Using GPIO with OS
Hi
Im new to with the system. I bought it two years ago but I was not able to use it before hehe
I want to use the Pine A64(+) to read several sensors, which are compatible with Arduino. I have two questions:
1) If I need to use the touch screen, that apparently only runs with Android 6.0.1, is there a way to also make use of the GPIO??
2) Are there libraries to use different sensors with those pins? or examples? I'm planing to use several sensors that work with analog outputs and I2C and SPI so I was wondering if there are info about that
Thanks!
(05-31-2019, 01:56 PM)MikeA23 Wrote: Hi
Thanks!
The TP port is I2C with iinterrupt port, you can make use of the 3 GPIOs.
  GPIO performance sgjava 0 1,464 10-08-2021, 08:31 AM
Last Post: sgjava
  gpio voltages ealbers 6 10,109 07-30-2017, 01:55 AM
Last Post: pfeerick
  read/write gpio in c example? ealbers 1 4,387 07-23-2017, 05:53 AM
Last Post: MarkHaysHarris777
  GPIO and OS Choice fsa317 3 4,729 05-02-2016, 04:30 PM
Last Post: rahlquist
