Set Ethernet Static IP
Sad
Hi. I'm using ROCKPRO64 4GB. I want to set static ip address for ethernet. But I can't find anywhere to set the static IP.
How can I do itSad
Thanks. At
that depends a bit what OS type you are using.
But head over to /etc/network/interfaces should be a good start for it.
Or search the Net for your OS type independent of the HW type.
M
(04-02-2019, 03:37 AM)mabs Wrote: Hi,
M
Hi M
I'm using Android 8.1 now. I can't find static IP setting menu in Android.
Can't i set static IP in android 8.1?
Thanks.
