IR Receiver installation
Sad
I received the remote control with my Pine 64 shipment. Remote control box had an IR receiver taped on the outside of the box and that was it. Not even a hand drawn schematic explaining how to hook it up.
Which pin is GND? Which pin is VCC?
Has anybody hooked it up?
Could you please post a picture or diagram?
Thanx.
http://wiki.pine64.org/images/7/7d/Pine6...nector.png
The image shows the IR reciever on the same side as the USB connectors. It is right next to the audio jack. plug it in facing outwards
  Mounting the IR Receiver on the PineA64 for use with OpenHour Remote MarkHaysHarris777 7 12,138 01-17-2017, 05:19 AM
Last Post: Israeldelamo
