No green Ethernet LED
Hi All!
I'm running three ROCK64/4Gb boards in a cluster and everything looks great and I'm very happy with the devices!
But, for some reason, the green Ethernet LED turns off after a week of running. I reboot the problematic board and it's back.
Has anyone seen such an issue? Is there any fix?
(03-06-2019, 03:36 PM)sanis Wrote: Hi All!
Logs please. Perhaps also strace dmesg to a .txt file.
Luke, thank you for your reply! I would really appreciate if you can tell me what exact commands to execute to get the logs.
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,531 01-17-2023, 02:31 PM
Last Post: Flagtrax
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 2,139 10-30-2021, 06:10 AM
Last Post: Rocklobster
  4 Uarts and 2 Ethernet possiblities gops 13 16,397 11-13-2020, 08:51 AM
Last Post: LMM
  USB3 to Ethernet adapter giuseppe 0 1,702 11-11-2020, 05:48 PM
Last Post: giuseppe
  flash image to sd/emmc through ethernet LMM 0 2,275 02-04-2019, 07:36 AM
Last Post: LMM
  No Boot, Red Green and White flash at 1 sec intervals wesleykonrad 2 4,050 01-28-2019, 11:54 PM
Last Post: wesleykonrad
  Rock64 ethernet problems ushills 4 6,196 05-29-2018, 05:16 PM
Last Post: pfeerick
  u-boot doesn't receive packets over ethernet hibernick 3 4,084 01-12-2018, 12:38 AM
Last Post: hibernick
  rock64 ethernet port sticker dkryder 1 3,409 11-14-2017, 10:18 PM
  Rock64 Ethernet LED Problem gaz2613 5 5,501 10-01-2017, 08:59 AM
Last Post: stuartiannaylor
