Fitting Rockpro64 inside Pinebook case
Hi all,
Please note that I've not delved into the matter properly (ie read the specs or look at the sizes) yet. But, conceivably, do you think at first glance it might be possible to fit the Rockpro64 Board inside the bottom case of the Pinebook? 14" model.
Thanks and regards,
(02-19-2019, 11:37 AM)made2hack Wrote: Hi all,
Thanks and regards,
No. But you will be able to fit a Pinebook Pro mainboard into a 14" Pinebook chassis.
Thanks Luke,
This is what I meant, the 14" chassis.
Who would I contact to find out the availability of the chassis? At the moment, it is out of stock.
Regards,
Thanks and regards,
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
  7" LCD on RockPro64 spammycheese 1 940 03-10-2023, 04:05 PM
Last Post: peteressive
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,514 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,496 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 15,673 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 5,992 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,956 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,057 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 3,546 07-08-2019, 07:15 PM
  Rock64's temperature while being in aluminium case _zernok 3 5,888 06-23-2019, 08:00 AM
Last Post: rasputin
