Any luck using GPIO's ?
Did anybody had any luck using the PI GPIO ?
As far as i can se the GPIO module is not added in the kernel? /sys/class/gpio does not exist..
Is there a way of adding it?
Hey, I'm interested in this topic too. Launched the last Android image (revision 05.05). And launched terminal emulator with root permissions and there is no /sys/class/gpio folder. Did you find out the solution how to use gpio? Also there is a problem with i2c, as I knew the kernel doesn't have an i2c config activated
Sent from my iPhone using Tapatalk
I did not find a solution.. i hope they add it in a release soon.
  GPIO access running Android rddragon888 20 28,821 11-06-2017, 07:18 AM
Last Post: Anvesh Reddy
  How to get control of GPIO pins from Remix? gbjensen 1 2,644 07-31-2016, 11:26 AM
Last Post: Beta
  API for controlling GPIO pins from Android apps Ghost 5 10,147 02-29-2016, 02:54 PM
