04-21-2016, 07:23 PM
I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times
PhoenixCard Burning Error
04-22-2016, 12:12 AM
(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times We start release Android, Remix and Linux build images that can be burned by DD method.
04-22-2016, 12:25 AM
(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple timesDid you check your card? See: http://forum.pine64.org/showthread.php?pid=6097#pid6097 Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
04-22-2016, 02:22 PM
(04-22-2016, 12:12 AM)tllim Wrote:(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times Where can i find instructions for the DD method?
04-22-2016, 04:31 PM
(04-22-2016, 02:22 PM)alin123 Wrote:(04-22-2016, 12:12 AM)tllim Wrote:(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times Already posted at http://wiki.pine64.org/index.php/Pine_A6...re_Release. We plan to make this page better understandable on next few days.
04-22-2016, 08:19 PM
(04-22-2016, 04:31 PM)tllim Wrote:It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?(04-22-2016, 02:22 PM)alin123 Wrote:(04-22-2016, 12:12 AM)tllim Wrote:(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times (04-22-2016, 08:19 PM)alin123 Wrote:(04-22-2016, 04:31 PM)tllim Wrote:It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?(04-22-2016, 02:22 PM)alin123 Wrote:(04-22-2016, 12:12 AM)tllim Wrote:(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times Hi, have you tried Linux Live USB Creator ? http://www.linuxliveusb.com/downloads/?stable
04-24-2016, 02:34 PM
(04-23-2016, 12:49 PM)cookeys Wrote:(04-22-2016, 08:19 PM)alin123 Wrote:(04-22-2016, 04:31 PM)tllim Wrote:It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?(04-22-2016, 02:22 PM)alin123 Wrote:(04-22-2016, 12:12 AM)tllim Wrote: We start release Android, Remix and Linux build images that can be burned by DD method. I tried the linux live usb creator and it just gave me error messages part way through
04-24-2016, 03:18 PM
(04-24-2016, 02:34 PM)alin123 Wrote:(04-23-2016, 12:49 PM)cookeys Wrote:(04-22-2016, 08:19 PM)alin123 Wrote:(04-22-2016, 04:31 PM)tllim Wrote:It says to use phoenixcard for Remix OS. Also I couldn't find the DD method, which tab is it under?(04-22-2016, 02:22 PM)alin123 Wrote: Where can i find instructions for the DD method? OK, make sure you not got a counterfeit SD card. For me I had the same error but I retry few times and format my card in Fat32 with Minitool Partition and i works ! So try and tell me Have a nice day Cookeys
04-25-2016, 12:02 AM
http://forum.pine64.org/showthread.php?tid=548
You could try this. Had to do the plug-out->plug-in method for my burns as well, but it works quite reliably. You probably don't need to reset the partitions, just burn, wait for error, leave Phoenixcard running, reinsert the card and burn again. |
Need Sollution : Screen Problem and says the Error "Out of Range" on the display | hunterzonecss | 2 | 4,067 |
04-19-2019, 08:26 AM Last Post: psychedup |
