Pinetab secondary display?
Hello all,
I apologise if this is not the correct forum for this,but I was wondering if it will be possible to include some functionality (perhaps via usb-c) to use the Pinetab as a secondary monitor?  I find myself wishing that I had a portable monitor with my work laptop and this would be a nice opportunity to have a useful machine with me too.
Thanks!
Actually, this would be really handy...
A quick search turned up some possible software solutions.
First bunch are virtual KVM switches:
Synergy (software KVM switch)
https://symless.com/synergy
https://github.com/symless/synergy-core
Barrier (Fork of Synergy)
https://github.com/debauchee/barrier
x2vnc
http://fredrik.hubbe.net/x2vnc.html
A little more searching turned up
VirtualMonitor (Use a phone or tablet as additional display device)
https://virtualmonitor.github.io/
These next might work if you load Android on the PineTab
Splashtop Wired XDisplay
https://www.splashtop.com/
Twomon
http://www.easynlight.com/en/
SpaceDesk
https://spacedesk.net
Sent from my moto x4 using Tapatalk
(09-10-2019, 07:48 AM)Kochise Wrote:
Yes but this is just a monitor. My hope was that the ability to use the Pinetab as a secondary monitor could be included so that it can have more uses day to day.
The basic idea and demonstration is here, by as Linus states, when really really thin, it becomes viable as a second screen you can easily carry around.
Sad display blinks on and off when not on charger jpaulbiss 8 6,104 12-09-2023, 08:14 AM
Last Post: mannzrespouse
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 656 09-02-2023, 10:13 AM
Last Post: lupyuen
  [Article] RISC-V Star64 JH7110: Inside the Display Controller lupyuen 2 934 08-23-2023, 05:08 PM
Last Post: lupyuen
  Article: ST7789 Display with LVGL Graphics on Apache NuttX RTOS (PineCone BL602) lupyuen 0 867 03-31-2022, 09:31 PM
Last Post: lupyuen
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,605 01-11-2022, 06:31 AM
Last Post: collierreinhold
  PineTab second batch guenther 2 1,590 10-28-2021, 08:42 AM
Last Post: guenther
  How to keep the display of the 120W PinePower turned off? pinepoweruser 4 4,140 08-04-2021, 12:24 AM
Last Post: kqlnut
  Looking to buy a used PinePhone Mobian CE or PineTab alontra 0 1,686 03-04-2021, 06:33 AM
Last Post: alontra
  Article: PineCone BL602 Talks UART to Grove E-Ink Display lupyuen 0 1,441 02-18-2021, 09:08 PM
Last Post: lupyuen
  Article: PineCone BL602 Blasting Pixels to ST7789 Display with LVGL Library lupyuen 0 1,416 02-15-2021, 09:03 PM
Last Post: lupyuen
