First Manjaro Mainline build!
Installed Manjaro the other day and ran into an issue with the ethernet connection. Transfer rates came down to zero when submitting large packages. As a result I was not able to update the system or browse the internet. I ended up copying the rk3399-rockpro64.dtb device tree file from an armbian installation to my Manjaro installation. With that device tree file everything is fine and I have a fast ethernet connection. As Manjaro uses the mainline kernel, it seems as if there are some kernel mods around which haven't found their way into mainline yet (mr.fixit's kernel is working, too). Browsing the armbian forum, searching for rp64 related information, I found a thread where a maintainer described the cumbersome process of submitting patches to the mainline kernel.  So one can only wait until, hopefully,these patches will be applied to mainline.
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,501 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,320 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,147 04-23-2023, 01:32 PM
Last Post: diederik
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,040 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 889 12-31-2021, 12:51 AM
Last Post: publiclewdness
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 2,308 09-11-2021, 08:58 PM
Last Post: t4_4t
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,464 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  Headphone jack issues Manjaro Mangled 2 2,805 03-06-2021, 11:01 PM
Last Post: Mangled
Question Mainline Debian Buster on RockPro64 ? chrestomanci 36 36,153 02-14-2021, 02:37 PM
Last Post: foresto
  Wifi on Manjaro User 19517 0 1,894 09-14-2020, 06:53 PM
Last Post: User 19517
