Another non-booting ROCK64
(06-17-2019, 12:26 PM)Rocklobster Wrote: 90% of HDMI issues are caused by badly manufactured or poorly screened cables. If you're using a desktop version Distro your system is left hanging as you've seen. Don't forget avoid plugging your HDMI cable when your board is powered up. Glad you got sorted!!!
That sucks in fact, because HDMI was designed to be hot pluggable. Sad
ANT - my hobby OS for x86 and ARM.
As an experiment try tipping the edge of the metal HDMI connector on the board with the HDMI cable plug end while the HDMI cable is plugged into the monitor and the board is powered up. You'll notice sparking. The Rock64 board needs to be cased and properly grounded which I imagine most tinkerers don't bother with.
(06-18-2019, 03:34 AM)Rocklobster Wrote: As an experiment try tipping the edge of the metal HDMI connector on the board with the HDMI cable plug end while the HDMI cable is plugged into the monitor and the board is powered up. You'll notice sparking. The Rock64 board needs to be cased and properly grounded which I imagine most tinkerers don't bother with.
The naked board always has such grounding concern :-(
Please DO NOT connect external ground to the board ! If you are not able set the same ground point for all equipment (and antenna) the high current on ground wire can flow between board and other equipment (TV) that can damage anything.
The some effects (like "hotplug" does not work, DDC ("i2c identification")  does not work, CEC does not work ...) are common to all single-ended signaling buses that are affected by ground "voltage differences" due to current flow on ground line.
Recommended power supply is designed as CLASS II (two power pins but no ground). Class II (double insulated) electrical appliance is designed in such a way that it does not require (and must not have) a safety connection to electrical earth (ground).
Checklist
  • * power supply CLASS II mark
  • * problems are in some power supply "reduced" designs without (or fakes) certification marks (maybe some Y class capacitor missing)
  • * TV antenna connection can be source of high ground (try to disconnect antenna or install antenna galvanic separator)
  • * disconnect other powered equipment from TV
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 244 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,206 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,620 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,048 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 319 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,858 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,483 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,069 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 740 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 941 10-07-2022, 07:50 PM
Last Post: rookie_267
