How to compile ayufan repo step by step?
I am recently buy a rock64 board, when search using google, I found  ayufan repo, so I download the SD card image from release link below:
https://github.com/ayufan-rock64/linux-b.../tag/0.7.9 , such as stretch-minimal-rock64-0.7.9-1067-arm64.img.xz
[url=https://github.com/ayufan-rock64/linux-build/releases/download/0.7.9/stretch-minimal-rock64-0.7.9-1067-arm64.img.xz][/url]the rock64 can start normal and into the linux system.
But when I changed some config in kernel, what is the step to create a SD image base on some components like: u-boot.img, boot.img, and buildroot rootfs.ex4.
Thanks a lot.
  Are you guys still using Ayufan's OMV on your Rock64? AkiraSensei 0 1,572 11-26-2021, 07:01 PM
Last Post: AkiraSensei
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 1,539 07-02-2021, 03:13 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 15,211 11-17-2020, 08:00 AM
Last Post: Johannes
  Ayufan apt repository? ab1jx 2 3,573 11-23-2019, 10:08 PM
Last Post: ab1jx
Wink SDR104 on ayufan 0.7.7+ XFer 0 1,604 10-25-2018, 06:30 AM
Last Post: XFer
  Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141 techyjtmb 9 10,214 06-23-2018, 09:52 AM
Last Post: NablaMetal
  AOSP Build Steps Using github.com/ayufan-rock64/android-7.1 birender.s 15 20,407 05-09-2018, 01:20 AM
Last Post: burram
  Some questions about r64 and ayufan android tv Synthetikz 1 2,736 03-13-2018, 03:28 PM
Last Post: Luke
  I can't compile kernel !! part2 pine3228 1 2,303 02-05-2018, 03:52 AM
Last Post: xalius
