No USB Power (ROCK64+ARMBIAN 5.7)
Question
Armbianmonitor:
http://ix.io/1DAn
Hello, can someone help me with my problem.
I have a ROCK64 with 4GB of RAM and an ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 4.4.174-rockchip64, installed.
My issue come with usb ports, from the three USB of the this device only works two: one 2.0 and 3.0. And when i have a disk connected towards usb 3.0 i have issues with port usb 2.0, it doesn't work well and I end up disconnecting the USB 3.0 to can work with my device connected towards USB 2.0 so I assume that the current power on the USB port is having issues or it's not working well.
Anybody an idea?
thanks!
Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
(03-15-2019, 07:36 AM)Rocklobster Wrote: Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
any other options or ideas?
is there any way to check current power of each usb from OS?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 135 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,329 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 324 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 596 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 597 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,247 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,540 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 583 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 636 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,965 12-07-2022, 08:22 PM
Last Post: luminosity7
