06-04-2019, 05:36 PM
Are there any specific requirements on the POE side for the Rock64 rev3?
Rock64 v3 - POE
06-07-2019, 12:24 AM
07-28-2019, 02:03 PM
I began to implement PoE but I found problem. If I use PI2/PI5 connector to feed from internal PoE there is ferrite bead "L3203" between 5V (connector) and VCC_SYS (system) (see official schematics). L3203 is BLM18PG181SN1 but it is rate only to 1.5A DC current ! It fries itself with higher currents.
Did you use in final version BLM18PG181SN1 or BLM18PG330SN1 (3A version) or 0ohm resistor as in my Rock64ver3 sample ?
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" . ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
08-18-2019, 05:51 AM
(This post was last modified: 09-28-2019, 01:40 AM by mcerveny.
Edit Reason: POE for RPI4
POE implementation was successful. POE PD 5V RT9400 ($4, 14mm width to attach in common case) + power button ML6-H1S12BVA ($1.5) + case EM-RasPI B+ basic ($6) + silicone thermal pads with adhesive to attach/cool POE (1mm/3mm) + cables and connectors + some passives = ~$13.
Implementation notes:
Actual versions of POE (~ $4 (poe) + $1 (capacitor+connectors)) without poweron button for RaspberyPI 4 (Rock64 v3 compatible). The last post. Farewell.
Rock64 No Audio @ Debian 12 | dmitrymyadzelets | 1 | 118 |
03-18-2024, 06:56 AM Last Post: diederik |
Rock64 bricked | shawwwn | 7 | 5,461 |
03-17-2024, 12:22 PM Last Post: dmitrymyadzelets |
Rock64 won't boot | luminosity7 | 10 | 3,868 |
03-16-2024, 08:33 AM Last Post: dmitrymyadzelets |
Rock64 doesn't boot | dstallmo | 1 | 256 |
03-16-2024, 08:29 AM Last Post: dmitrymyadzelets |
How well does Rock64 deal with HDR and Atmos on Kodi? | drvlikhell | 3 | 1,772 |
04-29-2023, 04:24 AM Last Post: newestssd |
OpenWRT on the Rock64 | CanadianBacon | 12 | 7,800 |
04-24-2023, 12:40 PM Last Post: arunkhan |
Rock64 board not working, no HDMI no Ethernet. | EDited | 3 | 3,402 |
01-17-2023, 02:31 PM Last Post: Flagtrax |
ROCK64 v3 can it boot from USB? | Tsagualsa | 4 | 1,975 |
11-29-2022, 11:31 AM Last Post: Macgyver |
rock64 v3 spiflash | Macgyver | 0 | 703 |
11-28-2022, 02:18 PM Last Post: Macgyver |
my rock64 dosen't work | rookie_267 | 0 | 907 |
10-07-2022, 07:50 PM Last Post: rookie_267 |
