Debian build from mrfixit2001
Updated Debian Minimal by mrfixit2001 version 190531 on Wiki and Pine64 Installer
(06-19-2019, 01:55 AM)pineadmin Wrote: Updated Debian Minimal by mrfixit2001 version 190531 on Wiki and Pine64 Installer
I just loaded v190531 on my Rock64 V3 board and it appears to work well, except that every time it boots, it uses a random MAC address.  Can anyone point me in the right direction to fix this?
Thanks.
If I'm currently running this Debian for the Pinebook Pro could one update to Debian 10 through the command line? Or do we need to wait till it's up on the Wiki? I see on the Debian 10 release it does support arm64 but not this chip specifically and don't know enough about each architecture to know if it would work. Thank you
Thanks.
If you check dmesg, you will find the MAC address randomization is done during booting.
I used this disk image since the one by ayufan wouldn't boot. It works fine and after a couple days I got everything set up the way I want, only to realize this is stuck at the same kernel version. Not only that, but but this appears to be running as armhf, instead of arm64. I'm really hesitant to just install the latest linux-image package because in my experience with other ARM systems, overriding a fixed kernel like that usually results in bricking the whole install.
I'm not using a GUI, so if upgrading the kernel means breaking the GPU drivers, that's fine - I don't care. Anyone know if I can safely upgrade the kernel, let alone convert my setup to arm64 (I realize doing that would involve replacing just about every single package; that's fine)?
(06-24-2020, 04:33 PM)schmidtbag Wrote: I used this disk image since the one by ayufan wouldn't boot.  It works fine and after a couple days I got everything set up the way I want, only to realize this is stuck at the same kernel version.  Not only that, but but this appears to be running as armhf, instead of arm64.  I'm really hesitant to just install the latest linux-image package because in my experience with other ARM systems, overriding a fixed kernel like that usually results in bricking the whole install.
i was able to update to the latest ayufan one with a workaround discussed here
on kernel 5.6 now, start from 0.9.16 arm64; update and upgrade using the procedures mentioned and it should get you there.
Funny - that solution seems pretty obvious.  I'd have likely done the same thing, if I didn't have the mrfixit disk image to try.  But I really don't want to start all over again reconfiguring everything.  At the very least, I'd like to use the disk image I currently have and just upgrade the kernel without bricking it.  If I'm stuck with armhf, that isn't such a big problem for me, because aside from some MySQL commands, I overall don't think I'll see any performance improvements.  In some cases, 64-bit is actually slower on ARM.
I just tried this build on Rockbox, but it is very unstable, it keeps restarting after doing the upgrade and installing network-manager.
Well, it is not so bad after all. It runs KDE and I upgraded it to Debian 10, so it is even quite up-to date. Will play with it a little, if is it suitable for some tasks.
  How to update/compile Debian 12.5? Wizardknight 3 210 9 minutes ago
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 7,971 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 5,126 08-12-2021, 04:55 AM
Last Post: igorp
  Debian kernel stuck at 4.4.167 Enig123 5 5,491 12-29-2020, 12:57 PM
Last Post: kwinz
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,141 09-21-2020, 04:33 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,153 05-09-2020, 03:15 AM
Last Post: lawrencejd
Question alternative browser / seamonkey armhf build? kapqa 1 2,828 03-26-2020, 03:02 AM
Last Post: kapqa
  csdr build issues. TravisH 0 1,936 02-19-2020, 04:47 AM
Last Post: TravisH
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,080 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Upgrading Debian Stretch image to Buster cosuhi 2 4,658 08-27-2019, 02:42 AM
Last Post: Malmgren
