Pinebook Pro sound
Music
Is the headphone jack the only possibility (besides BT) to enjoy sound from the Pinebook Pro?
(09-08-2019, 07:38 AM)hdk Wrote: Is the headphone jack the only possibility (besides BT) to enjoy sound from the Pinebook Pro?
Your options are the built in speakers, the headphone jack, Bluetooth devices and USB DACs.
Was there something in particular you were looking for?
Did not know about the built in speakers.
Thank you.
Thank you.
The specs page lists "Stereo speakers" https://www.pine64.org/pinebook-pro/
I just received my Pinebook Pro today I am not getting any sound through the internal speakers or via the headphone jack.
I am running the default MATE debian distro that came with the PBP.
sound hardware is set via the es8316-spk-sound device
Anyone else have this issue or other issues with sound?
(10-31-2019, 02:44 PM)debaser Wrote: I just received my Pinebook Pro today I am not getting any sound through the internal speakers or via the headphone jack.
Some applications (life Chromium) sometimes default to HDMI output ... for some reason. Try looking in the sound settings, under application output, and check if by accident the application isn't set to HDMI.
Thanks for the tip Luke. Unfortunately still no change. No sound through Chromium, Firefox, or Enjoy Music player. I am monitoring sound pref as well and output is still showing set for speakers. Under the Applications tab in Sound it doesn't show any application currently playing a sound or recording either.
(10-31-2019, 06:33 PM)debaser Wrote: Thanks for the tip Luke. Unfortunately still no change. No sound through  Cmium, Firefox, or Enjoy Music player. I am monitoring sound pref as well and output is still showing set for speakers. Under the Applications tab in Sound it doesn't show any application currently playing a sound or recording either.
Are you logged in as root or rock?
Using rock. Everything through sound preferences seems ok to me. Chromium is now showing in the application tab but still no sound.
***EDIT*** Resolved Smile MtFixIt update for some reason I don't think finalized correctly. Update was available for download again after reboot. I ran the update again and then performed a reboot. Issue resolved and sound is now working properly. Woohoo. Thanks.
I think there is a post elsewhere that had the same problem, fixed by logging in as root ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Pinebook Pro on Debian 12 Power Issue u974615 1 229 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 179 02-17-2024, 07:06 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 0 151 02-13-2024, 10:43 PM
Last Post: segaloco
  Pinebook Pro charging issues tomekdev 1 525 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 955 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 126,975 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,712 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,138 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 131,695 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,759 10-21-2022, 07:57 AM
Last Post: dachalife
