759] [<ffffff8008088428>] die+0x34/0x1b4
[    9.979160] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.979650] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.980065] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.980525] Exception stack(0xffffffc0f1567240 to 0xffffffc0f1567370)
[    9.981090] 7240: ffffffc0f1c23600 0000008000000000 ffffffc0f1567410 ffffff8008422884
[    9.981774] 7260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[    9.982459] 7280: ffffff80098f5148 0000000000000000 ffffffc0f15672b0 ffffff80080eda14
[    9.983144] 72a0: 0000000000000005 0000000000000000 ffffffc0f1567350 ffffff80080edb74
[    9.983829] 72c0: ffffffc0f15673d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[    9.984513] 72e0: ffffffc0f156749c ffffff8014000000 0000000000000004 00000040ee841000
[    9.985198] 7300: 0000000000000002 ffffffc0f15674a0 ffffffc0f156749c 00000000ffffffff
[    9.985881] 7320: ffffff800991039f 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[    9.986565] 7340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[    9.987249] 7360: 0000000000000000 0000000000000000
[    9.987679] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.988094] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[    9.988621] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[    9.989087] [<ffffff80080884ac>] die+0xb8/0x1b4
[    9.989487] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.989975] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.990389] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.990846] Exception stack(0xffffffc0f1567610 to 0xffffffc0f1567740)
[    9.991410] 7600:                                   ffffff8014100000 0000008000000000
[    9.992095] 7620: ffffffc0f15677e0 ffffff80084a1220 ffffffc0ef61d120 000000000000006e
[    9.992779] 7640: ffffffc0f15677f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[    9.993464] 7660: ffffffc0f1567752 0000000000000000 ffffffc0f1567680 ffffff8009692000
[    9.994149] 7680: 0000000000000140 00000000093c1b86 ffffffc0f1567860 ffffffc0f1567860
[    9.994833] 76a0: ffffffc0f1567830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[    9.995517] 76c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[    9.996202] 76e0: ffffff80098f4914 3a31303a30303030 6e696e6e61637320 0000000005f5e0ff
[    9.996887] 7700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[    9.997571] 7720: 000000000000000a 0000000000000000 0000000000000000 0000000000000000
[    9.998255] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.998671] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[    9.999229] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[    9.999794] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[   10.000329] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[   10.000795] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[   10.001308] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[   10.001804] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[   10.002325] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[   10.002852] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[   10.003350] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[   10.003929] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[   10.004457] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[   10.004962] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[   10.005489] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[   10.006024] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[   10.006513] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[   10.007002] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[   10.007523] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[   10.008012] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[   10.008563] [<ffffff80080b2350>] process_one_work+0x224/0x368
[   10.009068] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[   10.009552] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[   10.009974] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[   12.797988] NETDEV WATCHDOG: eth0 (rk_gmac-dwmac): transmit queue 0 timed out
[   12.798640] ------------[ cut here ]------------
[   12.799044] WARNING: at net/sched/sch_generic.c:306
[   12.799469] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[   12.800252]
[   12.800388] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.180 #1
[   12.800911] Hardware name: Pine64 RockPro64 (DT)
[   12.801314] task: ffffffc0f328b600 task.stack: ffffffc0f32a4000
[   12.801838] PC is at dev_watchdog+0x1a0/0x238
[   12.802220] LR is at dev_watchdog+0x1a0/0x238
[   12.802601] pc : [<ffffff8008d9ecac>] lr : [<ffffff8008d9ecac>] pstate: 00000145
[   12.803243] sp : ffffffc0f7f2adf0
[   12.803534] x29: ffffffc0f7f2adf0 x28: 0000000000000000
[   12.804004] x27: dead000000000200 x26: 00000000ffffffff
[   12.804473] x25: 0000000000000180 x24: 0000000000000004
[   12.804942] x23: ffffffc0f1d93280 x22: ffffff800989f000
[   12.805411] x21: ffffffc0f25523e0 x20: 0000000000000000
[   12.805879] x19: ffffffc0f2552000 x18: 0000000000000005
[   12.806349] x17: 0000000000000000 x16: ffffff80081ede5c
[   12.806818] x15: 0000000000000000 x14: 000000000000000a
[   12.807287] x13: ffffff80898f48e7 x12: 0000000000000030
[   12.807756] x11: 0000000000000006 x10: ffffff80098f48ef
[   12.808225] x9 : 0000000005f5e0ff x8 : 756575712074696d
[   12.808693] x7 : 736e617274203a29 x6 : ffffff80098f4938
[   12.809163] x5 : 0000000000000000 x4 : 0000000000000000
[   12.809632] x3 : 0000000000000000 x2 : ffffffc0f7f2e348
[   12.810101] x1 : 00000040ee895000 x0 : 0000000000000041
[   12.810570]
[   12.810570] PC: 0xffffff8008d9ec2c:
[   12.811003] ec2c  f9402661 3607fa61 f9402661 721e003f 54fffa01 52800014 f00049a4 f9405001
[   12.811750] ec4c  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[   12.812500] ec6c  ab01007f 540002e5 f9405401 b0005816 91000421 f9005401 3971eac0 35000180
[   12.813245] ec8c  aa1303e0 97ff81a4 2a1403e3 aa0003e2 aa1303e1 b0003ae0 9120e800 97cf092d
[   12.813990] ecac  d4210000 52800020 3931eac0 f9410260 f9403801 aa1303e0 d63f0020 14000005
[   12.814735] eccc  11000694 91060000 6b02029f 54fffb81 b983fa61 f00049a0 f940e000 8b000020
[   12.815479] ecec  97cd837d aa0003e1 91104260 97cd8c4e 35fff400 d538d081 f9423260 8b010000
[   12.816227] ed0c  885f7c03 11000463 88027c03 35ffffa2 17ffff98 f941e276 52800040 9bb75a96
[   12.816973]
[   12.816973] LR: 0xffffff8008d9ec2c:
[   12.817406] ec2c  f9402661 3607fa61 f9402661 721e003f 54fffa01 52800014 f00049a4 f9405001
[   12.818151] ec4c  b5000041 f9420661 f9405803 f240047f 54000380 f940e085 b983fa63 cb050063
[   12.818898] ec6c  ab01007f 540002e5 f9405401 b0005816 91000421 f9005401 3971eac0 35000180
[   12.819643] ec8c  aa1303e0 97ff81a4 2a1403e3 aa0003e2 aa1303e1 b0003ae0 9120e800 97cf092d
[   12.820387] ecac  d4210000 52800020 3931eac0 f9410260 f9403801 aa1303e0 d63f0020 14000005
[   12.821130] eccc  11000694 91060000 6b02029f 54fffb81 b983fa61 f00049a0 f940e000 8b000020
[   12.821875] ecec  97cd837d aa0003e1 91104260 97cd8c4e 35fff400 d538d081 f9423260 8b010000
[   12.822620] ed0c  885f7c03 11000463 88027c03 35ffffa2 17ffff98 f941e276 52800040 9bb75a96
[   12.823368]
[   12.823368] SP: 0xffffffc0f7f2ad70:
[   12.823801] ad70  0989f000 ffffff80 f1d93280 ffffffc0 00000004 00000000 00000180 00000000
[   12.824550] ad90  ffffffff 00000000 00000200 dead0000 00000000 00000000 f7f2adf0 ffffffc0
[   12.825295] adb0  08d9ecac ffffff80 f7f2adf0 ffffffc0 08d9ecac ffffff80 00000145 00000000
[   12.826040] add0  096d5000 ffffff80 fffb9dc1 00000000 00000000 00000080 0000000f 00000000
[   12.826785] adf0  f7f2ae40 ffffffc0 081013bc ffffff80 f7f2bb80 ffffffc0 098a0000 ffffff80
[   12.827533] ae10  00000100 00000000 08d9eb0c ffffff80 f2552410 ffffffc0 f2552000 ffffffc0
[   12.828279] ae30  08d9eb0c ffffff80 f2552000 ffffffc0 f7f2ae80 ffffffc0 081016dc ffffff80
[   12.829023] ae50  f7f2bb80 ffffffc0 f2552410 ffffffc0 00000002 00000000 096d5000 ffffff80
[   12.829769]
[   12.829769] X2: 0xffffffc0f7f2e2c8:
[   12.830201] e2c8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.830946] e2e8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.831687] e308  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.832433] e328  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.833181] e348  f7f2bb40 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[   12.833926] e368  00000001 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[   12.834668] e388  f7f2e388 ffffffc0 f7f2e388 ffffffc0 00000000 00000000 00000000 00000000
[   12.835415] e3a8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.836162]
[   12.836162] X6: 0xffffff80098f48b8:
[   12.836595] 48b8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.837343] 48d8  00000000 00000000 00000001 00000000 30303020 32303330 34333730 34205d33
[   12.838088] 48f8  20386638 382e3231 36313633 58205d32 30203a36 66666678 38666666 38393030
[   12.838833] 4918  62383466 300a3a38 39643830 63616365 70205d3e 74617473 30203a65 30303030
[   12.839576] 4938  0a353431 30303030 656e770a 70635f72 30203a75 3030300a 6c6c750a 625b2029
[   12.840322] 4958  30207375 66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e
[   12.841067] 4978  7020676e 7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e
[   12.841814] 4998  4c422b20 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29
[   12.842560]
[   12.842560] X10: 0xffffff80098f486f:
[   12.843000] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.843745] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.844490] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.845236] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   12.845984] 48ec  382e3231 38393531 34205d34 20636538 382e3231 36353234 58205d30 203a3031
[   12.846729] 490c  66667830 66666666 39303038 38346638 0a3a6636 39643830 63616365 70205d3e
[   12.847474] 492c  74617473 30203a65 30303030 0a353431 30303030 656e770a 70635f72 30203a75
[   12.848219] 494c  3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   12.848967] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   12.849713]
[   12.849713] X13: 0xffffff80898f4867:
[   12.850153] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   12.850899] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   12.851643] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.852389] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.853133] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   12.853879] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   12.854625] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   12.855374] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   12.856117] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   12.856866]
[   12.856866] X16: 0xffffff80081edddc:
[   12.857306] dddc  34fff777 91020260 97fffc1f 17ffffb8 f9403720 b4fffa40 aa1903e0 94073e42
[   12.858053] ddfc  17ffffcf 52800017 17fffff4 12800034 17ffffaf 12800014 17ffffb3 128002b4
[   12.858797] de1c  17ffffb1 12800114 17ffffb3 12800114 17fffe82 71000aff 54fff420 71000eff
[   12.859542] de3c  54fff640 12800214 710006ff 54ffef40 17fffea8 b5fff3f6 f94057a0 17fffe6d
[   12.860289] de5c  a9b57bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0103fa
[   12.861036] de7c  aa0203f8 aa0003f4 aa0303f3 aa1e03e0 d503201f 51000701 321f67e0 6b00003f
[   12.861779] de9c  54001708 d5384101 937c7f00 f9400422 aa1a03e1 ab000021 fa423022 9a9f87e3
[   12.862524] debc  b4001643 2a1403e0 97ff6a02 f90037a0 f27ef415 540015e0 f94016a1 f0006e60
[   12.863268]
[   12.863268] X19: 0xffffffc0f2551f80:
[   12.863709] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.864454] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.865200] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.865948] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.866693] 2000  30687465 00000000 00000000 00000000 00000000 00000000 f2488788 ffffffc0
[   12.867438] 2020  00000000 00000000 00000000 00000000 00000000 00000000 09be0000 ffffff80
[   12.868183] 2040  00000018 00000000 00000003 00000000 0986c7d0 ffffff80 f241c050 ffffffc0
[   12.868931] 2060  f2552a58 ffffffc0 f2552a58 ffffffc0 f2552070 ffffffc0 f2552070 ffffffc0
[   12.869678]
[   12.869678] X21: 0xffffffc0f2552360:
[   12.870118] 2360  f2552358 ffffffc0 ffffffff 0000ffff 00000000 00000000 00000000 00000000
[   12.870863] 2380  00000000 00000000 00000000 00000000 00000000 00000000 f2488810 ffffffc0
[   12.871608] 23a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.872355] 23c0  f1d93200 ffffffc0 00000001 00000001 ef5d0400 ffffffc0 000003e8 00000000
[   12.873102] 23e0  00020001 dead4ead 00000004 00000000 f328b600 ffffffc0 00001388 00000000
[   12.873847] 2400  00000000 00000000 fffb7634 00000000 00000200 dead0000 00000000 00000000
[   12.874592] 2420  fffb9dc0 00000000 08d9eb0c ffffff80 f2552000 ffffffc0 00000004 ffffffff
[   12.875337] 2440  ffffffff 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.876086]
[   12.876086] X22: 0xffffff800989ef80:
[   12.876526] ef80  095fb674 ffffff80 00000000 00000000 f24a5de0 ffffffc0 f24a5d80 ffffffc0
[   12.877271] efa0  0814848c ffffff80 09227288 ffffff80 08f69988 ffffff80 08f69824 ffffff80
[   12.878017] efc0  08148724 ffffff80 095fb504 ffffff80 00000000 00000000 f24a5f60 ffffffc0
[   12.878763] efe0  f24a5e10 ffffffc0 0814848c ffffff80 09227288 ffffff80 08f67204 ffffff80
[   12.879508] f000  08f65ba4 ffffff80 08148724 ffffff80 095fb440 ffffff80 00000000 00000000
[   12.880254] f020  f24a6030 ffffffc0 f24a5f90 ffffffc0 0814848c ffffff80 09227288 ffffff80
[   12.880998] f040  08f67150 ffffff80 08f65abc ffffff80 08148724 ffffff80 095fda18 ffffff80
[   12.881743] f060  00000000 00000000 f24a60f0 ffffffc0 f24a6060 ffffffc0 0814848c ffffff80
[   12.882488]
[   12.882488] X23: 0xffffffc0f1d93200:
[   12.882929] 3200  f2552000 ffffffc0 ef5d0400 ffffffc0 ef5d0400 ffffffc0 f1e1ffc0 ffffffc0
[   12.883676] 3220  f1e1a780 ffffffc0 f1e1a598 ffffffc0 f1e1a7a8 ffffffc0 f1e1a780 ffffffc0
[   12.884423] 3240  0986ef70 ffffff80 f1e24528 ffffffc0 00000001 00000007 00000000 00000000
[   12.885171] 3260  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.885917] 3280  000b000b dead4ead ffffffff 00000000 ffffffff ffffffff ffffffff 00000000
[   12.886662] 32a0  fffb7d86 00000000 00000001 00000000 00000006 00000000 00000000 00000000
[   12.887407] 32c0  00000439 00000408 0000005a 00000000 00000000 00000000 00000000 00000000
[   12.888153] 32e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.888903]
[   12.888903] X29: 0xffffffc0f7f2ad70:
[   12.889343] ad70  0989f000 ffffff80 f1d93280 ffffffc0 00000004 00000000 00000180 00000000
[   12.890089] ad90  ffffffff 00000000 00000200 dead0000 00000000 00000000 f7f2adf0 ffffffc0
[   12.890833] adb0  08d9ecac ffffff80 f7f2adf0 ffffffc0 08d9ecac ffffff80 00000145 00000000
[   12.891578] add0  096d5000 ffffff80 fffb9dc1 00000000 00000000 00000080 0000000f 00000000
[   12.892321] adf0  f7f2ae40 ffffffc0 081013bc ffffff80 f7f2bb80 ffffffc0 098a0000 ffffff80
[   12.893067] ae10  00000100 00000000 08d9eb0c ffffff80 f2552410 ffffffc0 f2552000 ffffffc0
[   12.893815] ae30  08d9eb0c ffffff80 f2552000 ffffffc0 f7f2ae80 ffffffc0 081016dc ffffff80
[   12.894560] ae50  f7f2bb80 ffffffc0 f2552410 ffffffc0 00000002 00000000 096d5000 ffffff80
[   12.895305]
[   12.895438] ---[ end trace 7582a5e8f3421942 ]---
[   12.895841] Call trace:
[   12.896057] Exception stack(0xffffffc0f7f2ac10 to 0xffffffc0f7f2ad40)
[   12.896618] ac00:                                   ffffffc0f2552000 0000008000000000
[   12.897300] ac20: ffffffc0f7f2adf0 ffffff8008d9ecac 0000000000000145 000000060001a23c
[   12.897980] ac40: 0000000000000000 0000000100000000 ffffffc0f7f2acf0 ffffff80080edb74
[   12.898660] ac60: ffffffc0f7f2ad70 ffffff80094fb83a ffffffc0f25523e0 ffffff800989f000
[   12.899342] ac80: ffffffc0f1d93280 0000000000000004 0000000000000180 00000000ffffffff
[   12.900023] aca0: dead000000000200 0000000000000000 0000000000000001 ffffff8009692000
[   12.900705] acc0: 0000000000000041 00000040ee895000 ffffffc0f7f2e348 0000000000000000
[   12.901386] ace0: 0000000000000000 0000000000000000 ffffff80098f4938 736e617274203a29
[   12.902067] ad00: 756575712074696d 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   12.902748] ad20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   12.903432] [<ffffff8008d9ecac>] dev_watchdog+0x1a0/0x238
[   12.903905] [<ffffff80081013bc>] call_timer_fn+0x9c/0x158
[   12.904376] [<ffffff80081016dc>] run_timer_softirq+0x238/0x244
[   12.904886] [<ffffff8008081180>] __do_softirq+0x250/0x300
[   12.905358] [<ffffff800809ffa0>] irq_exit+0x8c/0xd8
[   12.905785] [<ffffff80080eeb44>] __handle_domain_irq+0x84/0xb8
[   12.906292] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   12.906769] Exception stack(0xffffffc0f32a7da0 to 0xffffffc0f32a7ed0)
[   12.907331] 7da0: ffffffc0f7f31180 00000040ee895000 ffffffc0f7f31180 ffffffc0f32a7eb0
[   12.908012] 7dc0: 00ffffffffffffff 0000000018661874 0000000000005ff8 0000000000000000
[   12.908693] 7de0: ffffffc0f32a7f50 0000000000000000 00000000000009a0 0000000000000474
[   12.909375] 7e00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   12.910056] 7e20: ffffff80081ede5c 0000000000000000 0000000000000000 00000002f537a858
[   12.910737] 7e40: 0000000000000000 ffffffc0f1f7a400 0000000000000000 ffffff80098a0ce0
[   12.911419] 7e60: 0000000000000000 00000002f528758e ffffff800983def0 0000000001193244
[   12.912100] 7e80: 0000000000000000 ffffffc0f32a7ed0 ffffff8008c43ccc ffffffc0f32a7ed0
[   12.912781] 7ea0: ffffff8008c43d00 0000000060000145 ffffffc0f32a7ed0 ffffff8008c43ccc
[   12.913463] 7ec0: ffffffffffffffff 0000000000000000
[   12.913888] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   12.914317] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   12.914841] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   12.915305] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   12.915760] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   12.916270] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   12.916816] [<0000000001193188>] 0x1193188
[   24.156984] Watchdog detected hard LOCKUP on cpu 0
[   24.157403] ------------[ cut here ]------------
[   24.157824] WARNING: at kernel/watchdog.c:352
[   24.158205] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[   24.158989]
[   24.159125] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G        W       4.4.180 #1
[   24.159754] Hardware name: Pine64 RockPro64 (DT)
[   24.160157] task: ffffffc0f328c380 task.stack: ffffffc0f32a8000
[   24.160683] PC is at watchdog_timer_fn+0x190/0x2e8
[   24.161103] LR is at watchdog_timer_fn+0x190/0x2e8
[   24.161520] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[   24.162163] sp : ffffffc0f7f3fdf0
[   24.162453] x29: ffffffc0f7f3fdf0 x28: 0000000000000000
[   24.162923] x27: ffffff80096d7720 x26: ffffff8009698260
[   24.163393] x25: ffffffc0f7f42278 x24: ffffffc0f32abda0
[   24.163862] x23: 0000000000000000 x22: 0000000000000012
[   24.164331] x21: ffffff80096d6000 x20: ffffff80096982d8
[   24.164799] x19: ffffff8009698000 x18: 0000000000000005
[   24.165268] x17: 0000000000000000 x16: ffffff800811d6d8
[   24.165737] x15: 0000000000000000 x14: 000000000000000a
[   24.166205] x13: ffffff80898f48e7 x12: 0000000000000030
[   24.166674] x11: 0000000000000006 x10: ffffff80098f48ef
[   24.167143] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[   24.167612] x7 : 6574636574656420 x6 : ffffff80098f491d
[   24.168081] x5 : 00000000fffffffe x4 : 0000000000000002
[   24.168549] x3 : 00000040ee8aa000 x2 : 00000040ee8aa000
[   24.169018] x1 : 0000000000000005 x0 : 0000000000000026
[   24.169488]
[   24.169488] PC: 0xffffff800812c6b8:
[   24.169921] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.170669] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.171415] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.172160] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.172905] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.173651] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.174400] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.175144] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.175890]
[   24.175890] LR: 0xffffff800812c6b8:
[   24.176322] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.177066] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.177811] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.178555] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.179303] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.180050] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.180793] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.181538] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.182284]
[   24.182284] SP: 0xffffffc0f7f3fd70:
[   24.182716] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.183461] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.184207] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.184955] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.185700] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.186445] fe10  9a44408e 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000007 00000000
[   24.187190] fe30  098a07b8 ffffff80 9a44408e 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.187932] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.188679]
[   24.188679] X6: 0xffffff80098f489d:
[   24.189111] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.189859] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.190604] 48dc  00000000 00000001 00000000 30303020 32303330 30363030 34205d34 20636438
[   24.191349] 48fc  312e3432 37363838 58205d39 30203a36 66666678 38666666 38393030 39383466
[   24.192092] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[   24.192838] 493c  63636333 656e770a 70635f72 30203a75 3030300a 6c6c750a 625b2029 30207375
[   24.193582] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[   24.194327] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[   24.195075] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[   24.195821]
[   24.195821] X10: 0xffffff80098f486f:
[   24.196261] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197005] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197750] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.198495] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   24.199243] 48ec  312e3432 34323932 34205d33 20636538 312e3432 32383539 58205d31 203a3031
[   24.199989] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[   24.200734] 492c  74617473 36203a65 30303030 0a356331 63636333 656e770a 70635f72 30203a75
[   24.201480] 494c  3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   24.202228] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   24.202976]
[   24.202976] X13: 0xffffff80898f4867:
[   24.203416] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204166] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204912] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.205654] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206394] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207139] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207885] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   24.208630] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   24.209372] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   24.210119]
[   24.210119] X16: 0xffffff800811d658:
[   24.210559] d658  b50000f3 f90002bf 2a1303e0 f94013f5 a94153f3 a8c47bfd d65f03c0 d2800200
[   24.211307] d678  97ffff4e aa0003f4 b5000060 128001b3 17fffff6 aa1303e1 9100c3a0 97fffe03
[   24.212050] d698  2a0003f3 35ffff40 d5384100 f9400401 aa1403e0 b1004000 fa413002 9a9f87e2
[   24.212795] d6b8  b4fffe62 d2800202 9100c3a1 aa1403e0 940c15ae b5fffdc0 f90002b4 17ffffe3
[   24.213541] d6d8  a9bb7bfd 910003fd a90153f3 a9025bf5 aa0003f3 aa0103f4 aa1e03e0 d503201f
[   24.214289] d6f8  aa1303e1 9100c3a0 97fffde8 340000e0 928001b3 aa1303e0 a94153f3 a9425bf5
[   24.215034] d718  a8c57bfd d65f03c0 f9401ba0 b7f804c0 f9401fa1 d2993fe0 f2a77340 eb00003f
[   24.215779] d738  54000428 d5384115 92800000 f94006b6 f90006a0 d503201f f100029f 910103a1
[   24.216524]
[   24.216524] X19: 0xffffff8009697f80:
[   24.216965] 7f80  ******** ******** ******** ******** ******** ******** ******** ********
[   24.217709] 7fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218451] 7fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219198] 7fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219945] 8000  ******** ******** ******** ******** ******** ******** ******** ********
[   24.220691] 8020  ******** ******** ******** ******** ******** ******** ******** ********
[   24.221435] 8040  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222179] 8060  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222923]
[   24.222923] X20: 0xffffff8009698258:
[   24.223364] 8258  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224107] 8278  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224851] 8298  ******** ******** ******** ******** ******** ******** ******** ********
[   24.225600] 82b8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226343] 82d8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227090] 82f8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227834] 8318  ******** ******** ******** ******** ******** ******** ******** ********
[   24.228579] 8338  ******** ******** ******** ******** ******** ******** ******** ********
[   24.229326]
[   24.229326] X21: 0xffffff80096d5f80:
[   24.229767] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.230515] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231260] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232006] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232751] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.233495] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234240] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234985] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.235727]
[   24.235727] X24: 0xffffffc0f32abd20:
[   24.236168] bd20  00000000 00000000 f328c380 ffffffc0 000001c0 00000000 08c6cdb0 ffffff80
[   24.236914] bd40  00000002 00000000 080913c4 ffffff80 f32abd60 ffffffc0 080914b8 ffffff80
[   24.237662] bd60  f32abe70 ffffffc0 08c6d42c ffffff80 f32abdb0 ffffffc0 08cee258 ffffff80
[   24.238407] bd80  f2537210 ffffffc0 f2536e10 ffffffc0 f32abdb0 ffffffc0 08cee2a8 ffffff80
[   24.239152] bda0  f7f46180 ffffffc0 ee8aa000 00000040 f7f46180 ffffffc0 f32abeb0 ffffffc0
[   24.239896] bdc0  ffffffff 00ffffff 28a5e2b4 00000000 0000b8b6 00000000 00000000 00000000
[   24.240644] bde0  f32abf50 ffffffc0 00000000 00000000 000009a0 00000000 00000474 00000000
[   24.241391] be00  0000011d 00000000 00000001 00000003 00000004 00000000 00000000 00000000
[   24.242136]
[   24.242136] X25: 0xffffffc0f7f421f8:
[   24.242577] 21f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7f42210 ffffffc0
[   24.243322] 2218  f7f42210 ffffffc0 f7f42220 ffffffc0 f7f42220 ffffffc0 0812b194 ffffff80
[   24.244067] 2238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[   24.244813] 2258  00000001 00000000 00000006 00000000 00000005 00000000 f3326c00 ffffffc0
[   24.245561] 2278  f7f42278 ffffffc0 f7f420e8 ffffffc0 00000000 00000000 9a443dc0 00000005
[   24.246306] 2298  9a443dc0 00000005 0812c5a8 ffffff80 f7f41c80 ffffffc0 00000000 0000001f
[   24.247051] 22b8  0812c57c ffffff80 63746177 676f6468 0000352f 00000000 00000006 00000000
[   24.247796] 22d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   24.248544]
[   24.248544] X26: 0xffffff80096981e0:
[   24.248985] 81e0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249732] 8200  ******** ******** ******** ******** ******** ******** ******** ********
[   24.250477] 8220  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251222] 8240  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251967] 8260  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252715] 8280  ******** ******** ******** ******** ******** ******** ******** ********
[   24.253456] 82a0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254200] 82c0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254944]
[   24.254944] X27: 0xffffff80096d76a0:
[   24.255385] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51440 ffffffc0
[   24.256129] 76c0  00000015 00000000 f7f51400 ffffffc0 00000001 00000006 00000060 00000000
[   24.256875] 76e0  00015000 00001000 00000001 00000000 f7f51480 ffffffc0 f7f514c0 ffffffc0
[   24.257618] 7700  00000000 00000005 00000010 00000000 f7f51300 ffffffc0 f7ed3000 ffffffc0
[   24.258363] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[   24.259108] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[   24.259853] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[   24.260601] 7780  0001e28c 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[   24.261347]
[   24.261347] X29: 0xffffffc0f7f3fd70:
[   24.261787] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.262532] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.263275] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.264021] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.264769] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.265514] fe10  9a44408e 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000007 00000000
[   24.266259] fe30  098a07b8 ffffff80 9a44408e 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.267004] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.267752]
[   24.267886] ---[ end trace 7582a5e8f3421943 ]---
[   24.268288] Call trace:
[   24.268506] Exception stack(0xffffffc0f7f3fc10 to 0xffffffc0f7f3fd40)
[   24.269067] fc00:                                   ffffff8009698000 0000008000000000
[   24.269749] fc20: ffffffc0f7f3fdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[   24.270430] fc40: 0000000000000026 0000000000000000 ffffffc0f7f3fcf0 ffffff80080edb74
[   24.271111] fc60: ffffffc0f7f3fd70 ffffff800937898b ffffff80096d6000 0000000000000012
[   24.271793] fc80: 0000000000000000 ffffffc0f32abda0 ffffffc0f7f42278 ffffff8009698260
[   24.272474] fca0: ffffff80096d7720 0000000000000000 0000000000000001 ffffff8009692000
[   24.273156] fcc0: 0000000000000026 0000000000000005 00000040ee8aa000 00000040ee8aa000
[   24.273837] fce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[   24.274518] fd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   24.275199] fd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   24.275883] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[   24.276394] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[   24.276925] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[   24.277428] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[   24.277969] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[   24.278515] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[   24.279017] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[   24.279527] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   24.280006] Exception stack(0xffffffc0f32abda0 to 0xffffffc0f32abed0)
[   24.280567] bda0: ffffffc0f7f46180 00000040ee8aa000 ffffffc0f7f46180 ffffffc0f32abeb0
[   24.281248] bdc0: 00ffffffffffffff 0000000028a5e2b4 000000000000b8b6 0000000000000000
[   24.281930] bde0: ffffffc0f32abf50 0000000000000000 00000000000009a0 0000000000000474
[   24.282612] be00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   24.283293] be20: ffffff800811d6d8 0000000000000000 0000000000000000 000000059a443e47
[   24.283973] be40: 0000000000000000 ffffffc0f1f7a600 0000000000000000 ffffff80098a0ce0
[   24.284654] be60: 0000000000000000 000000059a350ca1 ffffff800983def0 0000000001193244
[   24.285336] be80: 0000000000000000 ffffffc0f32abed0 ffffff8008c43ccc ffffffc0f32abed0
[   24.286017] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f32abed0 ffffff8008c43ccc
[   24.286698] bec0: ffffffffffffffff 0000000000000000
[   24.287123] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   24.287552] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   24.288075] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   24.288539] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   24.288994] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   24.289503] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   24.290048] [<0000000001193188>] 0x1193188
Please try with "loglevel=7".
That way, you should get a more detailed log equivalent to the "dmesg" that you presented.
And the points to focus on are the following parts, for example.
Has the crash occurred in the part shown in the example below?
(from "PCIe Gen1 link training completed" to "PCIe probe completed successfully")
[    2.822176] rockchip-pcie f8000000.pcie: PCIe Gen1 link training completed
[    2.822226] rockchip-pcie f8000000.pcie: PCIe Gen2 link training completed!
[    2.822279] PCI host bridge /pcie@f8000000 ranges:
[    2.822295]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    2.822300]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    2.822541] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.822549] pci_bus 0000:00: root bus resource [bus 00-1f]
[    2.822554] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    2.822558] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    2.826504] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[    2.826595] aer 0000:00:00.0:pcie02: service driver aer loaded
[    2.826651] pci 0000:01:00.0: calling nv_msi_ht_cap_quirk_leaf+0x0/0x38
[    2.826722] pci 0000:01:00.1: calling nv_msi_ht_cap_quirk_leaf+0x0/0x38
[    2.826763] rockchip-pcie f8000000.pcie: PCIe probe completed successfully
Very strange, I noticed a login prompt while using loglevel 7.  Was able to login.  I'll see if I can start running some debugging tools.
Edit: had to reboot the card (unplug power) and now there is no login prompt!  The only thing odd to me about this is that the rockpro was sitting plugged in (but powered off) all night, and this was the first boot attempt.  I'm really wondering if there's some sort of power issue here.
Edit 2: leaving it plugged in and powered off for 10 minutes, rockpro now boots to login prompt with the card installed. The controller still isn't recognized in lspci.
.txt   ll7.txt (Size: 90.07 KB / Downloads: 338)
rock@localhost:~$ lspci -vvv
pcilib: Cannot open /sys/bus/pci/devices/0000:00:00.0/config
lspci: Unable to read the standard configuration space header of device 0000:00:00.0
Disabling msi by adding pci=nomsi to kernel boot options makes for a very quiet (no errors) boot, but still no card detected. Did get a PCIe gen 1 training confirmation.
[ 2.336232] rockchip-pcie f8000000.pcie: PCIe asserting reset
[ 2.337168] rockchip-pcie f8000000.pcie: advertising gen2/1 training
[ 2.337785] rockchip-pcie f8000000.pcie: PCIe reset released
[ 2.362277] rockchip-pcie f8000000.pcie: PCIe Gen1 link training completed
rock@localhost:~$ sudo lspci -vvv
00:00.0 PCI bridge: Device 1d87:0100 (prog-if 00 [Normal decode])
Control: I/O- Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 243
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00000000-00000fff
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: 00000000-000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Vector table: BAR=0 offset=00000000
PBA: BAR=0 offset=00000008
Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt+
LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd Off, Power+ Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL+ CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via message ARIFwd+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [274 v1] Transaction Processing Hints
Interrupt vector mode supported
Device specific mode supported
Steering table in TPH capability structure
Kernel driver in use: pcieport
rock@localhost:~$
Well, I might have found the problem. mrfixit's kernel doesn't have SAS support built.
rock@localhost:~$ cat running.config |grep -i sas
CONFIG_SCSI_SAS_ATTRS=m
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_3W_SAS is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_SAS is not set
CONFIG_SCSI_MPT3SAS=m
CONFIG_SCSI_MPT2SAS_MAX_SGE=128
CONFIG_SCSI_MPT3SAS_MAX_SGE=128
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_SND_SOC_STI_SAS is not set
rock@localhost:~$
I don't have the same card as you, but the crash points are the same.
And there are many other similar reports. For example, the report shown below.
https://github.com/ayufan-rock64/linux-build/issues/254
Unfortunately, in my case, using the "wait" insertion method suggested in this thread did not improve the situation.
Next, I would like to express my view on "ll7.txt" that you presented.
The log shows that "Gen1 Training" succeeded, but "Gen2 Training" failed and fell back to "Gen1".
And it crashes right after "pci 0000: 00: 00.0: bridge configuration invalid ([bus 00-00]), reconfiguring".
If it is functioning properly, the vendor ID acquisition should continue after this, but it ended in a crash before that.
[    2.434952] rockchip-pcie f8000000.pcie: PCIe Gen1 link training completed
[    2.935625] rockchip-pcie f8000000.pcie: PCIe link training gen2 timeout, fall back to gen1!
[    2.936458] PCI host bridge /pcie@f8000000 ranges:
[    2.936903]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    2.938606]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    2.939665] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.940277] pci_bus 0000:00: root bus resource [bus 00-1f]
[    2.940763] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    2.941405] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    2.942889] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
--- Crash occurred ---
[    2.943789] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff800c100000
[    2.944600] Internal error: : 96000210 [#1] SMP
[    2.945000] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[    2.945796] CPU: 2 PID: 6 Comm: kworker/u12:0 Not tainted 4.4.180 #1
[    2.946352] Hardware name: Pine64 RockPro64 (DT)
[    2.946771] Workqueue: deferwq deferred_probe_work_func
[    2.947234] task: ffffffc0f3244380 task.stack: ffffffc0f3278000
[    2.947758] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    2.948210] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    2.948661] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    2.949305] sp : ffffffc0f327b7e0
[    2.949598] x29: ffffffc0f327b7e0 x28: 0000000000000000
[    2.950070] x27: 0000000000000001 x26: 0000000000000000
[    2.950542] x25: 0000000000000000 x24: ffffffc0f0d6c800
This is why the card is not detected by sudo lspci -vvv
If "rockchip-pcie f8000000.pcie: PCIe probe completed successfully" is executed correctly,
Even if there is no driver, the card itself is detected by "lspci -vvv".
Like the "PNY Nvidia Quadro lspci -vvv" log you presented.
This is a proposal.
You point out kernel build options.
Therefore, I think that you are at a level where you can easily change "dtb".
First try to limit the number of lanes ("num-lanes")
If there is still no improvement, try limiting the link speed ("max-link-speed")
I hope the situation will improve, even a little.
And the "driver presence" that you point out is after this hurdle has been overcome.
Finally, I will state my view.
My conclusion is that Rockpro64's "PCIE-Express" originally has little margin.
Many people point out that power supply is suspected, but I think this is not correct.
Because, I own three Rockpro64, but all three work differently.
(One unit is unstable, two units operate stably, but performance is different)
Except for Rockpro64, all conditions are the same, so it is not reasonable to doubt the power supply.
Thanks for your input, I got the card to recognize in lspci.  First try was max_link_speed 1 and num_lanes 1, the rockpro booted but lspci was blank.
I changed num-lanes to 4 and now I have lspci output!  Still on link speed 1 though...
Here's the lspci output and dmesg is attached.
01:00.0 SCSI storage controller: LSI Logic / Symbios Logic SAS1068E PCI-Express Fusion-MPT SAS (rev 08)
       Subsystem: IBM SAS1068E PCI-Express Fusion-MPT SAS
       Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
       Region 0: I/O ports at <unassigned> [disabled]
       Region 1: Memory at fa210000 (64-bit, non-prefetchable) [disabled] [size=16K]
       Region 3: Memory at fa200000 (64-bit, non-prefetchable) [disabled] [size=64K]
       [virtual] Expansion ROM at fa000000 [disabled] [size=2M]
       Capabilities: [50] Power Management version 2
               Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
               Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
       Capabilities: [68] Express (v1) Endpoint, MSI 00
               DevCap: MaxPayload 4096 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                       ExtTag+ AttnBtn- AttnInd- PwrInd- RBE- FLReset- SlotPowerLimit 0.000W
               LnkCap: Port #0, Speed 2.5GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
                       ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                       ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
               LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
       Capabilities: [98] MSI: Enable- Count=1/1 Maskable- 64bit+
               Vector table: BAR=1 offset=00002000
               PBA: BAR=1 offset=00003000
       Capabilities: [100 v1] Advanced Error Reporting
               UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
               CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
.txt   dmesg_lanes_4_speed_1.txt (Size: 81.68 KB / Downloads: 396)
(11-14-2019, 12:21 AM)kram0000 Wrote: Thanks for your input, I got the card to recognize in lspci.  First try was max_link_speed 1 and num_lanes 1, the rockpro booted but lspci was blank.
Could you please let me know how did you manage to change number of lines?
I've got the SBC not booting up with the RAID H1110 and suspect the power isn't enough to supply it.
