PINEBOOK USB PORTS too SHort?
Team,
I'm not new to PS's laptops or FOSS.
The idea of the Pinebook is awesome, the Pinebook Pro could be a game changer for many folks.
I have had my Pine book for more than a few weeks, but scheduling, holidays and life started to crowd out some other projects so I "queued it up" and have reached the point where I want to start writing on it.
Unfortunately I spend my daily hours in a hospital with stooped amounts of WIFI security, so far I cant get the Pinebook on the guest network, which Im ok with.
After all that's why God created USB memory keys right?
Sneaker-net!
Imagine my surprise when The USB key wouldn't go in less than 1/8 of an inch. Unsurprisingly the PB wont read it.
Tried 3 different keys, same thing. This started on the RIGHT port, because of AC, but one of them is pretty slim, so I moved it left.
same issue.
2 sandisk 32GB Duo's (USB(a) on one end Micro USB on th other) and a Sandisk Cruzer Glide 16GB
nothing really notable abouyt any of them
any ideas?
Im sure I haven't pushed them in as hard as I coiuld but just didn't think much more force should be needed.
j
ok, I determined to try some more "energy" and a little sense.
The keys would go in a small way. but no further. Upon close examination I couldn't see ANYTHING in the port, but when I was watching it while inserting the key I noticed a slight movement in the 'port'
so I decided to use the key to press down slightly as I went in and voila, full insertion, then when I booted both keys were found just as I wanted!
ive just never seen one o tight and slightly out of line....
  pinebook 1080p power/barrel connector/cable cel 0 496 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,321 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,168 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,564 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,216 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,529 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,538 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,509 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,631 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,687 07-02-2020, 06:33 PM
