will openMP work on a pinebook?
should openMP work fine on pinebook?  will it have GCC or even G++?
Please don't post the same thread in multiple subforums.
Also, moved to the to the proper subforum for the subject.
I don't know what distribution you use, but if it's Arch or Arch-based, then openmp is available for arm64 within the AUR. It appears in Debian's available packages as well, so you should be able to install it.
https://archlinuxarm.org/packages/aarch64/openmp
https://packages.debian.org/search?suite...rds=openmp
  DietPi OS for Pinebook MichaIng 3 5,332 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,655 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 878 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 677 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,547 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,206 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,811 01-04-2022, 09:22 PM
Last Post: irongarment
  Wifi doesn't work correctly Fredric92 1 3,515 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,208 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,791 01-20-2021, 11:18 AM
