First-Timer trying to set up a minecraft server
Hello all!
I'm a newcomer to the world of SBC's and got my 4-GB Rock64 delivered yesterday, so of course I've been spending most of today fidgeting and trying to get it to boot properly. I'm writing here because while I've gotten it booted up 'n running, I still feel like the performance is very underwhelming. I have a sneaking suspicion it's because I've done something wrong but am not sure where to go from here.
I got this board specifically because of it's price-to-performance ratio, I'm looking to set this up as a minecraft server machine for my friends and after some quick searching on speccs and seeing others doing the same with their pine64 boards I thought it'd be the best option for the price.
I'm running the OS on a flashed 128GB, UHS-1 SanDisk ((still Very new to SBC so this felt like the less daunting option vs eMMc)) which I accidentally first flashed a RockPro64 image on and then emptied by formatting it back, using the SD Association's SDFormatter. It's now flashed through the Pine64 Installer with the Ubuntu 18.04 Bionic image (build 0.7.9-1067) which booted up no problem first try! Might also be worth noting I have VERY little experience working with linux, I've only ever owned windows machines but I've messed with ubuntu machines a bit in some programming courses so it's better than the 0 experience I have with any of the other options in the installer.
I also managed to set up a SSH-server on it and remotely installed the default JDK 11.0 kit, and a minecraft server by using PuTTY and psftp. which I could not get to run smoothely or anywhere near acceptable speeds. I delegated a minimum of 2GB memory for it to use but it never used more than .6-1.3 MB, and ended up stuttering and having delays of 2-5 seconds!
I guess my question is: Am I doing something wrong, and if so does anyone have any pointers? (maybe it's because of how I handled the SD card or maybe the fact I used a SD card to begin with? is there a better OS-image to use for this purpose?) or is this just not something that the Rock64 is capable of dealing with?
Its likely an issue with one setting or another - most certainly not something to do with the Rock64. I know nothing about minecraft so cant help you there.
Which image are you running? an exact link would be beneficial ...
(05-30-2019, 03:22 PM)Luke Wrote: Its likely an issue with one setting or another - most certainly not something to do with the Rock64. I know nothing about minecraft so cant help you there.
I'm using the Ubuntu Bionic image provided by the Pine64 Installer: https://wiki.pine64.org/index.php/ROCK64...5B0.7.8.5D
Minecraft servers are pretty basic .jar executable so I don't think it's anything I've done wrong on that end. Feels like I'm just not somehow delegating the resources to it that I want, through the SSH session, or maybe it's the OS that's not optimized for it?
My initial suggestion would be to try a (much) newer image. I suggest either getting the newest pre-release from ayufan or mrfixit's debian.
  Safest way to send shutdown signal to headless Rock64 SMB server? bmurphr1 3 4,221 03-14-2021, 06:01 PM
Last Post: clach04
  Rock64 v2 as Openmediavault server - buffers / shutdown problems helpmerock 2 3,927 12-29-2020, 09:46 AM
Last Post: helpmerock
  R64 media server Timelord47 0 1,711 05-09-2019, 04:19 PM
Last Post: Timelord47
  Rock64 as multiple server Sputnik 2 4,086 11-01-2018, 12:59 AM
Last Post: Sputnik
  How can I install tvheadend server un rock64? gedas07 12 13,358 08-25-2018, 01:06 PM
Last Post: gedas07
  [Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64 pine3228 9 11,713 03-11-2018, 07:46 AM
Last Post: pine3228
  ROCK64 as a server Fallen 6 12,804 08-20-2017, 11:45 AM
Last Post: Fallen
  Minecraft Server on Rock64 elienar 0 2,781 08-07-2017, 08:05 PM
Last Post: elienar
