RPi.GPIO python module for Pine A64/A64+
#61
(08-11-2016, 02:53 PM)MarkHaysHarris777 Wrote: @Wolfenstein, thank you for the effort;  very nice!
... its good to see other folks interested in the GPIO ; the more the community gets involved with connecting this PineA64 to the world via GPIO , the better.   It might be nice if a couple of us can dive into the RPi.GPIO-PineA64 code a bit, maybe even fork it, and not only get some of the kinks ironed out, but also get i2c, i2s, SPI, and pwm working...
What do you think would be involved in getting i2c working? I've a load of i2c boards from my Pi collection that I'd like to see working on the Pine64.
Tony
I2C and SPI have already been added back in November : https://github.com/swkim01/RPi.GPIO-Pine...13214728bf
Thanks. Looking forward to trying it out.
Hi, I'm new with the Pine 64 board, but I have some experience with the Arduino board. I downloaded two operating systems for my Pine 64 using two microsd cards, the two operating systems are debian jessie with mate by Lenny Raposo and the Ubuntu desktop image based on longsleep, that were downloaded at this link http: // Wiki.pine64.org/index.php/Pine_A64_Software_Release. After I installed the two operating systems in the microsd cards, I followed the Github steps to install RPi.GPIO https://github.com/swkim01/RPi.GPIO-PineA64 to use in the python language using pi 2 Bus GPIO. I´ve followed all the steps, but when I go to the python command setup.py install or python3 setup.py install, the terminal returns this message "can not open the file 'setup.py': [Errno 2] not such File or directory, "but when I looked at the file system, I found setp.py in /usr/lib/python2.7/dist-packages and even if I entered that directory using the cd command, is showed the same mistake. This problem is appearing on both operating systems, would you like to know if have any solutions to this problem?
(02-08-2017, 08:44 AM)Blackfalcon Wrote: Hi, I'm new with the Pine 64 board, ... This problem is appearing on both operating systems, would you like to know if have any solutions to this problem?
Unpack the modules files into a working directory and run the setup.py from there;  use
cd /working/directory
sudo python setup.py
... try that and see what happens.
I unzipped the module files to a working directory but when I enter the sudo phyton setup.py command, the terminal returns the same message. When I try to program in python it returns me that the module was not imported correctly
Again, you must have forgotten to do "cd RPi.GPIO-PineA64-master" before doing "python setup.py install" ...
(02-08-2017, 12:48 PM)martinayotte Wrote: Again, you must have forgotten to do "cd RPi.GPIO-PineA64-master" before doing "python setup.py install" ...
Hi I have a problem with connecting Pine A64+ and MCP3008 digital/analog converter.
Can you help me how connect it to my Pine and read data from analog inputs  ?
Regards
Karlo
I don't have any MCP3008, but according to the specs, looking specifically to section No.6, it is explain how to deal with 8 bits SPI.
In summary, you should do a transfer of 3 bytes and you will read 3 bytes. The bytes sent should be [0x01, 0x80, 0x00] for example for getting single-ended conversion of the channel 0.
The 3 read bytes should be [0x00, 0x03, 0xFF] if the voltage input is at the maximum, assuming there is a pull-down on MISO, otherwise left floating, some more bits can become HIGH in the fist 2 bytes.
For code, it should looks like :
from pyA20 import spi
spi.open("/dev/spidev0.0")
data = spi.xfer([0x01, 0x80, 0x00], 3)
print data
hallo,
I installed the RPi.GPIO-A64 from git on a ubuntu longsleep image - by all steps:
- Installed Python and Python3, Python-dev
- pip(ed) the Rasp.Pi GPIO
- sudo python setup.py install
Than tried test.py from the test folder and received somthing like:
GPIO only usable on RaspberPI!
Did I missed somthing?!
Huh
ps.
wiringPI is a lib for C/C++ ?
  fm transmitter with gpio weasel18 2 4,833 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,604 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,146 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,226 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,860 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,645 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,785 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,197 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 16,029 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,104 11-10-2016, 06:07 PM
Last Post: joseph
