Pinebook battery connector and reuse
Hello all,
Has anyone reused their pinebook battery for other than powering a pinebook?  Mine is in pieces right now, so I'm looking to reuse the parts I can.
Is the connector that the pinebook battery uses easy to acquire on Amazon or other sites online?  Would I have to de-solder the connector from the main board?  I tried to plugin a male end of GPIO jumper cable into one female outputs, but the pin is too thick.
The battery meters at around 4 ish volts, so I will need to boost it to 5 volts to run a raspberry pi.
Any thoughts or suggestions?
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
No suggestions? This is a perfectly good battery, I have a boost transformer to 5 volts already, but I want to be able to charge the battery too. There are 7 wires on this battery, 3 x 4 ish volt lines (red), 1 white (unknown purpose) and 3 ground (black). I looked at the PDF for the battery on the Wiki, but I didn't give me the information I was looking for.
My end goal is to power a raspberry pi 3b+ and an 3.5 display. It is going to be a small retro gaming system with arcade buttons wired into the GPIO pins (I have a pi cape to added extra ground pins and 5 volt and 3.3 volt pins). I'm looking for a UBEC that would work with this battery.
This is one guide I have been looking it:
https://www.instructables.com/id/Make-Yo...hargeable/
(10-17-2019, 10:35 AM)binholz Wrote: No suggestions?  This is a perfectly good battery, I have a boost transformer to 5 volts already, but I want to be able to charge the battery too.  There are 7 wires on this battery, 3 x 4 ish volt lines (red), 1 white (unknown purpose) and 3 ground (black).  I looked at the PDF for the battery on the Wiki, but I didn't give me the information I was looking for.
Try tagging one of the Pine team members, they should be able to help answer your connector question. I'm sure it's not too hard to find, as they seem to have an ease of sourcing in mind for most of their parts. If it is, you could probably find one of the RPi HATs that handles batter power/charging with it.
  Broken display connector Mick 3 377 12-13-2023, 01:47 PM
  pinebook 1080p power/barrel connector/cable cel 0 496 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,321 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,168 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,564 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,216 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,529 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,536 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,507 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,631 08-20-2020, 08:18 AM
Last Post: Reinoud
