Trying to update kernel
I installed Bionic Containers aarch64 (DockerCE & Kubernetes) [microSD / eMMC Boot] [0.7.9] image.  I'm booting from a microSD.  I must be missing something obvious, but I can't boot to a different kernel.
The kernel install looks good.
sudo apt install linux-image-4.14.0-rockchip-ayufan-136-gee91453
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/10.9 MB of archives.
After this operation, 41.6 MB of additional disk space will be used.
Selecting previously unselected package linux-image-4.14.0-rockchip-ayufan-136-gee91453.
(Reading database ... 48989 files and directories currently installed.)
Preparing to unpack .../linux-image-4.14.0-rockchip-ayufan-136-gee91453_0.5.15_arm64.deb ...
Unpacking linux-image-4.14.0-rockchip-ayufan-136-gee91453 (0.5.15) ...
Setting up linux-image-4.14.0-rockchip-ayufan-136-gee91453 (0.5.15) ...
update-initramfs: Generating /boot/initrd.img-4.14.0-rockchip-ayufan-136-gee91453
Creating new extlinux.conf...
Installing new extlinux.conf...
The extlinux.conf has the new kernel information.
cat /boot/extlinux/extlinux.conf
timeout 10
menu title select kernel
default kernel-4.13.0-rc1-rockchip-ayufan-102-g6104f84
label kernel-4.14.0-rockchip-ayufan-136-gee91453
   kernel /boot/vmlinuz-4.14.0-rockchip-ayufan-136-gee91453
   initrd /boot/initrd.img-4.14.0-rockchip-ayufan-136-gee91453
   devicetreedir /boot/dtbs/4.14.0-rockchip-ayufan-136-gee91453
   append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
label kernel-4.14.0-rockchip-ayufan-136-gee91453-memtest
   append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4 memtest
After rebooting, it still has the original kernel.
Quote:uname -r
4.4.132-1075-rockchip-ayufan-ga83beded8524
Thanks for any help!
I remember this error long time ago. Do you have something inside your SPI?
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 847 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,137 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 1,850 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 1,461 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 2,311 09-11-2021, 08:58 PM
Last Post: t4_4t
  compiling a new kernel for overclocking on arch Mentaluproar 2 2,790 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 3,026 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 3,190 03-12-2021, 05:17 PM
Last Post: LMM
  Kernel oops after big-ish writes gaeb 1 2,356 02-11-2021, 03:55 PM
Last Post: gaeb
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 5,369 10-22-2020, 01:12 PM
Last Post: dukla2000
