manjaro and qemmu+kvm
Hi, im trying to install qemmu on pinebook using manjaro.
I see kernel has enabled KVM via dmesg, but when try to create qemmu image ovmf files arent installed.
Strit said Anarsoul is kernel maintainer of manjaro-arm for pinebook.
But some packages aren't on majaro, like this, https://aur.archlinux.org/packages/ovmf-aarch64/
Any tips to install correctly qemu+kvm on pinebook?
I found more problems with qemu on manjaro arm pinebook.
sudo systemctl status libvirtd
● libvirtd.service - Virtualization daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2019-02-25 12:21:05 CET; 2min 5s ago
Docs: man:libvirtd(8)
https://libvirt.org
Main PID: 673 (libvirtd)
Tasks: 17 (limit: 32768)
Memory: 57.2M
CGroup: /system.slice/libvirtd.service
└─673 /usr/bin/libvirtd
Feb 25 12:21:12 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:21:58 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:21:59 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:22:06 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
(02-25-2019, 04:53 AM)erchache2000 Wrote: Hi, im trying to install qemmu on pinebook using manjaro.
Hi erchade2000
The package `ovmf-aarch64` that you mention is an AUR (Archlinux User Repository) package. AUR is not supported by `pacman`. The Archlinux devs prefer to have a natural barrier if you use AUR packages. That has advantages (you understand better what you are doing) but is also sometimes a bit cumbersome.
You can download and install the package manually (see wiki) or and generally more comfortably you use a so called AUR helper. The AUR helper makes access to the AUR repository very similar to the way pacman works and also can be used as a pacman replacement.
You might want to give `yay` a look (no dependencies) or maybe `trizen`
You can then install the package like this: `yay -S ovmf-aarch64`
If you use the AUR it is expected that you have installed the base-devel package group. Or you occasionally have to install a build dependency.
All packages available in the AUR for Archlinux are as far as I know also available for Manjaro.
(There are sometimes packages that are not supported for you architecture, but that's the same for Archlinux then)
Hi @erchache2000 ,
Have you managed to run qemu-kvm on your Manjaro?
If so, then could you please share your experience with managing some guest VM on such system?
My idea is to build a hypervisor that could manage 3-4 home servers (running on x86_64 servers). Is it possible with Pine64 boards?
Thank you.
Information Manjaro ARM for Pinebook erchache2000 88 112,987 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
  Plasma-wayland on Manjaro tophneal 2 6,098 09-01-2020, 06:48 AM
  Manjaro sway profile for pinebook e-minguez 3 5,340 07-21-2020, 03:25 PM
Last Post: jezek
  Manjaro instability DAMO238 6 9,395 10-17-2019, 12:55 PM
  Manjaro hangs on boot DAMO238 1 3,252 07-08-2019, 08:14 AM
Last Post: DAMO238
