Rock64 - Headless Setup?
Question
I'd like to be able to transfer an image of Bionic (or whichever - I've tried a few) to the Rock64 and have it boot, connect to my wireless LAN and allow me to ssh in headless.
I purchased the Rock64 along with the recommended USB Wireless dongle from the shop - and can't seem to get any combination of putting in a "wpa_supplicant.conf" file and a blank file of "ssh" like I do with the Debian installs on the Pi. I still always have to connect monitor and keyboard to get it to come up and get connected.
Anyone have a link on "Rock64 Headless Setup" they could point me to? I've tried my Google and duck-fu to no avail.
Any tips would be deeply welcomed! Thanks!
Ryan
(03-17-2019, 10:09 PM)SirRyanTheGeek Wrote: I purchased the Rock64 along with the recommended USB Wireless dongle from the shop - and can't seem to get any combination of putting in a "wpa_supplicant.conf" file and a blank file of "ssh" like I do with the Debian installs on the Pi. I still always have to connect monitor and keyboard to get it to come up and get connected.
Use nmtui
Use nmtui
Use nmtui
Yep. I did that and that's how I got it to connect - but that required me to boot it, plug in a monitor a keyboard and run that stuff. Is there a way to create the image for "first boot" when I plug it in to the Rock64 and turn it on that it's automatically connected and accessible from my internal LAN?
(03-18-2019, 07:26 AM)SirRyanTheGeek Wrote: Yep. I did that and that's how I got it to connect - but that required me to boot it, plug in a monitor a keyboard and run that stuff. Is there a way to create the image for "first boot" when I plug it in to the Rock64 and turn it on that it's automatically connected and accessible from my internal LAN?
I have the following on one of my systems
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
    address 192.168.0.100
    netmask 255.255.255.0
    gateway 192.168.0.1
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
and in /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
    ssid="ssid"
    psk="password"
auto wlan0
allow-hotplug wlan0
   gateway 192.168.0.1
update_config=1
network={
    ssid="ssid"
    psk="password"
That first piece of code - where it references the supplicant file - where does that live? Thanks!
(03-20-2019, 10:04 AM)SirRyanTheGeek Wrote: That first piece of code - where it references the supplicant file - where does that live? Thanks!
Sorry about that, /etc/network/interfaces, you may need to change wlan0 interface name if the system is using mac address naming...
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,365 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 337 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,391 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,589 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,421 12-07-2022, 08:22 PM
Last Post: luminosity7
