Clarification on Privacy Kill Switches
When ordering the pinebook pro I read to hold down F1/F2/F3 for 10 seconds to kill the wifi/camera/mic. Then in the Sept 2019 blog it was said to use the pine key with F10/F11/F12 to enable the kill switches. However I and not seeing either method work.
I have ran the updating script but it always come back as its all good no updates for you. When I hit Pine key and the F10 I see the lights for the Caps Lock blink twice and when I release the buttons the app menu opens. I don't notice anything happen and I still have wifi. Even after trying the same thing again with the F11 and F12 keys.
Have I missed something?
Exclamation
As far as I know, you need to press the Pine key and hold down either F10, F11 or F12 (not F1/F2/F3) for ten seconds.
I've clarified the privacy switch section: https://wiki.pine64.org/index.php/Pinebo...y_Switches
Thank you for the link. Tested just now and yessir works as described! Thanks for the clarification. Smile
  Did I kill my PBP's board? overlisted 7 7,296 11-12-2020, 03:28 PM
Last Post: overlisted
  Privacy switches not persistent yawnoc 0 1,688 07-16-2020, 12:01 AM
Last Post: yawnoc
  How do the kill switches work? Stevie-O 7 8,929 06-01-2020, 11:34 AM
Last Post: Phillip Bell
  pinebook pro overheats and switches off when streaming leonidas 13 13,873 04-20-2020, 09:05 AM
Last Post: bcnaz
  No Privacy Browser out yet? + my advice pin 2 4,014 04-06-2020, 09:15 PM
Last Post: xmixahlx
Lightbulb Are you like me and can never remember the privacy keys? jabo 2 3,142 03-16-2020, 09:28 PM
Last Post: LittleWalter
