RPi.GPIO python module for Pine A64/A64+
#71
(02-18-2017, 06:49 AM)JasperBrown Wrote: - pip(ed) the Rasp.Pi GPIO
Whit the above line, you seem to try to compile RaspberryPi version, not the A64.
no one has mentioned the script,
create_gpio_user_permissions.py
is there some criteria by which this script should [or should not] be run?
it seems like maybe it should be run but maybe it is called from another install script? thanks.
(02-18-2017, 12:16 PM)martinayotte Wrote: Whit the above line, you seem to try to compile RaspberryPi version, not the A64.
After
sudo python setup.py install
had not worked..i tried the install.txt from git..
You just had ran the setup.py and it worked?
After getting the git, yes, only "python setup.py install" is required.
Which system image did you use?
(02-21-2017, 04:43 AM)JasperBrown Wrote: Which system image did you use?
If you meet us on irc chat we can help you in real time;  often its faster with less confusion.
Big Grin
see below for chat room details
Armbian Mainline 4.10, but months ago, I was using longsleep and it was working there too.
Has anybody used this library for I2C?
I got my first I2C device recently, this temp/pressure sensor. I tried reading it from an ESP8266 and an arduino first and didn't have any luck, so I decided to give it a try on the pine64. It shows up on i2cdetect, and if I run "sudo i2cdump twi1 0x76" it dumps a bunch of data, so I'm guessing it's wired up right.
I saw in the notes in github that this library has I2C "borrowed from pyA20", so a little googling found me some documentation here (you have to scroll a bit to get to the I2C info).
From that info, I put together this python script:
#!/usr/bin/env python3
from RPi import I2C
I2C.init("/dev/twi1")
I2C.open(0x76)
# set power mode to forced
I2C.write([0xF4,0x01])
sleep(1)
# dump data
I2C.write([0xF7])
value = I2C.read(1)
print(value)
I2C.close()
quit()
Now when I run this (as root) using python3, I get this error:
Traceback (most recent call last):
 File "./bmp280_readonce.py", line 2, in <module>
   from RPi import I2C
 File "/usr/lib64/python3.4/site-packages/RPi/I2C/__init__.py", line 4, in <module>
   from RPi._I2C import *
ImportError: dynamic module does not define init function (PyInit__I2C)
I tried changing the first line to use python2 instead of python3, and then I get this error instead:
 File "./bmp280_readonce.py", line 5, in <module>
   I2C.open(0x76)
IOError: [Errno 2] No such file or directory
Any idea what I'm doing wrong?
Are you using the library from https://github.com/swkim01/RPi.GPIO-PineA64 ?
I've verified it with both python2.7 and python 3.5 under Armbian, and it is working with both.
Yes, that's the one. So far I've just used it to blink LED's. This is my first attempt at trying to work with I2C. I wonder if there's some sample code that I could look at somewhere.
  fm transmitter with gpio weasel18 2 4,752 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,546 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 10,956 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,044 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,755 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,160 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,586 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 20,936 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 15,728 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,011 11-10-2016, 06:07 PM
Last Post: joseph
