No boot with Supermicro AOC-SASLP-MV8 (serial output)
I'm using mrfixit's minimal debian release (v190531) and boot with a cpu lockup.  I hope someone smarter than I am can take a look to see if there's an easy fix, thanks!
Here's the serial output:
¿|²DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 249
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
FwPartOffset=2000 , 0
StorageInit ok = 44043
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xd35dc
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  3.9 GiB
Sysmem: init
Relocation Offset is: f5bfa000
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
               DCDC_REG1@     vdd_center:  750000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, disabled
               DCDC_REG4@        vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG1@     vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG4@         vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
                LDO_REG7@  vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
                LDO_REG8@        vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
             SWITCH_REG2@      vcc3v3_s0:     -61uV <->     -61uV, set       0uV, enabling | suspend     -61uV, disabled
                  dc-12v@         dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vcc-sys@        vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
              vcc3v3-sys@     vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend     -61uV, enabling (ret: -38)
       vcc-phy-regulator@        vcc_phy:     -61uV <->     -61uV, set     -61uV, enabling | suspend     -61uV, enabling
          vcc5v0-host-en@    vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
        vcc5v0-typec0-en@  vcc5v0_typec0:     -61uV <->     -61uV, set     -61uV, disabled | suspend     -61uV, enabling
              vcc5v0-sys@     vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend     -61uV, enabling (ret: -38)
   vcc12v-pcie-regulator@    vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend     -61uV, enabling (ret: -38)
                 vdd_log@        vdd_log:  800000uV <-> 1400000uV, set  900000uV, enabling | suspend     -61uV, enabling ; init  900000uV
             vcc1v8-sdio@    vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend     -61uV, enabling (ret: -38)
MMC:   dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial
Out:   serial
Err:   serial
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Bootdev(atags): mmc 1
PartType: DOS
get part misc fail -1
boot mode: None
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
 aplll 816000 KHz
 apllb 24000 KHz
 dpll 800000 KHz
 cpll 24000 KHz
 gpll 800000 KHz
 npll 600000 KHz
 vpll 24000 KHz
 aclk_perihp 133333 KHz
 hclk_perihp 66666 KHz
 pclk_perihp 33333 KHz
 aclk_perilp0 266666 KHz
 hclk_perilp0 88888 KHz
 pclk_perilp0 44444 KHz
 hclk_perilp1 100000 KHz
 pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
load_android_image: Can't find part: boot
Android boot failed, error -1.
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
404 bytes read in 3 ms (130.9 KiB/s)
1: ROCKPRO
Retrieving file: /Image
reading /Image
25612296 bytes read in 2715 ms (9 MiB/s)
append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current
Retrieving file: /rk3399-rockpro64.dtb
reading /rk3399-rockpro64.dtb
96363 bytes read in 13 ms (7.1 MiB/s)
## Flattened Device Tree blob at 08300000
  Booting using the fdt blob at 0x8300000
  Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 3845.41 ms
Starting kernel ...
[UNSUPP] Starting of Arbitrary Executable Fi
tem Automount Point not supported.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Reached target Swap.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Created slice System Slice.
[  OK  ] Reached target Slices.
[  OK  ] Created slice system-serial\x2dgetty.slice.
        Mounting Debug File System...
        Mounting POSIX Message Queue File System...
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on Journal Socket.
        Starting Remount Root and Kernel File Systems...
        Starting Restore / save the current clock...
        Starting Load Kernel Modules...
        Starting Journal Service...
        Starting Create list of required st
ce nodes for the current kernel...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Paths.
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Create list of required sta
vice nodes for the current kernel.
        Starting Create Static Device Nodes in /dev...
        Mounting FUSE Control File System...
        Starting Apply Kernel Variables...
        Mounting Configuration File System...
        Starting Load/Save Random Seed...
        Starting udev Coldplug all Devices...
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Static Device Nodes in /dev.
        Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
        Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Journal Service.
        Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
        Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
        Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Started Daily apt download activities.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Regular background program processing daemon.
        Starting System Logging Service...
[  OK  ] Started Boot and Home Patition Mount Service.
        Starting Avahi mDNS/DNS-SD Stack...
        Starting Login Service...
        Starting LSB: IPv4 DHCP client with IPv4LL support...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
        Starting LSB: Starts and stops Wicd...
        Starting Save/Restore Sound Card State...
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Timers.
[  OK  ] Started System Logging Service.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started Raise network interfaces.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Network.
        Starting OpenBSD Secure Shell server...
[  OK  ] Reached target Network is Online.
        Starting LSB: Start NTP daemon...
        Starting Permit User Sessions...
[  OK  ] Reached target Sound Card.
[  OK  ] Started Login Service.
        Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started LSB: IPv4 DHCP client with IPv4LL support.
[  OK  ] Started LSB: Start NTP daemon.
[  OK  ] Started OpenBSD Secure Shell server.
[    2.708506] Internal error: : 96000210 [#1] SMP
[    2.708910] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[    2.709708] CPU: 0 PID: 6 Comm: kworker/u12:0 Not tainted 4.4.180 #1
[    2.710264] Hardware name: Pine64 RockPro64 (DT)
[    2.710681] Workqueue: deferwq deferred_probe_work_func
[    2.711143] task: ffffffc0f3244380 task.stack: ffffffc0f3278000
[    2.711667] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[    2.712119] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[    2.712570] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[    2.713214] sp : ffffffc0f327b7e0
[    2.713506] x29: ffffffc0f327b7e0 x28: 0000000000000000
[    2.713979] x27: 0000000000000001 x26: 0000000000000000
[    2.714452] x25: 0000000000000000 x24: ffffffc0f16dd800
[    2.714923] x23: 0000000000000000 x22: 0000000000000004
[    2.715395] x21: ffffffc0eed75a28 x20: ffffffc0f327b86c
[    2.715867] x19: ffffff8014100000 x18: 0000000000000005
[    2.716340] x17: 0000000000000000 x16: ffffff80081ae544
[    2.716811] x15: 0000000000000000 x14: 000000000000000a
[    2.717283] x13: ffffff80898f48e7 x12: 0000000000000030
[    2.717755] x11: 0000000000000006 x10: ffffff80098f48ef
[    2.718227] x9 : 0000000005f5e0ff x8 : 616373203a31303a
[    2.718698] x7 : 3030303020737562 x6 : ffffff80098f4914
[    2.719170] x5 : ffffff80084a10bc x4 : 0000000000000000
[    2.719641] x3 : 000000000000000b x2 : 0000000000000800
[    2.720113] x1 : ffffff8012c00008 x0 : ffffff8014000000
[    2.720586]
[    2.720586] PC: 0xffffff80084a11a0:
[    2.721021] 11a0  54fffd01 39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[    2.721774] 11c0  2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[    2.722525] 11e0  b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[    2.723277] 1200  54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[    2.724031] 1220 [    2.724112] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency
[    2.724763]  b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[    2.725490] 1240  f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[    2.726242] 1260  8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[    2.726993] 1280  aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[    2.727747]
[    2.727747] LR: 0xffffff80084a1190:
[    2.728182] 1190  79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[    2.728933] 11b0  53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[    2.729685] 11d0  f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[    2.730438] 11f0  54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[    2.731189] 1210  710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[    2.731941] 1230  52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[    2.732692] 1250  17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[    2.733443] 1270  a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[    2.734197]
[    2.734197] SP: 0xffffffc0f327b760:
[    2.734632] b760  00000004 00000000 00000000 00000000 f16dd800 ffffffc0 00000000 00000000
[    2.735384] b780  00000000 00000000 00000001 00000000 00000000 00000000 f327b7e0 ffffffc0
[    2.736135] b7a0  084a1210 ffffff80 f327b7e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[    2.736886] b7c0  00100000 00000000 f327b86c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[    2.737638] b7e0  f327b820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 f16dd800 ffffffc0
[    2.738390] b800  00000000 00000000 00000140 00000000 f327b8ec ffffffc0 00000000 00000000
[    2.739140] b820  f327b870 ffffffc0 0848210c ffffff80 f327b8ec ffffffc0 f16dd800 ffffffc0
[    2.739892] b840  f16dd800 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[    2.740644]
[    2.740644] X0: 0xffffff8013ffff80:
[    2.741079] ff80  ******** ******** ******** ******** ******** ******** ******** ********
[    2.741838] ffa0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.742589] ffc0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.743342] ffe0  ******** ******** ******** ******** ******** ******** ******** ********
[    2.744094] 0000
[    2.744252] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[    4.281221] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    4.281767] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    5.282214] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    5.282756] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[    6.283116] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    6.283643] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    7.284114] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    7.284640] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[    8.285118] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    8.285646] rk808-rtc rk808-rtc: Failed to update RTC control: -110
[    9.287118] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x10, state: 1
[    9.287648] rk808-rtc rk808-rtc: Failed to update bits rtc_ctrl: -110
[    9.745077] BUG: spinlock lockup suspected on CPU#0, kworker/u12:0/6
[    9.745641]  lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:0/6, .owner_cpu: 0
[    9.746402] CPU: 0 PID: 6 Comm: kworker/u12:0 Not tainted 4.4.180 #1
[    9.746956] Hardware name: Pine64 RockPro64 (DT)
[    9.747368] Workqueue: deferwq deferred_probe_work_func
[    9.747830] Call trace:
[    9.748054] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[    9.748530] [<ffffff80080883e8>] show_stack+0x24/0x30
[    9.748976] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[    9.749423] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[    9.749860] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[    9.750361] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[    9.750895] [<ffffff8008088428>] die+0x34/0x1b4
[    9.751294] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.751785] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.752199] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.752658] Exception stack(0xffffffc0f327b240 to 0xffffffc0f327b370)
[    9.753223] b240: ffffffc0f3244380 0000008000000000 ffffffc0f327b410 ffffff8008422884
[    9.753907] b260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[    9.754592] b280: ffffff80098f5148 0000000000000000 ffffffc0f327b2b0 ffffff80080eda14
[    9.755275] b2a0: 0000000000000005 0000000000000000 ffffffc0f327b350 ffffff80080edb74
[    9.755960] b2c0: ffffffc0f327b3d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[    9.756644] b2e0: ffffffc0f327b49c ffffff8014000000 0000000000000004 00000040ee841000
[    9.757329] b300: 0000000000000002 ffffffc0f327b4a0 ffffffc0f327b49c 00000000ffffffff
[    9.758013] b320: ffffff800990fd7f 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[    9.758697] b340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[    9.759381] b360: ffffff80081ae544 0000000000000000
[    9.759811] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.760225] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[    9.760753] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[    9.761219] [<ffffff80080884ac>] die+0xb8/0x1b4
[    9.761618] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[    9.762106] [<ffffff8008093324>] do_sea+0x80/0x94
[    9.762519] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[    9.762977] Exception stack(0xffffffc0f327b610 to 0xffffffc0f327b740)
[    9.763541] b600:                                   ffffff8014100000 0000008000000000
[    9.764225] b620: ffffffc0f327b7e0 ffffff80084a1220 ffffffc0f16dd920 000000000000006e
[    9.764910] b640: ffffffc0f327b7f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[    9.765594] b660: ffffffc0f327b752 0000000000000000 ffffffc0f327b680 ffffff8009692000
[    9.766279] b680: 0000000000000140 00000000093c1b86 ffffffc0f327b860 ffffffc0f327b860
[    9.766964] b6a0: ffffffc0f327b830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[    9.767648] b6c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[    9.768333] b6e0: ffffff80098f4914 3030303020737562 616373203a31303a 0000000005f5e0ff
[    9.769018] b700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[    9.769702] b720: 000000000000000a 0000000000000000 ffffff80081ae544 0000000000000000
[    9.770386] [<ffffff80080825cc>] el1_da+0x24/0x84
[    9.770802] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[    9.771360] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[    9.771924] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[    9.772459] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[    9.772925] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[    9.773438] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[    9.773934] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[    9.774455] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[    9.774982] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[    9.775479] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[    9.776058] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[    9.776587] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[    9.777092] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[    9.777619] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[    9.778154] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[    9.778642] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[    9.779132] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[    9.779651] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[    9.780140] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[    9.780691] [<ffffff80080b2350>] process_one_work+0x224/0x368
[    9.781196] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[    9.781679] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[    9.782101] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[   24.157103] Watchdog detected hard LOCKUP on cpu 0
[   24.157517] ------------[ cut here ]------------
[   24.157939] WARNING: at kernel/watchdog.c:352
[   24.158320] Modules linked in: midgard_kbase dw_hdmi_i2s_audio phy_rockchip_pcie rockchip_saradc
[   24.159103]
[   24.159240] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.180 #1
[   24.159763] Hardware name: Pine64 RockPro64 (DT)
[   24.160166] task: ffffffc0f328c380 task.stack: ffffffc0f32a8000
[   24.160690] PC is at watchdog_timer_fn+0x190/0x2e8
[   24.161110] LR is at watchdog_timer_fn+0x190/0x2e8
[   24.161529] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[   24.162172] sp : ffffffc0f7f3fdf0
[   24.162462] x29: ffffffc0f7f3fdf0 x28: 0000000000000000
[   24.162932] x27: ffffff80096d7720 x26: ffffff8009698260
[   24.163400] x25: ffffffc0f7f42278 x24: ffffffc0f32abda0
[   24.163869] x23: 0000000000000000 x22: 0000000000000012
[   24.164338] x21: ffffff80096d6000 x20: ffffff80096982d8
[   24.164807] x19: ffffff8009698000 x18: 0000000000000005
[   24.165276] x17: 0000000000000000 x16: ffffff80081ede5c
[   24.165745] x15: 0000000000000000 x14: 000000000000000a
[   24.166215] x13: ffffff80898f48e7 x12: 0000000000000030
[   24.166684] x11: 0000000000000006 x10: ffffff80098f48ef
[   24.167153] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[   24.167621] x7 : 6574636574656420 x6 : ffffff80098f491d
[   24.168090] x5 : 00000000fffffffe x4 : 0000000000000002
[   24.168559] x3 : 00000040ee8aa000 x2 : 00000040ee8aa000
[   24.169028] x1 : 0000000000000005 x0 : 0000000000000026
[   24.169497]
[   24.169497] PC: 0xffffff800812c6b8:
[   24.169930] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.170674] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.171424] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.172171] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.172917] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.173664] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.174410] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.175160] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.175905]
[   24.175905] LR: 0xffffff800812c6b8:
[   24.176338] c6b8  91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[   24.177083] c6d8  a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[   24.177832] c6f8  f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[   24.178577] c718  91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[   24.179322] c738  d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[   24.180069] c758  b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[   24.180815] c778  6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[   24.181561] c798  d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[   24.182305]
[   24.182305] SP: 0xffffffc0f7f3fd70:
[   24.182738] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.183484] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.184229] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.184973] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.185719] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.186467] fe10  9a444065 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000003 00000000
[   24.187212] fe30  098a07b8 ffffff80 9a444065 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.187957] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.188705]
[   24.188705] X6: 0xffffff80098f489d:
[   24.189137] 489c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.189884] 48bc  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.190632] 48dc  00000000 00000001 00000000 30303020 32303330 33363030 34205d32 20636438
[   24.191377] 48fc  312e3432 30373838 58205d35 30203a36 66666678 38666666 38393030 39383466
[   24.192123] 491c  300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[   24.192870] 493c  30303030 5f72650a 3a757063 300a3020 30303030 6c6c750a 625b2029 30207375
[   24.193612] 495c  66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[   24.194360] 497c  7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[   24.195105] 499c  2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[   24.195853]
[   24.195853] X10: 0xffffff80098f486f:
[   24.196292] 486c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197038] 488c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.197782] 48ac  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.198527] 48cc  00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[   24.199273] 48ec  312e3432 37323932 34205d33 20636538 312e3432 35383539 58205d33 203a3031
[   24.200022] 490c  66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[   24.200769] 492c  74617473 36203a65 30303030 0a356331 30303030 5f72650a 3a757063 300a3020
[   24.201512] 494c  30303030 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[   24.202258] 496c  65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[   24.203009]
[   24.203009] X13: 0xffffff80898f4867:
[   24.203449] 4864  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204198] 4884  ******** ******** ******** ******** ******** ******** ******** ********
[   24.204941] 48a4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.205685] 48c4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.206429] 48e4  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207172] 4904  ******** ******** ******** ******** ******** ******** ******** ********
[   24.207915] 4924  ******** ******** ******** ******** ******** ******** ******** ********
[   24.208657] 4944  ******** ******** ******** ******** ******** ******** ******** ********
[   24.209398] 4964  ******** ******** ******** ******** ******** ******** ******** ********
[   24.210145]
[   24.210145] X16: 0xffffff80081edddc:
[   24.210584] dddc  34fff777 91020260 97fffc1f 17ffffb8 f9403720 b4fffa40 aa1903e0 94073e42
[   24.211329] ddfc  17ffffcf 52800017 17fffff4 12800034 17ffffaf 12800014 17ffffb3 128002b4
[   24.212072] de1c  17ffffb1 12800114 17ffffb3 12800114 17fffe82 71000aff 54fff420 71000eff
[   24.212819] de3c  54fff640 12800214 710006ff 54ffef40 17fffea8 b5fff3f6 f94057a0 17fffe6d
[   24.213565] de5c  a9b57bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0103fa
[   24.214313] de7c  aa0203f8 aa0003f4 aa0303f3 aa1e03e0 d503201f 51000701 321f67e0 6b00003f
[   24.215058] de9c  54001708 d5384101 937c7f00 f9400422 aa1a03e1 ab000021 fa423022 9a9f87e3
[   24.215807] debc  b4001643 2a1403e0 97ff6a02 f90037a0 f27ef415 540015e0 f94016a1 f0006e60
[   24.216555]
[   24.216555] X19: 0xffffff8009697f80:
[   24.216995] 7f80  ******** ******** ******** ******** ******** ******** ******** ********
[   24.217739] 7fa0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.218485] 7fc0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219229] 7fe0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.219971] 8000  ******** ******** ******** ******** ******** ******** ******** ********
[   24.220714] 8020  ******** ******** ******** ******** ******** ******** ******** ********
[   24.221461] 8040  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222206] 8060  ******** ******** ******** ******** ******** ******** ******** ********
[   24.222950]
[   24.222950] X20: 0xffffff8009698258:
[   24.223389] 8258  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224135] 8278  ******** ******** ******** ******** ******** ******** ******** ********
[   24.224879] 8298  ******** ******** ******** ******** ******** ******** ******** ********
[   24.225622] 82b8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.226366] 82d8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227112] 82f8  ******** ******** ******** ******** ******** ******** ******** ********
[   24.227859] 8318  ******** ******** ******** ******** ******** ******** ******** ********
[   24.228603] 8338  ******** ******** ******** ******** ******** ******** ******** ********
[   24.229346]
[   24.229346] X21: 0xffffff80096d5f80:
[   24.229786] 5f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.230531] 5fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.231276] 5fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232024] 5fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.232768] 6000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.233513] 6020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.234258] 6040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.235005] 6060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   24.235753]
[   24.235753] X24: 0xffffffc0f32abd20:
[   24.236193] bd20  00000000 00000000 f328c380 ffffffc0 000001c0 00000000 08c6cdb0 ffffff80
[   24.236940] bd40  00000002 00000000 080913c4 ffffff80 f32abd60 ffffffc0 080914b8 ffffff80
[   24.237685] bd60  f32abe70 ffffffc0 08c6d42c ffffff80 f32abdb0 ffffffc0 08cee258 ffffff80
[   24.238431] bd80  000052a3 00000000 00000005 00000000 ee8aa000 00000040 00400800 00000000
[   24.239180] bda0  f7f46180 ffffffc0 ee8aa000 00000040 f7f46180 ffffffc0 f32abeb0 ffffffc0
[   24.239927] bdc0  ffffffff 00ffffff 289c76bd 00000000 0000b9e6 00000000 00000000 00000000
[   24.240673] bde0  f32abf50 ffffffc0 00000000 00000000 000009a0 00000000 00000474 00000000
[   24.241421] be00  0000011d 00000000 00000001 00000003 00000004 00000000 00000000 00000000
[   24.242168]
[   24.242168] X25: 0xffffffc0f7f421f8:
[   24.242608] 21f8  ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7f42210 ffffffc0
[   24.243352] 2218  f7f42210 ffffffc0 f7f42220 ffffffc0 f7f42220 ffffffc0 0812b194 ffffff80
[   24.244098] 2238  f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[   24.244845] 2258  00000001 00000000 00000006 00000000 00000005 00000000 f3326c00 ffffffc0
[   24.245588] 2278  f7f42278 ffffffc0 f7f420e8 ffffffc0 00000000 00000000 9a443dc0 00000005
[   24.246335] 2298  9a443dc0 00000005 0812c5a8 ffffff80 f7f41c80 ffffffc0 00000000 0000001f
[   24.247081] 22b8  0812c57c ffffff80 63746177 676f6468 0000352f 00000000 00000006 00000000
[   24.247829] 22d8  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[   24.248573]
[   24.248573] X26: 0xffffff80096981e0:
[   24.249013] 81e0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.249757] 8200  ******** ******** ******** ******** ******** ******** ******** ********
[   24.250502] 8220  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251243] 8240  ******** ******** ******** ******** ******** ******** ******** ********
[   24.251988] 8260  ******** ******** ******** ******** ******** ******** ******** ********
[   24.252730] 8280  ******** ******** ******** ******** ******** ******** ******** ********
[   24.253473] 82a0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254216] 82c0  ******** ******** ******** ******** ******** ******** ******** ********
[   24.254960]
[   24.254960] X27: 0xffffff80096d76a0:
[   24.255400] 76a0  00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[   24.256148] 76c0  00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[   24.256895] 76e0  00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[   24.257640] 7700  00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[   24.258386] 7720  ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[   24.259134] 7740  ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[   24.259879] 7760  00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[   24.260625] 7780  0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[   24.261372]
[   24.261372] X29: 0xffffffc0f7f3fd70:
[   24.261813] fd70  00000012 00000000 00000000 00000000 f32abda0 ffffffc0 f7f42278 ffffffc0
[   24.262561] fd90  09698260 ffffff80 096d7720 ffffff80 00000000 00000000 f7f3fdf0 ffffffc0
[   24.263307] fdb0  0812c738 ffffff80 f7f3fdf0 ffffffc0 0812c738 ffffff80 600001c5 00000000
[   24.264054] fdd0  096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[   24.264799] fdf0  f7f3fe60 ffffffc0 08103104 ffffff80 f7f42278 ffffffc0 f7f41c00 ffffffc0
[   24.265546] fe10  9a444065 00000005 f7f41c80 ffffffc0 09692000 ffffff80 00000003 00000000
[   24.266293] fe30  098a07b8 ffffff80 9a444065 00000005 0812c5a8 ffffff80 f328c380 ffffffc0
[   24.267038] fe50  f7f42278 ffffffc0 096d6710 ffffff80 f7f3fed0 ffffffc0 081036e8 ffffff80
[   24.267784]
[   24.267916] ---[ end trace 279e8ad1d901fb9c ]---
[   24.268320] Call trace:
[   24.268536] Exception stack(0xffffffc0f7f3fc10 to 0xffffffc0f7f3fd40)
[   24.269098] fc00:                                   ffffff8009698000 0000008000000000
[   24.269780] fc20: ffffffc0f7f3fdf0 ffffff800812c738 00000000600001c5 ffffff80080eda14
[   24.270461] fc40: 0000000000000026 0000000000000000 ffffffc0f7f3fcf0 ffffff80080edb74
[   24.271143] fc60: ffffffc0f7f3fd70 ffffff800937898b ffffff80096d6000 0000000000000012
[   24.271824] fc80: 0000000000000000 ffffffc0f32abda0 ffffffc0f7f42278 ffffff8009698260
[   24.272506] fca0: ffffff80096d7720 0000000000000000 0000000000000001 ffffff8009692000
[   24.273187] fcc0: 0000000000000026 0000000000000005 00000040ee8aa000 00000040ee8aa000
[   24.273869] fce0: 0000000000000002 00000000fffffffe ffffff80098f491d 6574636574656420
[   24.274550] fd00: 4c20647261682064 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[   24.275231] fd20: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[   24.275914] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[   24.276424] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[   24.276954] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[   24.277458] [<ffffff8008c6def8>] arch_timer_handler_phys+0x38/0x50
[   24.277999] [<ffffff80080f3130>] handle_percpu_devid_irq+0xe8/0x178
[   24.278545] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[   24.279047] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[   24.279557] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[   24.280035] Exception stack(0xffffffc0f32abda0 to 0xffffffc0f32abed0)
[   24.280597] bda0: ffffffc0f7f46180 00000040ee8aa000 ffffffc0f7f46180 ffffffc0f32abeb0
[   24.281279] bdc0: 00ffffffffffffff 00000000289c76bd 000000000000b9e6 0000000000000000
[   24.281960] bde0: ffffffc0f32abf50 0000000000000000 00000000000009a0 0000000000000474
[   24.282640] be00: 000000000000011d 0000000300000001 0000000000000004 0000000000000000
[   24.283322] be20: ffffff80081ede5c 0000000000000000 0000000000000000 000000059a443e1d
[   24.284003] be40: 0000000000000000 ffffffc0f1f54c00 0000000000000000 ffffff80098a0ce0
[   24.284683] be60: 0000000000000000 000000059a3505a1 ffffff800983def0 0000000001193244
[   24.285365] be80: 0000000000000000 ffffffc0f32abed0 ffffff8008c43ccc ffffffc0f32abed0
[   24.286046] bea0: ffffff8008c43d00 0000000060000145 ffffffc0f32abed0 ffffff8008c43ccc
[   24.286727] bec0: ffffffffffffffff 0000000000000000
[   24.287153] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[   24.287582] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[   24.288106] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[   24.288570] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[   24.289025] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[   24.289535] [<ffffff800808c3f8>] secondary_start_kernel+0x194/0x1c0
[   24.290081] [<0000000001193188>] 0x1193188
  No audio on HDMI after u-boot upgrade xlx 2 1,895 11-28-2023, 01:03 PM
  RP64 Won't Boot After Power Down ColPanic_ 10 7,712 06-27-2023, 07:31 AM
Last Post: dkebler
Bug Anyone else's UART RX (serial input) stopped working? pion 1 1,752 04-07-2022, 08:35 PM
Last Post: foresto
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,473 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 4,968 02-17-2021, 11:35 AM
Last Post: dml-pc
  Won't boot with SATA card rjzak 4 5,720 01-09-2021, 05:56 PM
Last Post: kuleszdl
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 2,899 10-20-2020, 12:22 PM
Last Post: xmixahlx
  NAS mods: external serial port and power button foresto 4 6,494 10-04-2020, 11:21 PM
Last Post: zer0sig
  rockpro 64 does not boot up automatically after software reboot rahulsharma 12 13,426 04-17-2020, 09:00 AM
Last Post: pgwipeout
  Tested PCIe cards and output kram0000 5 6,138 10-24-2019, 01:17 PM
Last Post: xalius
