Emails from pine64 received as spam by gmail
Hi everyone,
I have recently registered an account to join the forums and I received no confirmation email at first, I later found it in the spam folder of my gmail account.
The header says:
Quote:Why is this message in spam? It is in violation of Google's recommended email sender guidelines.
Not sure if this is the place to note this and I couldn't find a reference for it when searching through the forums.
I clicked the 'Report Not Spam' button, but I figured you might want to take care of it on your side as well.
We're aware of the issue. There are plans for how to fix it, but we're not going to implement them until the current phase of Pinebook Pro preorders is over.
Likely the same issue but, the confirmation email is completely rejected by mailbox.org by default.
By default mailbox.org completely rejects email it considers spam. I thought I had it setup to put spam in the "Junk" folder but the settings are a bit tricky if you don't pay close attention to the FAQ here. If a "technical filter" (Greylisting, SMTP Plausibility check, Realtime Blacklist) is enabled, emails that match the technical filter will be *rejected* and not put in Junk, as the "move to Junk" option is only for the content filter. The confirmation email matches one of the technical filters, so I'm posting here in case it could help someone else who is wondering why it is not even in Junk ...
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,742 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,429 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just received Pinephone - system crashes Zebulon Walton 12 13,758 11-13-2020, 05:45 PM
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,721 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 3,963 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 150,384 01-15-2020, 12:46 PM
  How to handle a Pine64 correctly gbjensen 6 16,324 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 8,307 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 208,574 10-11-2018, 11:35 PM
Last Post: Technolab88
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,489 01-10-2018, 04:05 PM
Last Post: dkryder
