Rock64 Seafile Installation
Sad
Dear all,
currently i'm running 3 Raspberry Pi's for different tasks (ie. FHEM, VPN-Gateway, Seafile-Cloud, NAS ...). Due to the lack of USB performance i decided to buy a Rock64 to use it as NAS which works pretty good. Afterwards i thought about exchaning one of the RPI's by installing Seafile on the Rock64.
After several hours of try & error i can't get Seafile installed on the Rock64.
I tried to compile Seafile with the help of the Seafile manual but ending in a lot failures.
I tried to install an alreadys compiled version but struggeling with the mysql-configuration which is killing me.
On the Pi everything was a little bit easier. Has anybody a good and working instruction to get Seafile installed on the Rock64?
Which OS should i use to get it running? Up to now i tried bionic-minimal and armbian.
Thanks in advance for your support.
Hate to say it now but you do know that the Pi 4 has hit the scene with similar specs to the Rock64 if you're looking for the easy solution.
(06-26-2019, 05:30 PM)Rocklobster Wrote: Hate to say it now but you do know that the Pi 4 has hit the scene with similar specs to the Rock64 if you're looking for the easy solution.
Hi Rocklobster,
i realized it shortly after my post. I'll sell the rock64 to get the new Pi4 which has 2 USB3-ports. I looked forward to work with the Rock64
but the Pi-world is much easier :-(
Thanks for your response.
Regards
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 253 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,237 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,625 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,066 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 323 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,862 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,489 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,074 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 743 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 944 10-07-2022, 07:50 PM
Last Post: rookie_267
