Pinebook Pro Audio Codecs
Something they don't really cover, or I haven't been able to find where it is, is what audio codecs will this work with? Aptx hd, LDAC, AAC or SBC? hoping for Aptx hd
(09-05-2019, 10:57 AM)CryptoRick Wrote: Something they don't really cover, or I haven't been able to find where it is, is what audio codecs will this work with? Aptx hd, LDAC, AAC or SBC? hoping for Aptx hd
It's likely using the same wifi/bluetooth module as the RockPro64 adapter:
https://store.pine64.org/?product=rockpr...4-1-module
It seems to use a Broadcom BCM4359 wifi/bluetooth module.
You may be able to see what codecs are supported in hardware, but I would not assume a Qualcomm proprietary audio codec is likely to be supported in an older broadcom chip.
The Pinebook Pro uses a Ampack AP6255 module, which internally is effectively a Broadcom BCM43455. So, you're actually pretty close except that the 43455 is 1x1 WiFi. But that does not change the Bluetooth capabilities in any way.
To the best I can tell, most of those Bluetooth audio codecs are dependent solely on the software (with maybe the exception of AptX), so it will probably depend on what distro you have installed on your PBP.
Do any distros that you know of support any lossless format? LDAC is sony but I read somewhere it was ported.
  Pinebook Pro Initial Impressions kunger 443 584,937 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,238 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 377 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 280 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 273 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 206 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 637 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 708 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,479 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,171 12-15-2023, 02:11 PM
