Pinebook 1080p screen with other SBC?
Hello all,
I cracked open my pinebook after I noticed the hindge was opening the case a little bit when opening the lid.  Some of the plastic is broken in many of the screw points, so it got me thinking; what are alternative ways to reuse the hardware in my pinebook.  From the wiki doc on the LCD screen it said that the interface for the screen is an eDP (embedded DisplayPort), but the ribbon cable on the pinebook board is the same size as the DSI interface on a raspberry pi 3b (and others).  But I also noticed that the same cable drives the web camera too.
The cable has the following information on the sticker that was covering the connector:
YD200 LCD Cable
P/N: FPC-C0176
Date code: 18/10/08
Vendor code: XBH
Is there an easy (cheap) way to adapt this to DSI or HDMI input?  I would like to use it with a Retropie setup.
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
https://photos.app.goo.gl/Y8oqbuBwLCquvV7p7
I have tested the pinebook without the screen using HDMI out in Android and it was working. The wifi antenna was put back in the bottom case after taking the screen apart. The link is to some pics I took of my open PineBook 1080p.
If anyone knows of what control board works with the Pinebook 1080p screen through HDMI or DSI in I would greatly appreciate a link to the item so I could order it.
Thanks.
So, you say, that on android HDMI out works. Great. Just 2 questions.
Which android version are you using?
Is video HW acceleration working there too?
Thanks.
I was using the only Android release available for the pinebook 1080p on the pine64 wiki. It is Android 6.0, I have played Knights of the Old Republic on it before with an XBox 360 controller, and I also played some Nintendo DS games with DraStic. Games run better on Android than on any Linux build i have tried on this hardware.
I don't know if it was accelerated or not, but I got some of my Android games to run. Soul Caliber and NBA Jam also worked for me ... But with an Xbox 360 controller.
https://photos.app.goo.gl/roFb8rw54U3RVVb49
Pics of my pinebook running without the display using an HDMI output.
Thanks, will give it a try to see for myself.
  pinebook 1080p power/barrel connector/cable cel 0 544 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,373 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,223 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,632 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,317 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,603 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,608 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,778 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,673 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,886 07-02-2020, 06:33 PM
