nvme adapter for PBP
Is this nvme adapter, that can be ordered with the PBP, a special adapter for the PBP, or can I just order any nvme adapter?
What would you do with the nvme interface. I am curious what you would do with it, besides from installing an SSD...
Waiting to get my coupon...
An external GPU dock would be awesome sauce. You probably still need their fancy adapter with the carefully bent ribbon cable though.
(07-26-2019, 01:18 PM)InsideJob Wrote: An external GPU dock would be awesome sauce. You probably still need their fancy adapter with the carefully bent ribbon cable though.
Keep in mind it's only 4x though, so the GPU would severely underperform to its full potential.
The screen is 60Hz so I don't need more than 60FPS anyways or the tearing will be horrendous.
I'll probably connect a Crucial 1TB M.2 2280 3D NAND NVMe SSD to mine though... street price at Newegg and Amazon is $99.
It has to be NVME PCIE, not SSD.
(07-26-2019, 08:45 PM)binarian Wrote: Keep in mind it's only 4x though, so the GPU would severely underperform to its full potential.
GPU will not work on PBPro due to 32MB DMA buffer available.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
Quantify "severely". I've been running laptop with eGPU via EXP GDC connected to M.2 slot, gaming was very comfortable.
And, from my reading, it's PCIe 2.1, meaning only 5Gbps per lane, (which includes high encoding overhead, not the lower overhead of PCIe 3.x).
That's perfectly fine & usable for a 4 lane NVME SSD. But, video?
Of course I could be wrong about the PCIe 2.1. (I thought I was wrong once, but I was wrong :-). Here is the reference;
https://wiki.pine64.org/index.php/ROCKPr...sion_Ports
Arwen Evenstar
Princess of Rivendale
(07-27-2019, 07:21 AM)ayufan Wrote: It has to be NVME PCIE, not SSD.
What do you mean?  It's not a SATA SSD:
https://www.amazon.com/Crucial-1TB-NAND-...B07J2Q4SWZ
Will that not work?
Will that not work?
Yes, that should work fine.
Thanks for the link, looks like a fine device and great price. When I bought an 1TB 2.5" SATA SSD for my old laptop back in 2014, it cost $500 if I remember correctly. More than the cheap laptop it was going to installed in.
Edit: It should work fine as it's NVME, not SATA. However, we have been discussing power usage in another thread. So from a power perspective, it is unknown if the Crucial devices will work reliably.
Arwen Evenstar
  New Working nVME gilwood 0 155 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,418 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,725 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,036 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,794 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,793 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,359 12-10-2021, 07:47 PM
Last Post: josmo
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,316 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 2,555 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,630 07-09-2021, 08:45 PM
Last Post: moonwalkers
