PCIe Sata II adapter and ssd TRIM
Hi!
I've just received and installed the PCIe Sata adapter into my RockPro64. It is connected to a Samsung Evo860 Sata SSD. The problem is that when I do a trim (for exmaple, "fstrim -va") it takes a long time and generates lots of error messages (see https://pastebin.com/5EARFYTk). Has anybody experienced this? I am using the latest Ayufan 5.2 kernel and the ssd works properly (if I connect it through a JMicron usb3 to sata adapter, the trim works fine and the performances are very similar to the one I can see with the PCIe to sata adapter).
Thanks for any feedback and suggestions!
  RK3399 PCIe enumeration jhadd 0 281 01-31-2024, 08:56 AM
Last Post: jhadd
Question nand-sata-install on RAID-1 array ARMandHammer 1 891 02-12-2023, 03:10 AM
Last Post: igorp
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,217 10-14-2022, 06:24 AM
Last Post: rwk-
  No PCIe controller detected... Limhes 1 1,598 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,838 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,409 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,854 05-20-2021, 10:04 PM
Last Post: t4_4t
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 8,077 12-12-2019, 04:43 AM
Last Post: dukla2000
  Frequent kernel panic, possibly due to PCIe SSD? meier 4 5,953 11-22-2019, 05:15 PM
Last Post: meier
  My PCIe disk controller works with Linux 5.3.6 guannais 1 2,753 10-30-2019, 07:11 PM
Last Post: guannais
