VNC on Rock64 Ambian
on my Rock64 with Ambian, can I use this instruction form Orange Pi Ambian to install VNC?
https://diyprojects.io/armbian-access-re...H96mVW6Pmg
yes
I installed VNC and create user, login as user and so on.
But after typing "vncserver :1" I got following:
You will require a password to access your desktops.
vncserver: Couldn't find "tigervncpasswd" on your PATH.
Please install the tigenvnc-common package, i.e., sudo apt-get install tigenvnc-common.
I tried as well "sudo apt-get install tigenvnc-common.", but I got also an error message
try tigervnc-common not tigenvnc-common
OK, thank you. I'm a little bit further.
Now it seems, that it works, but when I use VNC Viewer from another computer, I can not connect.
On the Rock64 I have following message:
Would you like to enter a view-only password (y/n)? n
/usr/bin/xauth: file /home/rock64/.Xauthority does not exist
New 'localhost:1 (rock64)' desktop at :1 on machine localhost
Starting applications specified in /etc/X11/Xvnc-session
Log file is /home/rock64/.vnc/localhost:1.log
Use xtigervncviewer -SecurityTypes VncAuth -passwd /home/rock64/.vnc/passwd :1 to connect to the VNC server.
Isn't it possible to use the regular VNC viewer?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 607 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,356 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,343 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,305 12-07-2022, 08:22 PM
Last Post: luminosity7
