Rock64 board seems defective, how to confirm?
Hi all!
I have a 4GB Rock64 that has never been able to run any image for more than a few minutes without a kernel panic or a complete freeze. It usually happens within seconds of booting. At first I assumed I had just been unlucky with my image choices, but over the past few days I've gone through probably a dozen different images, Linux as well as Android, and nothing seems to work (though Android images typically run ok right up until the mouse cursor shows up on the screen). I'm booting from sd and I've tried two different cards. Is there anything else I can try that would possibly get this working? Any recommendations for a super-stable image to try? Or something like a memtest image that could help me diagnose the problem?
Unfortunately I bought this last year so it is no longer under warranty, but I would at least really like to confirm that it is a hopeless case before I throw it out the window.
(08-08-2019, 01:35 PM)Josk Wrote: Hi all!
1. Please check your power supply whether still function properly. If you have scope, check the voltage ripple waveform.
2. Run meemtest is a good way to determine whether DRAM still function well.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 255 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,239 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,625 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,066 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 324 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,863 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,491 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,075 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 744 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 944 10-07-2022, 07:50 PM
Last Post: rookie_267
