Not able to boot Armbian 5.75@Rock64 4GB
i'll trying since days to boot following image on my Rock64:
Armbian_5.75_Rock64_Debian_stretch_default_4.4.174
Flashed it via etcher without any problem.
As soon as I boot I'll get after one minte a Exception stack ....
Exception Stack
I'm able to flash and boot Ubuntu 18.04 Bionic minimal 32bit Image.
There I have troubles to find/install the WLAN adapter.
I wanted to buil a Home-SIEM with the Rock64 (https://medium.com/@fbotes2/secure-dns-i...faa85bd833)
My Setup:
ROCK64 SINGLE BOARD COMPUTER
DRAM: 4GB
ROCK64 USB 3.0 Dual Band 1200Mbps WIFI 802.11A/B/G/N/AC (RTL8812AU) Adapter
1 $21.99
32GB CLASS10 MICROSD CARD
Have somebody a clue or hint?
i installed a copy of this last week and it worked good. i'd suggest unplugging the usb wifi card and then boot to see if that is causing the issue. if it still does not boot try burning another image. wait until you go through the setup and get a desktop and then insert the wifi adapter.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,333 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 600 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 598 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,277 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,729 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 639 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 616 03-03-2023, 09:24 PM
Last Post: acwest
