Unable to get edimax wifi dongle to work with archlinux on Pine64
Hi guys,
The title pretty much describes my situation that I am currently in. I don't know what to do and have been looking online for a while now and I can't seem to figure out the cause of my problem. Has anyone tried to use the edimax wifi dongle on their Pine64 yet and if so did you get it to work?
(04-26-2016, 01:54 PM)g3tinmybelly Wrote: Hi guys,
The problem is the current Kernel does not have a lot of drivers/modules built in at this time. Simple as that. If you are running one of the linux OS's install whatever package you need to get lsusb and issue that command, it should identify more specifically the wifi chip involved. Needed I am afraid because even big wifi adapter manufs from time to time will change which wifi chip is in a wifi dongle of the same model number (stupid I know).
Post back the info here and maybe someone can help get it working.
So will it one day be supported?
(04-26-2016, 10:12 PM)g3tinmybelly Wrote: So will it one day be supported?
No clue, maybe, maybe not.
I have been lazy myself and not tried other than cursory playing to try to get the wifi adapters I have around working. To be honest the pine folks  are really only obligated to support their own wifi card. Beyond that you're at the mercy of Allwinner and/or the devs who are working with linux and Pine.
Of course I have seen at least one person say they have compiled their own kernel based on longsleep's instructions ( http://forum.pine64.org/showthread.php?t...ht=compile ) you could always find out what modules and drivers you will need and try to roll your own.
I tried 2 different ones - nothing seems to works atm. I am sceptical if we will see support for wifi dongles anytime soon ...
Without telling what device this is it is hard to say. I guess it is one that requires rt8192cu driver which is not supported by the BSP Kernel. It can be backported though. Feel free to open up a PR on GitHub. The rt8192cu driver would be nice to have.
(04-27-2016, 01:16 PM)longsleep Wrote: Without telling what device this is it is hard to say. I guess it is one that requires rt8192cu driver which is not supported by the BSP Kernel. It can be backported though. Feel free to open up a PR on GitHub. The rt8192cu driver would be nice to have.
So is one wanted the Atheros ath9k_htc added a pull request would be sufficient?
Yes, but i am looking into it already. I can see that some common and often used wifi modules should be there.
(04-27-2016, 04:02 PM)longsleep Wrote: Yes, but i am looking into it already. I can see that some common and often used wifi modules should be there.
You really do need a tip jar.
Yeah, it's the one that requires rt8192cu driver. I think I will open up a PR on github. Good idea!
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,743 08-24-2021, 08:17 AM
Last Post: lamson
  Newbie unable to connect to internet Derek7 2 3,081 07-16-2021, 12:41 AM
Last Post: Derek7
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,432 06-17-2021, 05:35 AM
Last Post: kqlnut
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,890 02-02-2021, 12:13 AM
Last Post: PineSupporter
  How to get Netflix to work in Chromium or Firefox on PBP User 17828 13 19,302 09-24-2020, 08:52 AM
Last Post: solostian
  Cannot charge and NO Wifi? jiapei100 3 5,447 06-27-2020, 02:11 PM
Last Post: jiapei100
Bug WiFi enabled but refuses to connect cardboardmaster 6 7,765 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 9,005 05-28-2020, 05:44 PM
Last Post: Luke
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,726 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 3,963 04-19-2020, 10:33 PM
