Trying to install OpenBSD, I get u-Boot error
Hi there.
I tried to install OpenBSD, I copied the minirootfs to sd card from an OpenBSD machine and copied relevant dtb to sd card:
dd if=miniroot64.fs of/dev/rsd0c bs=1m
mount /dev/sd0i /mnt
mkdir /mnt/allwinner
cp /usr/local/share/dtb/arm64/allwinner/sun50i-a64-pine64.dtb /mnt/allwinner
But it didn't help. I get
U-Boot SPL 2018.09 (Oct 12 2018 - 03:54:15 -0600)
DRAM: 0 MiB
### ERROR ### Please RESET the board ###
Please advise
Got a bit further, now it doesn't detect my mmc:
dd if=miniroot65.fs of=/dev/rsd0c bs=1m
cd /mnt
cp /usr/local/share/dtb/arm64/allwinner/sun50i-a64-sopine-baseboard.dtb .
mkdir allwinner
cp sun50i-a64-sopine-baseboard.dtb allwinner/sun50i-a64-pine64-plus.dtb
cd ~
umount /mnt
dd if=/usr/local/share/u-boot/sopine_baseboard/sunxi-spl.bin of=/dev/sd0c bs=1024 seek=8
And here is what I get:
U-Boot 2019.01 (Feb 08 2019 - 05:43:56 -0700) Allwinner Technology
CPU:   Allwinner A64 (SUN50I)
Model: Pine64
DRAM:  sunxi SPL version mismatch: expected 3, got 2
2 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from FAT... MMC: no card present
In:    serial
Out:   serial
Err:   serial
Net:   phy interface6
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  0
Device 0: device type unknown
... is now current device
ethernet@1c30000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-ba-06-5b-d4-59
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-sunxi
Config file not found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
  Installing OpenBSD on Pine A64 - LTS epsilonKNOT 2 5,024 05-23-2019, 09:19 AM
Last Post: joshuacampbell
